Like Tree28Likes
Old 11-03-2014, 03:57 PM   #5791
you use the 22.4 front rims because the are made for the 4wd. the rears are the same for two wheel or four.
slasn_48 is offline   Reply With Quote
Old 11-03-2014, 04:03 PM   #5792
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
meh, lost an axle pin. Cant find them on amain. It appears to be about 1.6mmx11.8mm. Anyone know of a replacement pin?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-03-2014, 04:24 PM   #5793
If you snip the straight part off a large bodypin it should fit well enough to keep running. Easy enough to test-fit in the axle before you make the cut.
PetRock is offline   Reply With Quote
Old 11-03-2014, 04:41 PM   #5794
trick25's Avatar
Trader Rating: 25 (100%+)
the axle pins are not seperate from hot bodies. they are with the hex
HBS112746
or you can get the durango that are 14mm long and cut it a little short.
TDR310135
another option is get the durango cvd rebuild which has the roll pins. and im pretty sure you can use the rest of it to rebuild the axle. But i am not 100 percent the rest will work on the d413. But hot bodies does not have a cvd rebuild kit either. they make you buy the whole axle.
TDR210038
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 11-03-2014, 04:50 PM   #5795
I found some 1.6x10mm solid roll pins for my tlr/ae cars. I used a little shoe goo on all of my pins and goo'd and centered the 1.6x10mm pin.
Old 11-03-2014, 05:09 PM   #5796
RC Juice's Avatar
Trader Rating: 140 (100%+)
I just lost one and found some Axial ones that were perfect. I'll check my Amain order history for the part number, I think I found them by searching "12mm pin" or something like that. On my phone now but I'll check that order later.
RC Juice is offline   Reply With Quote
Old 11-03-2014, 05:10 PM   #5797
trick25's Avatar
that will work too. i still have a set of cvd rebuilds i was talking about from when i had the dex410. one day when i have the d413 apart i will mic the durango vs hot bodies cvd parts.
Old 11-03-2014, 05:26 PM   #5798
these probably?
http://www.amain.com/Axial-Pin-15x12mm-6/p18917
Old 11-03-2014, 06:48 PM   #5799
kdeleon's Avatar
Random question, has any one tried to eliminate the bump steer? Seem like I am toed in on full compression and toed out when the suspension in released. I haven't really noticed an issue but curious. Not sure if it can really be fixed as the suspension travel is so much compared to any other car that I have.
kdeleon is offline   Reply With Quote
Old 11-03-2014, 06:51 PM   #5800
RC Juice's Avatar
Yes sir, they work great.
Old 11-03-2014, 06:54 PM   #5801
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Has anyone tried putting 3mm limiters in the shocks yet?
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 11-03-2014, 08:02 PM   #5802
Nocal Hobbies (san jose) has two kits on the shelf !
Cygnus X is offline   Reply With Quote
Old 11-03-2014, 08:15 PM   #5803
Originally Posted by rclove13 View Post
I just received my d413. Shorty or saddle pack for best results indoor track
Every D413 I've seen was running a shorty.
Old 11-03-2014, 10:44 PM   #5804
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Would it be bad to run the esc behind the motor rather than in front of it.
perfect balance that way!
Hot Bodies D413 1/10 4WD Buggy-413-scales.jpg
MantisWorx is offline   Reply With Quote
Old 11-03-2014, 11:31 PM   #5805
You have your battery very far backwards on your chassis though. I keep meaning to chuck my D413 on the scales. Battery all the way forward and ESC in front of the motor.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
