Like Tree31Likes
Old 10-23-2014, 08:35 AM   #5416
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by snwchris View Post
Not sure if the TLR pistons would have same issue
They will not, the 413 pistons shaft hole is really small.
MantisWorx is offline   Reply With Quote
Old 10-23-2014, 08:52 AM   #5417
dMITIj's Avatar
I'm considering buying a D413 but is there some parts I need to buy right from the go, while I'm ordering? think I've read a bit about some problems with leaking shocks and problems with slop? can i order some parts that solve these problems? and is there other things I need to take care of right of the bat?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 10-23-2014, 08:57 AM   #5418
snwchris's Avatar
Also you might want to download manual, to check tools needed, I had to buy a couple Hex tips that I didn't have... 1.3 and 0.05 tips
The only thing I would say, is order an extra spur, always good to have one anyways. I ordered the B5 shock caps and composite standoffs when bought my 413 and they are still sitting in the bag in my case, no use of them yet, but nice insurance to have on hand. I ordered the HB servo arm, since had the proper height for the linkage to work. I didn't feel like messing with the servo saver assembly.
It does come with wheels, but you'll need tires and foams, a lot of the guys here run AKA Red foams and break them in by hand (scrunch up for few mins) to help the break in period.
Just this past week I ordered Front Arms, Caster Blocks and Steering blocks, it's nice insurance to have that wont end your race day, LOL
Mantis, thanks on the info for TLR piston, we should get the front page updated so people know about the pistons that DO NOT work, due to shock shaft size.
snwchris is offline   Reply With Quote
Old 10-23-2014, 09:06 AM   #5419
kdeleon's Avatar
The TLR pistons can be made to work. Yes, the shaft on the HB is smaller than TLR shocks, but if you assemble the piston in the shock body, it will work. I even wrote up some instructions a while ago on this thread. And others confirmed that they got it working. In the end, I would prefer perfect ones, so I will also order when they come available. But if you really want to use premade ones right now, you can use the TLR ones.
kdeleon is offline   Reply With Quote
Old 10-23-2014, 09:33 AM   #5420
snwchris's Avatar
I did get a chassis protector too, right away. Stickit1 racing had them available and got them in 3days.
Old 10-23-2014, 10:10 AM   #5421
dMITIj's Avatar
Originally Posted by Wildcat1971 View Post
I would have spare spur gears for any 4wd buggy. Otherwise...the car is pretty tuff. I would normally say front arms, but mine are taking a pounding. You are more likely ti break the front inner hinge pin than an arm. I would get some xrings for the shocks. Just because they are a lot more smooth.
You got an part nr. for the xrings for the shocks?
TLR 22-4.
Old 10-23-2014, 10:15 AM   #5422
dMITIj's Avatar
what about oil, is that in the kit ore?
i got an hex 1.3 lying around, but thanks
TLR 22-4.
Old 10-23-2014, 10:22 AM   #5423
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
they are the traxxas blue ones.
I use these. A few other members have also used them with out issues.
http://www.amain.com/Traxxas-Shock-Rebuild-Kit/p45156
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-23-2014, 10:30 AM   #5424
dMITIj's Avatar
TLR 22-4.
Old 10-23-2014, 10:41 AM   #5425
snwchris's Avatar
The kit comes with 10K Diff and 100K Diff and 500 shock oil. With any kit I buy I usually use my own, either Losi or AE fluids. I know lately some are switching to the PT racing for oils.
Old 10-23-2014, 10:44 AM   #5426
I have some PT. It is ok, I will stick with AE oil.
Old 10-23-2014, 10:52 AM   #5427
dMITIj's Avatar
So what do i need to make that B5 shock cap worke with the D413?
TLR 22-4.
Old 10-23-2014, 10:56 AM   #5428
You need the AE shock mounts. I used the AVID B5 shock mounts. And you will need 3mm screw that is like 23mm long. And of course the AE caps. But...The AE caps are not a 100% solution. The "fit" but one of my HB shocks will not thread the cap on all the way. And it was not hte AE cap. I think the anodizing on this shock is slightly thicker than the other 3 shocks. The kit caps work ok, but they get work after a while and will start popping off on crashes. I had one pop off flat landing a large jump. Seems like the rears are mostly the problem.
Old 10-23-2014, 11:38 AM   #5429
dMITIj's Avatar
okay thanks. think ill stick with the kit cap's and hope some will make som "normal" caps for the D413
TLR 22-4.
Old 10-23-2014, 11:39 AM   #5430
Treat the caps like ball cups. Once they start popping off, it might be time to replace.
