Like Tree35Likes
Old 10-09-2013, 07:49 AM   #526
Trader Rating: 21 (100%+)
I'd be ok with 13-16 a set cuz they won't break nearly as often cuz the are hb lol
jason248 is offline   Reply With Quote
Old 10-09-2013, 09:00 AM   #527
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Arms aren't bad. Consumables, like dogbones, outdrives and that fancy (probably expensive) input shaft with the drive cup machined into it are the only worries I have. I wonder what a rebuild would cost.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-09-2013, 12:31 PM   #528
dogbones and outdrives on this car are pretty standard so rebuilding them will be comparable to other cars. the 1-piece gear/input shaft/drive cup has shown no signs of wear from all the running we've put into it. although that one piece will probably cost more than the typical input gear, we've eliminated a bunch of other parts in the drive line - there are no pins, cv cups, couplers, set screws, rings, etc. cost as a whole should be similar to others but reliability is much higher because there are very few parts.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 10-09-2013, 12:58 PM   #529
mattchis's Avatar
Default Wheels
Are the wheels the same as the old D4?
Team Draught
Supported by APA Group.
mattchis is offline   Reply With Quote
Old 10-09-2013, 01:20 PM   #530
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Straight from Torrance:
For the rear it has 12mm hexes. It is compatible with all the usual 12mm hex rear wheels (AE, Kyosho, TLR, PL, JC, AKA, etc.)
For the front the kit includes BOTH 12mm and 9.8mm hexes. The included HB wheels uses the 12mm hex. The included 9.8mm hexes are compatible with the TLR-22 2WD buggy front wheels.
That's not a typo - the offset compatibility is with the 2WD TLR-22 front which PL, JC, and AKA have versions of. The usual 4WD fronts from the major wheel companies can be made to fit but the hex fit will be a little tight and the front total track width will end up a little narrow. for some reason the hex on the TLR-22 is 9.8mm and the rest of 4WD wheels are 9.5mm. Why there's a 0.3mm difference between the 2WD and 4WD i don't know. The wheel offsets are different as well but during the design phase I studied all the available wheels and I preferred the TLR-22 offset.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-09-2013, 01:37 PM   #531
gticlay's Avatar
In the pictures, there appears to be significant toe-in - is there 3-4* on that setup?
gticlay is offline   Reply With Quote
Old 10-09-2013, 03:13 PM   #532
we made new wheel molds but yes, the old D4 wheels are compatible.
Torrance Deguzman
powered by LRP
Old 10-09-2013, 03:14 PM   #533
good eye. Ty was running 3.5 degrees.
Torrance Deguzman
powered by LRP
Old 10-09-2013, 04:56 PM   #534
In Australia we run 17.5 blinky. Just wondering if there will be option spur gears or if something could be modified to fit?
d4shane is offline   Reply With Quote
Old 10-10-2013, 05:51 AM   #535
lbenton's Avatar
Trader Rating: 48 (100%+)
One more selling point to me, my humble pile of TLR 22 buggy wheels / tires can be dual purpose now.. this will help the track budget a bit.
lbenton is offline   Reply With Quote
Old 10-10-2013, 11:36 PM   #536
we can make other spur gears in the future if there is a demand for a particular size. because the spur gear is part of the center diff I don't think you'd be able to easily modify something to fit.
what final drive do you run for 17.5 blinky?
Torrance Deguzman
powered by LRP
Old 10-10-2013, 11:46 PM   #537
froggie22's Avatar
At WCMRC guys are running from ~5.8 up to 6.3ish.. I sit around 6.2.
froggie22 is offline   Reply With Quote
Old 10-11-2013, 04:53 AM   #538
Trader Rating: 34 (100%+)
Considering this car is fairly close to being available could we get some setup sheet info soon?
GettinLapped is offline   Reply With Quote
Old 10-11-2013, 12:55 PM   #539
currently the largest pinion that the car will accept is a 38T which will yield a final drive of 6.27. hopefully this can get you in the ballpark in the beginning. if a 4WD stock class does emerge then we'll make a smaller spur. for now however there hasn't been many tracks that run a 17.5 blinky 4WD.
(for reference the D413 comes with a 72T spur and the gearbox ratio is 43/13)
Torrance Deguzman
powered by LRP
Old 10-11-2013, 12:59 PM   #540
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Hi Torrance - Is there a MSRP for this bad boy yet?
www.smc-racing.net for all of your Lipo needs
RC10B5, Caster S10B Pro, 22T
Grasschopper is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
kidcotton
