Like Tree28Likes
Old 10-30-2014, 08:45 PM   #5671
tom2tone's Avatar
Trader Rating: 98 (100%+)
So I've been thinking of picking up the D413 and have heard several people mention the slop. Is there a fix for it?
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 10-30-2014, 08:48 PM   #5672
I know there was guys saying they didnt like the slop in the ackerman bar. Rcshox just released a ackerman bar thats suppose to eliminate slop.
Beaker151 is offline   Reply With Quote
Old 10-30-2014, 08:52 PM   #5673
tom2tone's Avatar
Ok thanks for the quick reply! I think I just need to order one already
TEKNO EB48.3 / ET48
AE T5M & B6
Old 10-30-2014, 08:53 PM   #5674
Trader Rating: 29 (100%+)
According to Torrence, it was designed and built with more "slop" than most other top brand cars, intentionally. The reason being that as you get the chassis broken in the car stays consistent. But... if it is built with slop to begin with then I would imagine this eliminates this chassis break in period? Either way, this car is well designed and drives like no other 4 wheel. It's as aggressive as you want and easily mellowed out. Excellent choice for someone looking to get into 4 wheel buggy.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 10-30-2014, 08:54 PM   #5675
That BANANA drives me NUTS!!!! LOL
Old 10-31-2014, 05:24 AM   #5676
rider313's Avatar
Trader Rating: 94 (100%+)
Wow, Amain has 33 D413 kits in stock. Lets see how long they last
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 10-31-2014, 05:37 AM   #5677
MantisWorx's Avatar
Trader Rating: 28 (97%+)
I agree with this somewhat but not in the steering department, that linkage needs to be slop free for sure. I tend to not use AL hubs or any "bling" and leave a little slop on my rides especially at the arms. anything that mounts to the chassis i tighten all the way and then back off a 1/4 turn.
MantisWorx is offline   Reply With Quote
Old 10-31-2014, 06:15 AM   #5678
RC Juice's Avatar
Trader Rating: 140 (100%+)
Any suggestions for "mellowing" it out? This is my first 4wd buggy and I'm getting better and better but it still seems do twitchy to me and I feel like I am constantly over-steering it and chasing it back and forth.
RC Juice is offline   Reply With Quote
Old 10-31-2014, 06:16 AM   #5679
trick25's Avatar
Trader Rating: 25 (100%+)
what tires are you running. especially front.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 10-31-2014, 06:19 AM   #5680
RC Juice's Avatar
I had Rebars and tried some Holeshots on it last night. I run on an outdoor clay track that does get watered and becomes very tacky but does also get dry and loose.
Old 10-31-2014, 06:30 AM   #5681
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
try a stiffer front spring and maybe go up in oils.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-31-2014, 06:40 AM   #5682
RC Juice's Avatar
My current setup is AE red fronts with 37.5 and 2x1.6, and AE white rears with 32.5 and 2x1.7. When I first got the car, I got is used and ran it as it was to get a baseline. The thing drove like a washboard and was al lover the place, when I got it home I took it apart and found that he had modded some stock pistons by plugging off 2 holes in each and was essentially running 2x1.2 fronts and 2x1.4 rears. The changes I made helped smooth out the car a lot, our track is very bumpy.
Should I stiffen up both the front springs and oil you think?
Old 10-31-2014, 07:45 AM   #5683
when you said all over the place, I figured you meant twitchy. Not bouncing all over. I run indoor on a pretty bumpy track. I also use AE red/white springs, but I am running 1.3x4 pistons front and rear. My car is pretty planted over the bumps. otherwise,m my setup was pretty much box stock. I just slapped on Ty's reedy setup, but with 1.3x4 pistons with 42.5/37.5 oils. Since i dont have 2 hole pistons yet.
Old 10-31-2014, 09:13 AM   #5684
snwchris's Avatar
If you can post up a video of you driving it, curious if its setup or driver skill with learning 4w buggy. Also have one of the local fast guys in 4w buggy try it out and see what they think, that can help a lot as well.
I put a 7.5 motor in mine just so I wouldn't get in over my head. So far its been perfect and fast enough to keep up with the fast guys as well.
snwchris is offline   Reply With Quote
Old 10-31-2014, 09:36 AM   #5685
snwchris's Avatar
Originally Posted by lovell View Post
I wish I could post a picture. I have been running the serpent caps for two race weekends with zero issues. The fronts screwed right on while the rear caps showed resistance. It may seem that they don't work , but there was coating in the threads that needed cleaned out. Once the threads were cleaned out,, the caps screwed on with ease. I used the emulsion seal in the cap and have zero leaking issues.
Proof of Serpent Cap on the D413, thanks lovell for the pics.
Hot Bodies D413 1/10 4WD Buggy-serpent-cap-1.jpg   Hot Bodies D413 1/10 4WD Buggy-serpent-cap-2.jpg
