Like Tree35Likes
Old 10-22-2014, 05:24 AM   #5341
snwchris's Avatar
Originally Posted by ColourGhost View Post
If anyone is capable of putting on the bladder without the shock shaft starting to move out and thereby creating at least 50% rebound when done, you either have a good portion of luck in you, or you simply are an alien. If you cant even seal it with the bladder without the shaft starting to move, letīs just wait talking about what to do with the shock cap , - right ?
Damn, iīm beginning to lose faith
WOW, I'm not sure why your having such an issue. I've rebuilt mine a couple mines with no issues. Did you drill small hole or ream small weep hole in side of cap, basically thru the sidewall.
Hot Bodies D413 1/10 4WD Buggy-img_0905.jpg
snwchris is offline   Reply With Quote
Old 10-22-2014, 05:38 AM   #5342
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Put the the bladder on while the shaft is up and when you lay the bladder on "roll" it to one side so that the extra oil comes out. If you just lay the bladder on top and give the oil no where to go you will have rebound. Try that and see how it goes!
After you have that part figured out, install the cap with the bleed screw completely out, tighten the cap all the way down, leave the shaft up and to be honest i would just leave the bleed screw out, but if you want to use the bleed screw, screw it in while the shaft is up. you should get as close to zero rebound as you can with this technique.
MantisWorx is offline   Reply With Quote
Old 10-22-2014, 06:39 AM   #5343
big greg's Avatar
Trader Rating: 119 (99%+)
Originally Posted by nv529 View Post
There's 7 of us on the eastside.
Are u including me? Lol since technically I'm in ohio
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 10-22-2014, 06:41 AM   #5344
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Greg, Myself, and 2 other locals(Doug and Terry) did some testing over the weekend at the RC Clubhouse Halloween race. We've found out there can be a 7.5wt difference in shock oil depending on the type or brand seals when using the same pistons.
We've tested the following.
AE X-rings: leaked really bad out of package, ended up not using this seals.
Kyo X-rings: smoother than stock with less stiction but required 7.5wt heavier oils
Traxxas X-Rings: same a Kyo X-rings required 7.5wt heavier oils
Stock O-rings: Although they have much more stiction, I've found this seals to be the most consistent and since I've already had the shock package dialed-in with this seals I ended up using them over the weekend.
Hot Bodies D413 1/10 4WD Buggy-nv529-10-22-2014.jpg
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 10-22-2014, 06:52 AM   #5345
MantisWorx's Avatar
are the traxxas rings blue?
What piston combos is everyone using with this car right now?
Old 10-22-2014, 06:53 AM   #5346
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the xrings? yes
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-22-2014, 06:58 AM   #5347
I see a lot of people running copper front and black rear sway bars. This would yield more steering than silver/silver correct? I am curious, because I dont really want any more steering in my car
Old 10-22-2014, 07:23 AM   #5348
big greg's Avatar
And again , we've found more people that had zero packing they're 2 hole drilled, so our local machinist nick Vasquez , hooked em all up. I think I may be the only other that drilled mine, per nicks instructions tho, but our cars were dialed last weekend, with nick being on a blistering tq run, but lap traffic wasn't having it, 1st through 5th were like 5 seconds apart. We turned a lot of heads with this. Car
Rip bill bridges
Old 10-22-2014, 07:25 AM   #5349
hopefully, so new pistons hit the market soon.
Old 10-22-2014, 07:28 AM   #5350
MantisWorx's Avatar
What holes/size are you using right now?
Old 10-22-2014, 07:35 AM   #5351
1.3x4 f/r. I am debating 1.2x4 in the front, as my weight is transferring too fast imo.
Old 10-22-2014, 07:40 AM   #5352
big greg's Avatar
After getting the 2 hole dialed in I see no reason to switch now. The shock package is the best part of this car now I feel
Rip bill bridges
Old 10-22-2014, 07:42 AM   #5353
I plan to try 2 hole once someone makes machines ones, lol
Old 10-22-2014, 07:49 AM   #5354
MantisWorx's Avatar
2 stage will help with that since the rear will rise faster than the front will fall.
I think 2 hole in 12mm is the best combo too.
2 hole with what size holes?
I can have them available in a day or so!
Old 10-22-2014, 07:58 AM   #5355
big greg's Avatar
Per nick (nv529)
I'd recommend using this method
#55 or #56 pilot hole
Front: Drill with #53, check hole with 1/16" drill. If it doesn't fit drill with 1/16" bit
Rear: Drill with #52, check hole with #51 drill. If it doesn't fit drill with #51 bit.
Take your time the holes should fit snug against the drill bit when the size is correct.
Just a FYI: I've checked my drills with a .0001" micrometer 1/16" measured .0623"/1.582mm, #51 measured .0667"/1.694mm
Rip bill bridges
