Like Tree35Likes
Old 11-04-2014, 04:38 AM   #5806
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by WagwanBumba View Post
You have your battery very far backwards on your chassis though. I keep meaning to chuck my D413 on the scales. Battery all the way forward and ESC in front of the motor.
Car did not handle well with the battery forward, look at the numbers on the picture. If you put the esc in front of the motor and also move the battery forward. You will have to to have entirely too much collar jack to get the cross weights back to 50/50. In testing just sliding the battery forward made the rear very unstable most noticeable on landings and on exit. You could probably get away with it on higher grip tracks but on a med bite track it was tough to drive.
The motor/esc weighs almost exactly what the battery weighs, seems logical to me that you would want them across from each other. As it sits the rear is almost perfect and the car just needs some weight on top of the servo.
MantisWorx is offline   Reply With Quote
Old 11-04-2014, 06:59 AM   #5807
snwchris's Avatar
Ran on new layout this past weekend and the D413 did great, the track was little tighter and some narrower lanes then usual with quite a few of 180s or U-turns and the car ands setup performed great.
I did manage to test out the durability again... LOL
The car got a litter wide in one of the turns and the front passenger side clipped a cement post.... and thought it was the end of that side... LOL come to find out it only popped the shock ball cap. The turn marshall pressed the ball cap on the tower and finished the race, granted I dropped down to 6th after being in 3rd, but my car is still alive and still drives.
Now if I had on one of the other caps, I bet something or the tower would have snapped, so I'm still like the "ball cup" shock caps
snwchris is offline   Reply With Quote
Old 11-04-2014, 08:34 AM   #5808
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by MantisWorx View Post
perfect balance that way!
Where did you get that scale!!!! That thing is awesome!! I want one.
jhautz is offline   Reply With Quote
Old 11-04-2014, 08:38 AM   #5809
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
SkyRC. you wont want it after you see the price, lol.
http://www.trinityrc.net/shop/index....product_id=653
$119 from hong kong
http://www.ebay.com/itm/SKYRC-Corner...item43ce1f7657
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-04-2014, 08:48 AM   #5810
MantisWorx's Avatar
I love it and IMO worth the price, its amazing what a balanced car will do and how much easier they are to drive.
Old 11-04-2014, 10:15 AM   #5811
Send a message via AIM to LightningStruck
That's actually pretty cheap compared to buying 4 digital scales!
LightningStruck is offline   Reply With Quote
Old 11-04-2014, 10:56 AM   #5812
offroad dude's Avatar
Trader Rating: 25 (100%+)
Here go a great place to get the scale from. Fast shipping and outstanding customer service.
http://www.discountrcstore.com/SkyRC...sk50001501.htm
offroad dude is offline   Reply With Quote
Old 11-04-2014, 12:19 PM   #5813
MantisWorx's Avatar
+1 Phil is awesome!
Old 11-05-2014, 06:21 AM   #5814
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Another wheel question...22 or 22-4 fronts? I know both work but 2wd fronts are narrower
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-05-2014, 06:22 AM   #5815
Trader Rating: 132 (100%+)
22-4 front and rears are a direct fit
skyline1015 is offline   Reply With Quote
Old 11-05-2014, 08:31 AM   #5816
Originally Posted by rcguy76559 View Post
I just started building one of these new d413 kits! What front wheels you guys running? I read 22 2wd wheels but was told to run 22-4 wheels by someone else. So im little confused. Thought the car was designed off of 22 wheels.
I was confused by this too. The 2WD wheels do not work, they have 10 mm hexes. Use the 22-4.
Last edited by jjl1; 11-05-2014 at 08:32 AM. Reason: left out the fact that this is for the front wheels only.
jjl1 is offline   Reply With Quote
Old 11-05-2014, 08:39 AM   #5817
Originally Posted by rclove13 View Post
I just received my d413. Shorty or saddle pack for best results indoor track
I am using the saddle packs and the set up works well for flat parts of the track but I have not been able to make it jump consistently. In fact I have ruined two rear shock mounts due to bad landings. I am going to change to the shorty to see if it is better. Not sure when I will get a chance to test due to weather.
Old 11-05-2014, 08:43 AM   #5818
The kit has 12mm AND some smaller front hexes
Old 11-05-2014, 08:47 AM   #5819
The smaller fronts are for B44 10mm wheels.
Old 11-05-2014, 08:48 AM   #5820
Yeah, but it was stated by HB that they "work" with the TLR 22 front wheels. There are quotes on the front page of this thread. Ty ran the 22 fronts last year at Nats, I think.
