Like Tree28Likes
Old 10-23-2014, 11:48 AM   #5431
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The shock guards. Are peopel using them? I have been, but they cause the cup to get dislodged a lot. I have it happen every other pack, mostly in the front.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-23-2014, 11:48 AM   #5432
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Will the lunsford or avid standoffs for the B5M fit the D413 when swapping caps or must you run the normal screw standoff?
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 10-23-2014, 11:50 AM   #5433
any of the B5 mounts should work fine. I used the AVID and the AE kits ones with no issues
Old 10-23-2014, 11:51 AM   #5434
snwchris's Avatar
Also when removing the shocks from tower, in one of the tips, they recommend removing the whole mount from tower, so that way the "ball cup" cap doesn't start getting play. Check out first page for pic.
snwchris is offline   Reply With Quote
Old 10-23-2014, 11:52 AM   #5435
I use them only on the rear. There shouldn't be much throwing dirt onto the front shock shafts. After all, you should be in front of the rest of the field, throwing dirt on their cars.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-23-2014, 11:53 AM   #5436
ture, popping them on and off will only make it worse quicker.
Old 10-23-2014, 11:53 AM   #5437
yeah, I used to only run them in the rear. I am going to go back to that. I dont like them on the front.
Old 10-23-2014, 11:56 AM   #5438
snwchris's Avatar
As of right now the only option for Alum Shock Caps is piecing together some parts from the Serpent SRX buggy, but it gets pricey. A lot of us are waiting to hear when Prolines Alum Caps will be ready.
Originally Posted by lovell View Post
I have serpent caps on my d413.
Here are the part numbers needed
500146-14.50
500137-4.69
500199-11.49
2-500176-23.99
500179-2.50
Old 10-23-2014, 02:24 PM   #5439
Bburns's Avatar
Last I knew was proline wasn't making the caps, those were just one offs for ty. HB is working on aluminum caps.
Mugen Seiki racing - Austintown Hobby Shop
Bburns is offline   Reply With Quote
Old 10-23-2014, 02:51 PM   #5440
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Brandon is correct, Proline will not be producing caps although they could have made a killing by now.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-23-2014, 05:02 PM   #5441
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by slakr View Post
I'm waiting for Marcus to say his 2x1.6 & 2x1.7 pistons for the D413 are available
done!
MantisWorx is offline   Reply With Quote
Old 10-23-2014, 06:32 PM   #5442
trick25's Avatar
Trader Rating: 25 (100%+)
are those $13 bucks per piston??
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 10-23-2014, 06:53 PM   #5443
https://www.facebook.com/pages/RCSho...13498721997258
I think he said per set, so 2x pistons I think. Although, "pair" should mean 2 and a "set" should be 4.
When you buy a set of tires for your real car, that is 4 tires and a pair is 2. Unless you say, I want a set of rear tires, then that is 2 because you ware only referring to the rear tires. Unless you have a dually, then it is 4 tires for the rear set.....
Old 10-23-2014, 07:06 PM   #5444
trick25's Avatar
ok i just saw it on the rcshox website and all i saw is a pic of one.
Old 10-23-2014, 07:21 PM   #5445
MantisWorx's Avatar
Its for a full set of 4, sorry about the confusion
