Like Tree42Likes
Old 10-22-2014, 11:57 PM   #5401
Shark413's Avatar
Trader Rating: 24 (100%+)
Originally Posted by sugelle View Post
+1....mine is on the way
I pulled the trigger and ordered one as well. I was able to use the Super Saver discount of $60, free shipping and no tax, I couldn't resist.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 10-23-2014, 04:21 AM   #5402
Hi guys. A team X-ray driver from my track (indoor carpet), is using 850 front and 650 rear- shock oil together with 1.7mm 3 hole pistons. He's is going REALLY fast. If i wanna try something "heavy" on my D413, -does 770 front and 600 rear with the stock 1.4mm 4 hole pistons sound totally crazy ?
ColourGhost is offline   Reply With Quote
Old 10-23-2014, 05:08 AM   #5403
offroad dude's Avatar
Trader Rating: 25 (100%+)
That makes 2 of us then!
offroad dude is offline   Reply With Quote
Old 10-23-2014, 05:14 AM   #5404
Hi Guys, what kind of front and rear droop are you running. Just built mine and it has a lot of droop. At present I'm on the middle marking on shock shaft. Should I add limiters aswell under the piston's ??
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 10-23-2014, 06:22 AM   #5405
snwchris's Avatar
The front has lots of droop compared to the rear. It depends on how you set it up either per the box stock settings or if your using someones setup from Petitrc.com. I'm using TYs Reedy setup and in his he measured with calipers the length or position of eyelet. I've seen other setups that say use first line or second line.
snwchris is offline   Reply With Quote
Old 10-23-2014, 06:27 AM   #5406
snwchris's Avatar
For those that are recently picking them up, make sure to take look at first page, lots of great info and tips for the car.
This is my first 4w Buggy and the kit was fun to build and is a blast to drive. I've had mine now for about 4wks and the 413 is a beast.
Old 10-23-2014, 06:39 AM   #5407
MantisWorx's Avatar
Trader Rating: 28 (97%+)
I think 4 hole will be sluggish but you never know! try it and see I know that i run 4x1.6 on my eighth scale with around 500 for a reference point.
and on my 413 i have 3x1.4 with 550/450
MantisWorx is offline   Reply With Quote
Old 10-23-2014, 06:50 AM   #5408
Ok maybe iŽll try the tlr22 pistons, or maybe try to drill my own. Would like to try 3x1.7mm, on a thick oil. I was told by a pro racer that my 413 was way to soft with 550/500 - 4x1.3 and Kyosho orange springs.
Old 10-23-2014, 06:59 AM   #5409
slakr's Avatar
Trader Rating: 28 (100%+)
I'm waiting for Marcus to say his 2x1.6 & 2x1.7 pistons for the D413 are available
I can have them available in a day or so!
OK thanx, will work on them today!
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 10-23-2014, 07:30 AM   #5410
snwchris's Avatar
I think a couple pages back someone had tried various pistons and had issues with some, you'll have to watch the piston I.D. for the shaft, some of them are a tad bigger.
When I first setup my car I ran with the 4x1.3 pistons, stock springs and 37.5 and 35 oils and actually felt really good and even couple other guys tried and liked. Now each driver has their own style or skills, so I would say tune the car to the way you drive or how you drive. As you try different things report back or keep others posted.
I will say this though.... a lot of people are using the 2x1.6 with great success, so it must be working. When I changed mine over I was hesitant, but the very next week was able to push the car a little harder and faster and felt more planted.
Old 10-23-2014, 07:33 AM   #5411
snwchris's Avatar
Originally Posted by DCNash55 View Post
avid ae and kyosho do not work... center hole is to large!! tried that during the initial build.
Not sure if the TLR pistons would have same issue
Old 10-23-2014, 07:35 AM   #5412
trick25's Avatar
Trader Rating: 27 (100%+)
using 3x1.3 here.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 10-23-2014, 07:45 AM   #5413
Graham11's Avatar
Trader Rating: 21 (100%+)
lots of discussion about pistons on this thread. I just built my kit using the kit setup to start but should I have not? I will be running on fairly high traction clay and carpet mostly, I thought the kit setup was for high traction but please correct me if I am wrong because I will change it. Usually the kit setup is a good starting point but it seems like this stock setup is pretty specific.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 10-23-2014, 08:03 AM   #5414
snwchris's Avatar
I used TYs Reedy setup as starting point for first race and made adjustments for the following week. For the first race I ran the stock springs, 4x1.3 pistons and 37.5 & 35 losi oils and 7-100-3 based on our track surface. I did follow TYs setup for the Front kickup and Rear anitsquat. I was told by a couple local racers to follow that and it made the car very easy to drive and learn since this was my first 4w ever.
Out of 8 fast local racers that day I finished 4th and just missed 3rd for my first time running 4w buggy. Once I had my baseline race under my belt to judge numbers off, the following week I changed out the pistons to 2x1.6 and 37.5 and 32.5 oils and was able to get faster with car and push it more. I still run a Tekno Ebuggy and this car reminds me of driving Ebuggy, LOL
Tires also play a BIG part too, if you don't have the right tires you can chase setups all day. For our track and others in the area Proline Ions are the ticket as well as Dirt Webs and Elektrons.
And remember not all setups always work for the track or how you drive, but it's nice to have that baseline starting point to go from. The car reacts to minor changes as well, so make a couple small changes to see if that helped or didn't help.
Old 10-23-2014, 09:20 AM   #5415
MantisWorx's Avatar
LOL you are on it!! i have the CAD work done already, i spent most of the day yesterday working on the ballbearing ackerman bar so i can test tomorrow, with any luck i should have time this evening to machine a few sets of flat pistons. I drew up 2x1.6, 2x1.7 and 3x1.3
Announcement will be made on facebook, so check periodically.
You are always going to search for different "feels" with your car. Pistons are a very important aspect of how your buggy will perform, there is no perfect piston oil setup, weather changes, different brands of oil, track conditions etc etc. Some people just go with one and stick with it while others like me change all the time.Kit setups like any other posted setup will just get you close. Drive your car like it is until you get consistent with it and then make one change at a time to make it better for you.
Very well put
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
