Like Tree28Likes
Old 11-11-2014, 07:31 AM   #5941
Trader Rating: 52 (100%+)
what servo are you guys running in this buggy?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
CarFanatic is offline   Reply With Quote
Old 11-11-2014, 07:51 AM   #5942
Savox 1257tg
anthonybaston84 is offline   Reply With Quote
Old 11-11-2014, 07:53 AM   #5943
MasiisaM's Avatar
Originally Posted by ironzgti35 View Post
How critical is the C clip on the diff pinion? The rear diff couple bag did not have a snap ring in it and I don't have the proper size laying around. I doubt HPI will send out a replacement and the only way to get one is to buy the replacement gear set for $40
I would call them...Thats not fair.
The clip is critical. It really does hold everything together with proper mesh. Without it... i would think the mesh would float and strip the ring gear.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 11-11-2014, 08:21 AM   #5944
ironzgti35's Avatar
Trader Rating: 20 (100%+)
I sent an email last night and will do a follow up call today. The mesh seems ok on the bench but under load it would float was my thinking as well. If not, I'll hit a the hardware store and see if they have a snap ring that will fit
HB Racing – Proline – Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-11-2014, 08:42 AM   #5945
I just got my kit yesterday but I am confused as to what a snap ring is for the diff? can someone show me what you are speaking of?
cripplethreat is offline   Reply With Quote
Old 11-11-2014, 08:53 AM   #5946
ironzgti35's Avatar
http://www.amain.com/Hot-Bodies-Diff...Z6LRoCmcvw_wcB
Old 11-11-2014, 09:14 AM   #5947
kdeleon's Avatar
Yeah call them. My bearing was missing a seal when I first got the kit. I called and they sent a new one right away. No questions asked. It gets shipped from Tower Hobbies.
kdeleon is offline   Reply With Quote
Old 11-11-2014, 09:18 AM   #5948
luist99's Avatar
Send a message via MSN to luist99
Originally Posted by Wildcat1971 View Post
I am running red front and white rear with 42.5/37.5 oils and the 1.3x4 pistons. I dont feel like the car is overly tippy running the rest of ty's reedy setup with my shock package. I run on high bite bumpty and we run clay slicks.
Mine not tippy either it just flips really easy especially after strait away and I have baby it, but when every one else I hauling it's hard to Baby it. I have a few video posted in YouTube just search luist99 that way u guys could see the type of track I run. Don't get wrong the I love the buggy and it makes it to the Amani every time but it's just little frustrating I can't make it to the front just bcuz It flips, but I could be the drive also
luist99 is offline   Reply With Quote
Old 11-11-2014, 09:29 AM   #5949
ran into a 2wd SCT (hpi blitz) that was moving at ˝mph 2/3rd's down the straight, smacked into him at full speed and under power
(straight is right next to drivers stand, so one does not see whats at the end of the straight before car has passed and you have turned your head)
front shock tower shattered into multiple pieces, carbon was fine though, both shocks popped, a bent piston, and whats looks like a hair line fracture on the chassis carbon
put a new tower on the car and got rolling, will see if the chassis holds up
norcal hobbies had a front tower, and i got tons of spares...worst part is the car is out of alignment, wil have to drop it on to the setup board and get everything right again
Cygnus X is offline   Reply With Quote
Old 11-11-2014, 09:33 AM   #5950
luist99's Avatar
I bet nothing broke on the blitz
Old 11-11-2014, 10:01 AM   #5951
not s single thing !
Old 11-11-2014, 11:29 AM   #5952
luist99's Avatar
Lol, I own 2 of them and I know how tough the are.
Old 11-11-2014, 12:40 PM   #5953
I'm having a hard time picturing what you mean by flipping really easy if it isn't traction rolling. I'm not arguing with you or anything, just trying to understand the difference between traction rolling and what you are seeing with your car. I would call any flipping that isn't from some type of bump or rut traction rolling, but I'm probably wrong about that.
-Chris
iScream is offline   Reply With Quote
Old 11-11-2014, 03:13 PM   #5954
luist99's Avatar
-Chris
It could be traction rolling but there time that I'm going through the S section of the track and it just want to get up on 2 wheels. I'm only running a 9.5 motor so it's not that I'm over powering through the turns.
Old 11-11-2014, 03:59 PM   #5955
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I watched this https://www.youtube.com/watch?v=CTexIYXHypY
I have no idea which one is your car. But full speed into a flat right hander will traction roll if the traction is decent. Most of the drivers are coming in hot, braking in a straight line before the corner and then entering the turn. We had something like this at my track. I had to run a more gradual entry to the corner. because a hard turn even at lower speeds was too much. The Ty reedy setup did help the car slide more and not turn in sooo hard. The kit setup was so aggressive, even at slower speeds my car would flip.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
