Hot Bodies D413 1/10 4WD Buggy
#5326
With either the stock or AE caps:
Vented = bladder and bleeder screw left out
Emulsion = cut bladder and bleeder screw in
#5331
I know its been asked but what is everybody doing about the sway bar coming out of its link where the set screw goes in? Its been happening more & more
#5334
#5335
#5336
These f....... shocks!!
If anyone is capable of putting on the bladder without the shock shaft starting to move out and thereby creating at least 50% rebound when done, you either have a good portion of luck in you, or you simply are an alien. If you cant even seal it with the bladder without the shaft starting to move, letīs just wait talking about what to do with the shock cap , - right ?
Damn, iīm beginning to lose faith
#5337
Proline Trifecta
I just got the Proline Trifecta wing and it seems really durable. But since it's so thick I cannot not mount it with the regular wing mounts. Do anybody have a tip on how to mount a thicker wing. Do you dremel the wing mounts och drill a new hole for the clip, or do you do anything else?
/Patrik
/Patrik
#5338
I wasn't planning on it. But if everyone wants to meet up, I'm in!
Try a little bit of shoe-goo between the ball cup and swaybar.
It should mount the without wing washers.
/Patrik
/Patrik
