Like Tree42Likes
Old 10-24-2014, 05:10 AM   #5461
slakr's Avatar
Trader Rating: 28 (100%+)
Originally Posted by MantisWorx View Post
done!
Ordered a set of each size plus the steering rack. Thanks Marcus
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 10-24-2014, 05:15 AM   #5462
snwchris's Avatar
My downloaded manual from PetitRC has TYs Silver Dollar Roar Nats on pg36. If you go thru manual as if you were building the kit, it does list out the stock info for building it.
snwchris is offline   Reply With Quote
Old 10-24-2014, 05:20 AM   #5463
offroad dude's Avatar
Trader Rating: 25 (100%+)
Yes
Is there a website I can go to so I can buy a set or do I just send you a PM?
offroad dude is offline   Reply With Quote
Old 10-24-2014, 06:43 AM   #5464
slakr's Avatar
http://www.rcshox.com/hotbodies/
Old 10-24-2014, 07:13 AM   #5465
I just finished doing the exact same thing...
Old 10-24-2014, 07:41 AM   #5466
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
the guys here in ohio are doing really well with these pistons, you guys should give them a try. You won't be dissapointed, the 2 guys who own the company have been racing for like 30 years each and this is the first product they had to make sure everyone could have.
http://www.visionracingproducts.com/...es-D413_c5.htm
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 10-24-2014, 07:49 AM   #5467
That's a nice looking product!
Old 10-24-2014, 08:01 AM   #5468
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
MantisWorx, which ackerman configuration did you design the steer bar from?
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 10-24-2014, 08:10 AM   #5469
jwood7's Avatar
Default shorty vs saddle
has anyone ran the car in both battery configurations? i know ty runs a shorty but i am not ty. curious as to what the difference in handling is
jwood7 is offline   Reply With Quote
Old 10-24-2014, 08:28 AM   #5470
Check this out Nick!
http://www.rcshox.com/d413-ballbearing-ackerman-bar/
Old 10-24-2014, 08:36 AM   #5471
Graham11's Avatar
Trader Rating: 21 (100%+)
are these ackermans designed to take the slop out? I just finished building my d413 and holy slop! Pretty disappointed with how soft the plastics are and the over all slop of the vehicle, over all the kit seems pretty great but the plastics, slop, and instructions are the weaknesses so far. Now all of that will be null and void if it performs well but thats just my initial feedback.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 10-24-2014, 08:42 AM   #5472
bigemike's Avatar
yes they are dialed, you can see the difference in how fast the car settles down and how quickly it reacts, you get better turn in and the car doesn't scrub as much speed coming off of big jumps. Also running through rough sections is visably faster with these pistons. I am not sponsered by them, I have just used them and seen the difference in my lap times.
Use whatever piston size you normally would with the same shock oil and you will see and improvement. I have seen these run for over 10 races and no rebuild has been needed yet. Biggest killer is if you cut a valve when taking off an eclip.
You guys should really try them, they are fully supporting the d413
Also the fit and finish and the smoothness of these even over other companies machined pistons is notable, they have alot less variation in size from one piston to the next.
Old 10-24-2014, 08:47 AM   #5473
His page doesn't say which config it's based off. The stock rack has 4 different options.
Originally Posted by T. Deguzman View Post
the +/- raises and lowers the rack 0.5mm for bump steer adjustment. if the + is facing up it is higher, with the - facing up the rack sits lower. you can also put shims under the rack if you need more than 0.5mm.
the dots are for ackermann adjustment. if you have the dot facing forward it pushes the ballstud further forward, giving you less ackermann and vice versa. similarly you can also use shims. i designed it this way in case if you want to run the ballstud far forward you don't have to use huge stack of shims and possibly run out of thread engagement.
Hot Bodies D413 1/10 4WD Buggy-d413.jpg
Nick Vasquez
Old 10-24-2014, 08:57 AM   #5474
The rack bushing are too long which is producing most of the steering play. Most of it can be removed by dremeling the bushing flush (red area) to the rack (yellow area).
Hot Bodies D413 1/10 4WD Buggy-1.jpg
Nick Vasquez
Old 10-24-2014, 09:08 AM   #5475
snwchris's Avatar
I was curious too with the slop, but the car handles amazing IMO and have been running for about 4wks.
