Like Tree28Likes
Old 10-27-2014, 08:54 AM   #5536
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by nv529 View Post
Your car looks like a handful to drive.
haha, it is better than it was. Some parts of the track are very grippy and rutted. Other parts have less bite and are smoother. There was a few times where the car got very upset quickly. It defiantly does not settle in quickly. On some of those doubles, I had to pause for a split second for the car to settle down. In comparison, my b5m is very easy to drive and pulls the same laptimes as my 4wd, lol. Made me a little sad.
I am running the kit setup on most of the car, including sway bars. I did go with middle inner camber link and top outside in the rear. Outside (short) front camber link. I was running 1 limiter front, 0 limiter rear with the eyelets all that way tightened. I wanted to see if less droop helped with the traction rolling. I do feel like that helped a little. Running 1.3 pistons with 42.5/37/5 and traxxas xrings. Clay slicks. 10/100/7 diff oils. Shorty in the middle position
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-27-2014, 09:04 AM   #5537
JDJamminX1's Avatar
I ran the AE X-rings for a little. They are not the right size as they will suck air into the shocks creating unwanted rebound. Switched back to stock. No more issues.
Sometimes you just have to stay with what you know.
I did like how the x-rings felt, but didnt feel like working on my shocks in between every heat.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 10-27-2014, 09:06 AM   #5538
yeah, several people have had issues with the AE xrings in the d413 shocks. The traxxas ones seem fine. No leaking or excessive air.
Old 10-27-2014, 09:16 AM   #5539
snwchris's Avatar
Still using stock orings here with no issues and just rebuilt them to Emulsion this weekend at big race and felt smooth as butter.
snwchris is offline   Reply With Quote
Old 10-27-2014, 10:31 AM   #5540
Send a message via AIM to LightningStruck
So the losi pistons work, no problems?
LightningStruck is offline   Reply With Quote
Old 10-27-2014, 10:32 AM   #5541
Trader Rating: 129 (100%+)
Default Setup for tight track on high bite clay
hey guys, i need a little help with a setup on a high bite tight clay track running slicks. i need more steering on entry.
skyline1015 is offline   Reply With Quote
Old 10-27-2014, 10:33 AM   #5542
Dont use the TLR pistons. They are NOT a direct fit. RCShox has some machined pistons out for the car, I would get those.
Old 10-27-2014, 10:34 AM   #5543
haha, I just posted a video above running high bite with slicks. I have plenty of steering. Are you referring to on or off power steering on entry?
Old 10-27-2014, 10:38 AM   #5544
RC Juice's Avatar
Trader Rating: 140 (100%+)
I just built my shocks this weekend emulsion style with the TRX x-rings as suggested here and they were great at Sarurday night practice. I drilled my own 2x1.6 and 2x1.7 pistons and am definitely on the right path with the handling of this car (running 32.5/37.5 oil).
RC Juice is offline   Reply With Quote
Old 10-27-2014, 11:26 AM   #5545
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
post your set up, then we can suggest what to change.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 10-27-2014, 03:18 PM   #5546
Default RSX and PRO2 5800
Originally Posted by yzracer758 View Post
RSX all the way! I will post back with results
What did you find out...my electronics are in the mail?!?!
buyselltradeevy is offline   Reply With Quote
Old 10-27-2014, 03:51 PM   #5547
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Unforunately, our Test track was torn down earlier this summer to make way for our building expansion. The track won't be rebuilt till next spring.
We have no doubt the setup with the Pro 2/RSX will work good.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-27-2014, 03:57 PM   #5548
What kind of EPA are you guys using with the aluminum HB horn and steering link in the stock hole? I've been running mine in the inner hole because I had to turn my EPA way down to get it set right in the rear hole. Guess I'm trying to figure out if its just me or I've not thought of something. Thanks!
AMorgan is offline   Reply With Quote
Old 10-27-2014, 05:55 PM   #5549
What does everybody use to lube CVD's now days ? Think I use to just use MIP grease but cant find any at my LHS unless I buy a CVD kit I wont need lol. I built my car yesterday but didnt grease them will just have to take them back out to lube not a big deal !
Only problem I had was I was tightening one of the 4 screws on the center diff and it wouldnt get tight and the screw imbeded into the gear and now it doesnt turn straight when its in the car and I spin it... gonna try it but hopefully wont have an issue with it. Did anybody else use washers for these tiny screws ? Just seems like that is a really soft plastic for that small of a screw....
And my integy driver set didnt come with a 2mm and 3/4 of the screws on this car are 2mm ! Ended up using the 3/32 which is 1.95 close enough I guess !
Jason84 is offline   Reply With Quote
Old 10-27-2014, 06:22 PM   #5550
I use AE grease. but you can just goto auto zone and pick up some moly grease
