Like Tree28Likes
Old 11-01-2014, 04:01 PM   #5746
Chr1s's Avatar
I just finished putting my car together. my left rear driveshaf bottoms out in the out drive before the shock does. And the front driveshaft looks like it's about to fall out at full droop. Yes I realize the front and rear driveshafts are different lengths, and the longer one goes in the front. Iso everyone's car like this?
Chris Kline
Chr1s is offline   Reply With Quote
Old 11-01-2014, 04:18 PM   #5747
Did you put the diffs in right one is front and one is rear.
slasn_48 is offline   Reply With Quote
Old 11-01-2014, 04:20 PM   #5748
Chr1s's Avatar
Never mind I figured it out
Chris Kline
Old 11-01-2014, 06:15 PM   #5749
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Ran my car for the first time tonight and it was very good! I did not run the stock set up but it was as fast as another in stock settings. I went to more rear toe in, forward swept front arms and 1.5mm behind the stud on the steering rack. I did not like the rack adjustment so Im going to no spacers next week.
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 11-01-2014, 06:40 PM   #5750
Originally Posted by MantisWorx View Post
True Integy and Exotek can easily do it but MikeR already responded for his reasons not too which are the truth!
We are way off topic so Pm me if you want to discuss further
ahhh cnc have moved on since i played with it about 8 years ago....but a cnc machine as you described could make it work $$$ wise....
my method of just removing 0.001" was for measurement only, once its figured out i would not do it such small increments....
i shot a mail to integy, maybe they will make some, and thats the last on that subject from me...back to D413 :-)
Cygnus X is offline   Reply With Quote
Old 11-01-2014, 07:30 PM   #5751
trick25's Avatar
Trader Rating: 25 (100%+)
Originally Posted by ColourGhost View Post
In Europe it's nearly impossible to get the stock shock caps, so i decided to get me the AE b5 aluminium caps BUT!! Damn expensive,- almost $100 with all you need to make them fit.
My big stash of parts is the only reason i dont sell this beautiful thing and buy a X-ray xb4 2015 when it's released soon.
SO does anyone know if i can make the Kyosho ZX6 shocks fit my D413 ?
aluminum b5 caps wont work.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 11-01-2014, 08:43 PM   #5752
Originally Posted by Shark413 View Post
What do you guys (and gals) think looks better with my paint scheme, white or black wheels?
For bashing black is a popular choice. On the track I like white or yellow - like Marcus I prefer to be able to see the rim and tire move as I steer: it also makes suspension movement (i.e compression through a corner) stand out more.
PetRock is offline   Reply With Quote
Old 11-02-2014, 10:55 AM   #5753
I just about finished up building my chassis yesterday. You guys aren't kidding on the steering slop and I even filed by bushings down a bit. How are you guys setting your toe up front?
I was disappointed with the CV joints for the driveshafts going to the wheels too. My front joints were binding really bad when I first built them. Had to take them back apart and work on them with some fine sandpaper so they were smooth. One of the rears needed a little work too but nothing like the fronts.
Should be able to get my electronics installed this evening and hopefully make it out to the track in the next few days.
I have my shocks 99 percent built per the manual but not filled. I'm thinking about going emulsion with them after reading comments in this thread. If I do, should I still start with the pistons and oil weight specified in the manual?
Thanks,
Chris
iScream is offline   Reply With Quote
Old 11-02-2014, 11:35 AM   #5754
You are doing something wrong...
1. i got mine from an UK online shop, easy.
2. The aluminium caps dont fit well, waste of money.
3. Kyosho shocks are too small.
4. Selling the car because of the shock caps?
nicmo is offline   Reply With Quote
Old 11-02-2014, 11:50 AM   #5755
1. No problem getting the kit
2. Ok- Thanks
3. Damn!!! Are you sure ? If i run 3mm inside limiters on my d413, would the Kyosho not be spot on ?
4. Not just the caps, also the rest 30% of the parts are "out of stock".
ColourGhost is offline   Reply With Quote
Old 11-02-2014, 02:27 PM   #5756
Send a message via AIM to LightningStruck
Those of you that have used the RCShox pistons, did you have a fair amount of space between the piston and shock inner wall? The stock pistons are 11.90mm in diameter, and I measured the RCShox pistons at 11.61-11.63mm.
~Curt F.~
Agama A215, REDS R7, Futaba 4px, Byron Fuel
AE B5M, Reds 8.5, Tekin Rs
Special thanks to: Nemo Racing, Reds Racing, LeadFinger Racing
LightningStruck is offline   Reply With Quote
Old 11-02-2014, 03:03 PM   #5757
MantisWorx's Avatar
Trader Rating: 28 (97%+)
That is done on purpose because they are thicker and the sidewall is parallel. stock pistons are molded plastic, round edged not flat and soft. With the side of the piston straight you get less stiction on the shaft. They are exactly how i designed them to be!
Hot Bodies D413 1/10 4WD Buggy-01ede49737147e02354e2ff633bbefd0a3259720b0.jpg   Hot Bodies D413 1/10 4WD Buggy-0162eef339edf7031ce98863f9de4e65b5f6f42eb9.jpg
MantisWorx is offline   Reply With Quote
Old 11-02-2014, 04:35 PM   #5758
Just making sure. Just because people make things for years, doesn't mean screwups don't happen. I work for the largest a equipment manufacturer in the world, and I see screwups everyday
Old 11-02-2014, 05:02 PM   #5759
Those pistons work...let my buddy,local A main driver, race the D413. I think the pistons made the suspension more planted. He was TQ and won with the car. I think the car is really good also, but Rob can win with a Radio Shack Golden Arrow!!
buyselltradeevy is offline   Reply With Quote
Old 11-02-2014, 05:07 PM   #5760
MantisWorx's Avatar
Understood but in this case I am the one programming and machining these particular parts! On the industrial side of the shop we have 13 employees and its a circus all day long!! Not sure if you have ever had to deal with a NASA project or not but we do at least 2 a year and it will make you pull your hair out, We cant even do inspections on days where the humidty is too high or too low!
I spend alot of time at the track trying all kinds of tolerances . I was at the track yesterday for 8 hours just playing with oils and piston thickness' In my research i have found that with 10th scale they feel better with looser PTW clearances than 1/8 scale.
