Like Tree28Likes
Old 11-10-2014, 10:28 AM   #5911
trick25's Avatar
Trader Rating: 25 (100%+)
Originally Posted by CarFanatic View Post
I am thinking about picking up this car, is there any parts I should order with it that I need to make it more durable?
b5 caps and standoffs(plastic), run cap head screws on the 2 motor clamp screws instead of button and on the center top strap. Some run longer counter sunk scews on the cam to motor piece. Make sure you use threadlock to mount motor or you will prob strip a spur.
i broke a front hinge pin but i now believe that was a fluke. i also broke a rear rod end when a etruggy landed on me during practice laps but there are extra rod ends in the kit. Did not blame the car at all.
But in short. get the dang buggy. you will love it.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 11-10-2014, 10:29 AM   #5912
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Why not use 2 thumb screws for the shorty battery strap? Looks like you would need a wrench near by for a battery swap
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-10-2014, 10:31 AM   #5913
trick25's Avatar
the strap has a slot cut out that allows you to slide the strap out. it is not countersunk on this end. so its actually better to use a nut on this end.
Old 11-10-2014, 10:34 AM   #5914
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by slasn_48 View Post
Slotmachine have you heard from vrp about your pistons?
No word yet, I wrote them again today.
Paul
Update.....
I apologize for the delay on your order. I held it up a week so I can get you the latest piston design. Unfortunately, the Red Silicone Valve we have been using has shown a weakness in the colder temps of 'winter' racing. And in the spirit of offering the highest quality part, I felt the need to correct the issue was important enough to hold orders for a short period.
I finalized the new design yesterday. The new Valve will be made out of a rubber material that is 20 times stronger than Silicone and equally as flexible. They are much more chemically resistant and will most likely last forever. We will factory assembled the piston as one piece. And the functionality of it will be exactly the same as before.
The shop worked over the weekend to get new pistons made so they can be sent out on Monday/Tuesday. Also, fyi: anyone who purchased the original red silicone valved pistons will automatically get a new set of V2 pistons in the mail. This technology works very well and I'm committed to making a great product and having the service to go with it.
Thanks,
Mike
VRP
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 11-10-2014, 10:40 AM   #5915
ironzgti35's Avatar
True but do you not tighten that nut down? When I take off the thumb screw the flange nut is tight enough to not slide the carbon strap out
Old 11-10-2014, 10:56 AM   #5916
dMITIj's Avatar
I have a brand new kit for sale take it all 500$ and ill pay for the shipping (with insurance) and the Pay Pal fee. (im from Denmark)
http://www.oople.com/forums/showthread.php?t=159442
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 11-10-2014, 10:57 AM   #5917
I use the 2 thumb screws with no issues. Most pictures i see have the nut on the back. Maybe it's just choice idk lol.
anthonybaston84 is offline   Reply With Quote
Old 11-10-2014, 10:59 AM   #5918
trick25's Avatar
no i do not tighten it down. the flage nut i keep a little lower so when i crank down on the thumbe screw on the other end. the batt is not going anywhere.
think of it this way. if you were to use thumb screw on both ends. the taper edge of the nut will be in the slot where the flange nut will be a lot more contact area with the patch. But if you feel more secure with thumb screw on both ends. go for it.
Old 11-10-2014, 12:18 PM   #5919
Trader Rating: 52 (100%+)
the b5 caps aluminum or plastic?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
CarFanatic is offline   Reply With Quote
Old 11-10-2014, 12:19 PM   #5920
trick25's Avatar
use the plastic ones. aluminum ones wont work.
Old 11-10-2014, 01:06 PM   #5921
do you know the part number for the stand offs and caps?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
Old 11-10-2014, 01:12 PM   #5922
kdeleon's Avatar
Check the first post of this thread.
kdeleon is offline   Reply With Quote
Old 11-10-2014, 01:18 PM   #5923
got it thanks!!
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
Old 11-10-2014, 02:30 PM   #5924
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Originally Posted by dMITIj View Post
Turn the wing mount up side down should do the trick ;-)
That is out of the box thinking for you. I didn't even consider that. Thanks.
I just flip the thumb screw so it is flat side down on the slotted end of the strap.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 11-10-2014, 02:58 PM   #5925
ironzgti35's Avatar
How critical is the C clip on the diff pinion? The rear diff couple bag did not have a snap ring in it and I don't have the proper size laying around. I doubt HPI will send out a replacement and the only way to get one is to buy the replacement gear set for $40
