Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 11-12-2014, 04:47 PM
  #5971
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
from avids facebook page
http://www.avidrc.com/product/5/acce...cessories.html
Wildcat1971 is offline
Old 11-12-2014, 05:06 PM
  #5972
Trader Rating: 25 (100%+)
Can't imagine losing flex will be an advantage... Maybe beneficial on carpet or on super high bite clay
kerby is offline
Old 11-12-2014, 05:56 PM
  #5973
I run on high bite clay. So I plan to try it out. That and the Rcshox rack should make the car more consistent
Old 11-12-2014, 05:57 PM
  #5974
Trader Rating: 53 (100%+)
What's the benifit of the avid chasis over the carbon?
CarFanatic is offline
Old 11-12-2014, 06:05 PM
  #5975
lower CG. My d413 feels top heavy on high bite, so I want to give this a try.
Old 11-12-2014, 06:26 PM
  #5976
Trader Rating: 116 (100%+)
Originally Posted by Wildcat1971
I am sure it is isolated. I have not heard of this happening. I have not had that happen and I run on high bite and drive the car hard.
Good to hear...I think that's the case also.
winstonite is offline
Old 11-12-2014, 06:34 PM
  #5977
ironzgti35's Avatar
Trader Rating: 33 (100%+)
Wonder if the floating servo mount works with the carbon chassis, didn't see a mention in the description
ironzgti35 is offline
Old 11-12-2014, 06:41 PM
  #5978
R/C Tech Elite Member
tom2tone's Avatar
Trader Rating: 99 (100%+)
Originally Posted by onekiwi
First drive e with the buggy tonight, what a handful it was. Very edgy.
Small track with tight sharp turns. Carpet + slicks with additive.
Previous owners setup.
Black arb f+r
F 4x1.3 700 gold
R 4x1.4 350 yellow
8-50-8
6.5 motor with 23 pinion too much so I'll look at a lower T motor as well.
On power the arse wants to overtake the front and the front hooks on the way out not helping this.
I haven't gotten to terms with all the toe and kick up etc so I'll get back once it's written down.
Any suggestions from what's given?
I have never raced carpet. But those hole pistons might be a bit soft for carpet. You also might need to go up in springs. HB red in the front for sure. Petite RC has some astro setups, not sure if that gets you closer. I goilg go much higher in center diff oil. 100k min, but probably closer to 300k for carpet
I got my kit today and I will also be racing on carpet. Should I pick up some springs as well? And diff oils are good to have on hand?
Any other suggestions or tips is appreciated.
tom2tone is offline
Old 11-12-2014, 06:46 PM
  #5979
I suppose it would work if you drilled another hold in the chassis.
I would definetly look at the high bite astro setups to start, you will want stigger spring for sure and probably some more diff oils. maybe a 15k for the front and 300k for center.
Old 11-12-2014, 06:51 PM
  #5980
Lazi's Avatar
Default exotek Parts
Look what Mike Cooking in the EXOTEK kitchen!
couple stuff coming out shortly.
center 2 piece spur gear.
this way you dont have to take apart a diff if u strip the gear. just unscrew the spur and switch to the fresh one.
its also a harder plastic.
the other one is the center top deck
and this is a new alu wing mount, you can use the Exotek wing washer with a 3mm. countersunk screw.
keep it in your mind these are for testing right now and when its going to be available we gonna see the usual topnoch Exotek finish!
Lazi is offline
Old 11-12-2014, 06:55 PM
  #5981
billdogg's Avatar
Trader Rating: 15 (100%+)
First practice night with this buggy. I am using Ty's Reedy setup with the exception of kit springs, plastic arm inserts. Running on a medium bite hard packed dirt track with SS gold web front, and clay dirt web rear. Car felt really good, except for low speed 180' turns. I'm new to 4wd cars. With my 2wd cars, I could blip the brake and get the car to rotate. With this, it would just slow down, and could not get the car turned quickly. I added a gold front sway bar as per suggestion from another racer. Car felt a bit better in high speed corners, but the same on the low speed corners.
What should I try, sway bars, springs, diffs?
Like I said, I'm new to 4wd, so tuning with sway bars and diffs is new to me. Any help with those would be appreciated.
billdogg is offline
Old 11-12-2014, 06:58 PM
  #5982
interesting, but I would like to see Flat head screws instead of buttons. I like the idea of replacing the spur without having to crack open the diff. Not sure about all of the alum bling up high.
Old 11-12-2014, 06:59 PM
  #5983
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
68 or 69T spur gear option would be handy if it's possible to do.
ajj is offline
Old 11-12-2014, 07:02 PM
  #5984
yeah, brake drifting a 4wd is harder for sure. try accelerating through the turn. Unlike 2wd. these cars will turn quickly with the wheels cranks and throttle applied. Kinda hard to explain. but you drive the 4wd through a corner, where as in 2wd you coast or brake slide the car. You can try softer front springs also, to increase the rate at which weight transfers and add a little droop the the rear. lots of things to do. If you are need to 4wd, I would just drive it a few weeks and get a feel for what a wheeler can and cant do.
Old 11-12-2014, 07:34 PM
  #5985
billdogg's Avatar
Will do, thanks.
Is there a good article out there for tuning with sway bars and diffs?
billdogg is offline
