Like Tree28Likes
Old 10-27-2014, 06:27 PM   #5551
Trader Rating: 15 (100%+)
Originally Posted by Jason84 View Post
What does everybody use to lube CVD's now days ? Think I use to just use MIP grease but cant find any at my LHS unless I buy a CVD kit I wont need lol. I built my car yesterday but didnt grease them will just have to take them back out to lube not a big deal !
Only problem I had was I was tightening one of the 4 screws on the center diff and it wouldnt get tight and the screw imbeded into the gear and now it doesnt turn straight when its in the car and I spin it... gonna try it but hopefully wont have an issue with it. Did anybody else use washers for these tiny screws ? Just seems like that is a really soft plastic for that small of a screw....
And my integy driver set didnt come with a 2mm and 3/4 of the screws on this car are 2mm ! Ended up using the 3/32 which is 1.95 close enough I guess !
Center diff.....
It's not seating properly, I had to sand down the back side of each convex gear to free up the entire diff.
uncle everett is offline   Reply With Quote
Old 10-27-2014, 06:56 PM   #5552
Originally Posted by uncle everett View Post
Center diff.....
Really ?! I didn't think it would be that tight in there. Mine is together and not leaking. I think i just expanded / deformed the plastic where the 1 screw went in to far. It seams to seat fine just that I couldnt tell when it was tight enough.
Think on my next spur i will add really small washers to help that.
Jason84 is offline   Reply With Quote
Old 10-27-2014, 07:18 PM   #5553
I found it best to pre-thread the holes in the diff cup with the screws before assembling the diff. Makes it easier to tell when it's tightening down against the spur gear. I use a 0.050" power driver bit to carefully run the screws in and out of the diff cup. The screws actually get pretty hot from the friction. I run them almost all the way in and let them cool off awhile before removing them. This forms the threads in the plastic to give a snug but not overly tight fit for the screws.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-27-2014, 07:39 PM   #5554
bedwell1's Avatar
Has anyone tried the optional shock towers or Ackerman arms? Any feedback.
bedwell1 is offline   Reply With Quote
Old 10-28-2014, 01:54 AM   #5555
what pinion should i start with on a small tight track with a tekin 7.5
billsharp34 is offline   Reply With Quote
Old 10-28-2014, 03:21 AM   #5556
Default Option parts
Love this thread - Thanks guys for all the info. Option parts to the D413 are not falling from the sky, so would someone please make a list of parts fitting. Im really interested in pre drilled pistons. I read earlier in the thread that Avid, Kyosho, AE doesn't work well, but what does work ?
Also i heard the sworkz wing is a really good option.
Enjoy -
ColourGhost is offline   Reply With Quote
Old 10-28-2014, 05:38 AM   #5557
snwchris's Avatar
I would say start with 24T and maybe carry a 25T. I have a 7.5 on medium sized track and running 25T with mine. The first page has a quick ref. gearing chart to can check out as well.
snwchris is offline   Reply With Quote
Old 10-28-2014, 05:40 AM   #5558
snwchris's Avatar
Enjoy -
RCshox (mantis on here) just came out with some predrilled pistons, 2x1.6, 2x1.7 and I believe 3x1.3. Take a look at the site and check out.
Old 10-28-2014, 05:54 AM   #5559
trick25's Avatar
Trader Rating: 25 (100%+)
i like the sworz wing but otheres do not. i love it cause im not replacing it all the time. made out of thick plastic instead of lexan.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is online now   Reply With Quote
Old 10-28-2014, 05:55 AM   #5560
trick25's Avatar
i to run 24t on a tackstar 7.5
Old 10-28-2014, 06:08 AM   #5561
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I use the sworkz wing. I dont have any issues with it. Weights about the same as the trifecta
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-28-2014, 06:15 AM   #5562
Just looked, Thanks. The ackerman looks very nice too.
Old 10-28-2014, 07:52 AM   #5563
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Enjoy -
Also be sure to check out Vision Racing Products for an assortment of different sized pistons. http://www.visionracingproducts.com/...es-D413_c5.htm
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-28-2014, 09:32 AM   #5564
Trader Rating: 129 (100%+)
Originally Posted by Wildcat1971 View Post
haha, I just posted a video above running high bite with slicks. I have plenty of steering. Are you referring to on or off power steering on entry?
I need more off power steering. my setup below...
https://www.dropbox.com/s/lmn6mqtb1j...setup.pdf?dl=0
skyline1015 is offline   Reply With Quote
Old 10-28-2014, 09:44 AM   #5565
Try laying the front shocks down.
slasn_48 is offline   Reply With Quote
