Like Tree35Likes
Old 10-22-2014, 08:00 AM   #5356
slakr's Avatar
Trader Rating: 28 (100%+)
Originally Posted by MantisWorx View Post
2 hole with what size holes?
2x1.6 & 2x1.7 seem to be most common from what I have seen.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 10-22-2014, 09:19 AM   #5357
MantisWorx's Avatar
Trader Rating: 28 (97%+)
OK thanx, will work on them today!
MantisWorx is offline   Reply With Quote
Old 10-22-2014, 09:24 AM   #5358
snwchris's Avatar
I'm running 2x1.6 with 37.5 Losi front and 32.5 Losi Rear oils and no front swaybar.
A lot of people that are using TYs Reedy setup have 2x1.6 and 2x1.7
snwchris is offline   Reply With Quote
Old 10-22-2014, 09:31 AM   #5359
Put the the bladder on while the shaft is up and when you lay the bladder on "roll" it to one side so that the extra oil comes out. If you just lay the bladder on top and give the oil no where to go you will have rebound. Try that and see how it goes!
After you have that part figured out, install the cap with the bleed screw completely out, tighten the cap all the way down, leave the shaft up and to be honest i would just leave the bleed screw out, but if you want to use the bleed screw, screw it in while the shaft is up. you should get as close to zero rebound as you can with this technique.
I tried it emulsion style, and BADABAAAANG!! Zero rebound. That's just way itīs gonna be then. Thanks again MantisWorx and all you guys for trying to help me out here
ColourGhost is offline   Reply With Quote
Old 10-22-2014, 10:17 AM   #5360
big greg's Avatar
Trader Rating: 119 (99%+)
We're actually using losi 30ft 25 rear and it has more corner speed, still lands without a sound
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 10-22-2014, 10:31 AM   #5361
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
crap that seems light. I was talking to a sponsor HB driver that runs the 1.6/1.7 combo. He said he is running 45/42.5. He said his car was trash with lighter oils around 30wt.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-22-2014, 10:49 AM   #5362
ok, I know this question comes up a lot. And yeah it is kinda noobish and very subjective.
We run 8 minute mains in 4wd and 6 minute quals. I am currently using 5mm bullets on all of my batteries. The d413 seems to be really punishing my packs. They come off the track in the main at 30%. They also get a little warm, not much, but you can feel it in your hands. My main issues are increased IR in one cell and puffing. I am using the 90c 4800 mah packs with a 6.5. Does anyone make a pack cell that holds up better and does not puff? In my experience al of these higher mah packs in the same sized cases are puffing. I am told this had to do with the tight confines of the cells in the shorty pack. The orion 100c 4500 seems like it might be a well made pack, but they are 4mm. I know the turnigy ultimates are 5mm, but I have had issues with cell failing entirely in those. Maybe I just expect my packs to last too long. thoughts?
Old 10-22-2014, 10:58 AM   #5363
Graham11's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Wildcat1971 View Post
I have to ask, did you mix up the hex pin and the cva pin?
I didn't mix anything up, I opened each bag step by step and it had two pins but they are different, one was correct and one was the thinner type for the wheel hex. I had one in my parts bin from another kit but it was definitely the wrong one.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 10-22-2014, 10:59 AM   #5364
ah, ok. Who does HB's US support? Just curious.
Old 10-22-2014, 11:04 AM   #5365
snwchris's Avatar
Hmmm interesting with the lighter oils. What type or style of track or any pics to get an idea. Most the 413 guys here at our track are still messing with oils, but always seem to come back to 37.5 and 32.5 to 35 for rear. I know on a couple of our jumps if I over shoot, you get a little smack.
As for the battery thing Wildcat said, so far I haven't noticed with mine, but curious now. We run 5min Quals and 7min Mains, so you figure about 3mins for warm-up laps and 7mins, your running for atleast 10mins now. I might have to check mine this weekend at trophy race, since running on a bigger indoor track, pretty much a 1/8 indoor track.
Old 10-22-2014, 11:17 AM   #5366
I tried some small capcity shorties. TP, reedy and a few others. But, if i tried to do practice laps, I would dump in the main. The TP 3800 would dump in a 5 minute race if I did practice laps. The magic number seems to be 4500+ mah. I just want a higher quality cell, that will hold up to a 6.5 in a wheeler better. I try to get my packs to last a year
Old 10-22-2014, 11:32 AM   #5367
Trader Rating: 36 (100%+)
Off topic, but these are some of the reasons that I run a HV setup (batteries are cheaper, last longer, runs cooler, etc...). The bigger races that I have entered (there aren't that many, and aren't National level) didn't care at all about it because it's a mod class anyway.
ufoDziner is offline   Reply With Quote
Old 10-22-2014, 11:34 AM   #5368
ah, are you the one using 380 sized motors on 3s in 2wd?
Old 10-22-2014, 11:36 AM   #5369
roc 412 1200 or pro4 1400 on 6s in 4wd buggy. At one point I was using smaller can on 3 or 4 cell in 2wd, but it's been a while.
Old 10-22-2014, 11:42 AM   #5370
interesting. you running that in a shorty config? the pro4 1400 is a 5mm shaft, no?
