Like Tree29Likes
Old 10-28-2014, 09:46 AM   #5566
Originally Posted by skyline1015 View Post
I need more off power steering. my setup below...
https://www.dropbox.com/s/lmn6mqtb1j...setup.pdf?dl=0
15K in the front, and 12 deg kickup is probably why it doesn't have enough off power turn in. I bet it has a TON of on power steering tho.
Go lighter in the front diff oil and maybe a little less kickup.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-28-2014, 09:49 AM   #5567
MantisWorx's Avatar
Trader Rating: 28 (97%+)
YUP!!
MantisWorx is offline   Reply With Quote
Old 10-28-2014, 09:50 AM   #5568
Would adjusting the arm sweep help?
buyselltradeevy is offline   Reply With Quote
Old 10-28-2014, 04:22 PM   #5569
billdogg's Avatar
Trader Rating: 15 (100%+)
I haven't been keeping up with this thread lately. I just got my D413 in the mail. What's a good setup for indoor, medium track, medium/high grip hard pack dirt.
billdogg is offline   Reply With Quote
Old 10-28-2014, 06:46 PM   #5570
Is Associated black grease the wrong stuff to put on diff outdrive shafts?
My front and rear diffs had gotten really stiff: they were almost posi even with 7000/5000 oils. I hadn't noticed when when we were goofing off outdoors, but as soon as I moved back to carpet the buggy pushed through every slow tight corner.
When I opened things up the outdrive that went through the plastic diff housing spun freely... but the one that went through the metal ring gear was almost locked up. It took penetrating oil, a screwdriver slotted into where the dogbone goes, and wrap of paper towel on the ring gear so I didn't cut myself... just to let me wiggle it long enough to get it free. I had put the same amount of AE black grease on both shafts when building: should I have used something else?
A perfectly acceptable answer is "pay attention, and do more frequent maintenance" . But before I seal them back up I thought I'd ask if I should lube them with something else. Thanks!
PetRock is offline   Reply With Quote
Old 10-28-2014, 07:07 PM   #5571
Quick question for the guys running AE caps, are you using the AE sealing o-ring for the top of the shock as well? Everything I see only mentions the caps and standoffs and I want to make sure I have everything I need to reassemble the shocks tomorrow for a big race Saturday. Thanks!
AMorgan is offline   Reply With Quote
Old 10-28-2014, 07:14 PM   #5572
Slight leaking without the o'ring, is there a seal you can put in the cap? So slight that I don't even worry about it, although I'm into my shock non stop for testing.
uncle everett is offline   Reply With Quote
Old 10-29-2014, 02:40 AM   #5573
I had that same "locked diff" problem before our heats last Saturday. With A FULL rear diff(10k) after a 5 minute run the rear end was locked. If you let the buggy sit for 15 minutes or so the diff would free up. I drained it, put 7k just up to the cross shafts and reassembled. It's been fine ever since. Did I overfill? That is probably the obvious answer, but doesn't the silicone diff fluid get thinner as it gets hotter?
Old 10-29-2014, 03:01 AM   #5574
cokemaster's Avatar
Trader Rating: 18 (100%+)
Use the bladders that came with the kit (bladder style or emulsion style).
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 10-29-2014, 03:11 AM   #5575
In getting thinner, it also expands and if pressure has increased in the diff, you might get hydro-locking because of the oil expansion.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 10-29-2014, 03:32 AM   #5576
When do your little darling (D413) bottom out, - i mean from which hight ? I have put 850 oil front and 600 rear with 4x1.4mm pistons and it still feels a little soft, and bottoming out when i drop it from above 30cm. And yes the shocks are put together correct (emulsion style). I run indoor carpet, and i was inspired by a team X-ray driver from my track running the same oil front and rear, but with costum 3x1.7mm pistons. maybe i should try with the stock 4x1.3mm instead, what are your thoughts ? Enjoy RC people
ColourGhost is offline   Reply With Quote
Old 10-29-2014, 04:31 AM   #5577
That ring would probably work, they'd have to be emulsion
Old 10-29-2014, 06:13 AM   #5578
snwchris's Avatar
TYs Reedy setup is a great starting point for what you described. There's 3 of us running that setup at our track which is about the same description.
snwchris is offline   Reply With Quote
Old 10-29-2014, 06:30 AM   #5579
MantisWorx's Avatar
Try 2 stage pistons, they are 3x1.4 and eliminate the bottoming out.
Old 10-29-2014, 06:32 AM   #5580
snwchris's Avatar
I hate to say it but the Xray is a totally different animal, so what he's running for oils might not work in your car or set-up.
I would say try one on the Petitrc setups, there's a couple for astro turf high bite and there's a couple of TYs on Clay w/sugar very high bite. I really think you should look into the 2x1.6 pistons. Maybe start 37.5F 32.5R, maybe even step up to 40F & 35-37R
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
