Like Tree31Likes
Old 10-14-2014, 05:56 PM   #5161
trick25's Avatar
Trader Rating: 25 (100%+)
looking forward to what you find out marcus. finally someone that runs on loose track to compare notes with.
yeah i was going to move mine back too. but waiting on the avid. umm. i thought that was supposed to be a "month" out.
4wd bug-D413, Blinky bug-XB2 17 CE 4wd SC-SCT410
trick25 is online now   Reply With Quote
Old 10-14-2014, 06:12 PM   #5162
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by CTEKTOOL View Post
What kind of scales are those?
SkyRC, i think discountRC sells them
seems like most run on high grip which is what the car is designed for, My first impression after driving it was that the chassis is too stiff and the car wasnt planted in the turns, My TeamC was the same way. The delrin upper decks should fix that. We run on friday so i should have some good feedback over the weekend. proto pistons are also on the car with a different configuration special for the wheelers
MantisWorx is offline   Reply With Quote
Old 10-14-2014, 06:23 PM   #5163
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I tried to contact Avid today, but they are at the onroad race in Las Vegas. The chassis should be very close. I will let you know when I have a better date.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-15-2014, 01:49 AM   #5164
Originally Posted by Soapy View Post
Hi Guys, what is the preffered method with the shocks. Do I cut the bladder to make them emulsion shocks or drill out the bleed hole to make them bladder shocks.
Bumpety Bump,
Can anyone advise please?
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 10-15-2014, 04:30 AM   #5165
trick25's Avatar
most ppl make emulsion shocks
Old 10-15-2014, 05:14 AM   #5166
Originally Posted by MantisWorx View Post
Finally got my hands on a 413 for testing! very well engineered car, we run on looser tracks so first thing i made was a more flexible upper deck!
Also found that the car scaled better with the ESC behind the motor, this pic was with all collars even and no additional weight added. crossweight is perfect as is rear numbers but front left is heavy even with the esc in the rear.
Testing friday!!
Wouldn't the corner to corner weight be dependant on the placement of the battery? because it's further back in your setup, it makes sense to put the esc back there. Most setups seem to have the battery fully forward. I need to check my corner weights again, but I have my battery up front and ESC in the front also. Corner weights were good IIRC but I'll have to check.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is online now   Reply With Quote
Old 10-15-2014, 06:02 AM   #5167
snwchris's Avatar
Bumpety Bump,
I built my shocks Bladder style with bleed hole and so far have been real nice.
snwchris is offline   Reply With Quote
Old 10-15-2014, 06:06 AM   #5168
MantisWorx's Avatar
Shifting the battery forward is not going to move 30g of weight and as it sits now the rear balance is perfect, moving the battery at all will take that away. Seems logical that if you have even weights, you would want them symmetrical on the chassis. The esc and motor weighs almost the same as the battery and the servo is only minimally heavier than most receiver. Moving the esc up front will force you to add static weight to the rear left or jack the rear left collar down until its out of range ( i dont like to go more than 1 revolution personally.) You can no doubt make it work either way and that has been proven!
The battery really does need to be moved forward, this is how the car was given to me so i havent really messed with it much other than making the upper deck and installing the pistons. I plan on spending most of the day friday testing and trying some different things,moving the battery forward will be one of them!
Old 10-15-2014, 07:29 AM   #5169
MantisWorx's Avatar
+1 best and most consistent way of building shocks!
Old 10-15-2014, 07:34 AM   #5170
Are you referring to running bladders without the bleeder screw installed? My only issue with that would be contaminates. The hole faces forward and will pack with dirt on crashes.
Old 10-15-2014, 07:41 AM   #5171
MantisWorx's Avatar
even if something got in there the bladder separates from the shock oil so it would make a difference especially on a lovely clean indoor track!!
Old 10-15-2014, 07:45 AM   #5172
Yeah, for me there is no dust, so that is not a concern. More like packing the hole closed and changing how the shock works. With the AE caps, I would just face the bleeder inwards and not have an issue. The HB bleeder faces forwards, so that would be my only concern.
Old 10-15-2014, 07:53 AM   #5173
MantisWorx's Avatar
I could see that happening for sure with the stock caps on a muddy or wet track but with as much pressure that builds up inside on a hard landing i would think it would just blow out especially since the holes is so small.
Old 10-15-2014, 09:23 AM   #5174
Stevomatik's Avatar
New body y'all
http://www.redrc.net/2014/10/jconcep...ll/#more-87604
Stevomatik is offline   Reply With Quote
Old 10-15-2014, 09:32 AM   #5175
hmm, I think I like the proline better.
