Like Tree28Likes
Old 10-13-2014, 07:22 PM   #5131
Thanks, nv. I'll add them to the list.
AMorgan is offline   Reply With Quote
Old 10-13-2014, 07:24 PM   #5132
snwchris's Avatar
This is my first time running anything 1/10 buggy related and I'm using TYs Reedy setup. I'm running 7k-100k-3k for diffs, then 2x1.6 pistons with AE Blue Fronts, 37.5 Losi oil and AE White Rears, 32.5 Losi oil. I find it very easy to drive and can drive it hard like an Escale. I have no problems with our 180s, feels planted and back has never felt loose or broke loose.
snwchris is offline   Reply With Quote
Old 10-13-2014, 07:36 PM   #5133
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
what type of traction? I am pretty much driving on velcro
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-13-2014, 08:28 PM   #5134
cokemaster's Avatar
Trader Rating: 18 (100%+)
Originally Posted by kerby View Post
Anybody know an alterative to a Xgear yellow front?
Xgear yellow front is very close to HB red front. And Xgear white rear is very close to HB gold rear. Spring rates in lb/in:
HB Red front is 3.63. Xgear yellow front is 3.60
HB gold rear is 2.12. Xgear white rear is 2.10.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 10-14-2014, 04:01 AM   #5135
Tranzistor's Avatar
HB D413 - TQ and WIN the Ukrainian Off-Road Championship 2014 (11-12 October 2014 in Kiev)
Motorhouse Racing
Durango Club Ukraine
Extreme Race Off-Road Track (Kiev)
Tranzistor is offline   Reply With Quote
Old 10-14-2014, 04:29 AM   #5136
Have managed to overheat my 6.5T down here in oz running in 26C (79F) temperatures. What are people doing to get extra cooling for their motors? I am considering getting a heatsink with a fan mounted on it but there doesn't look like there is a huge amount of room.
moch8 is offline   Reply With Quote
Old 10-14-2014, 04:38 AM   #5137
what pinion were you using?
this is a possible solution: http://www.warny.pt/store/hot-bodies-d413-fan-rx-plate
nicmo is offline   Reply With Quote
Old 10-14-2014, 04:49 AM   #5138
Hi Guys, what is the preffered method with the shocks. Do I cut the bladder to make them emulsion shocks or drill out the bleed hole to make them bladder shocks.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 10-14-2014, 05:05 AM   #5139
That's not a bad idea.
I was initially running a 23T and dropped down to a 22T but it is still running hot.
Planning to try have a 30mm fan running at the back to suck the hot air out.
Old 10-14-2014, 05:46 AM   #5140
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Originally Posted by big greg View Post
Nick Vasquez and I have been doing some heavy testing. (More him) but we realized it's very easy to drill the 2 hole pistons to big. It took me 3 tries to get it right, a pilot hole with a number 55 is a must. And be very careful when drilling final hole, it's amazing the difference in the car when the holes are just slightly big. I was able to drop 5 wt in each end and it lands way better and is way more stable
I cannot stress this enough! The plastic is really soft I went through 2 piston sets until I got it right. The first time I drilled the rear pistons with a #51 the hole over sized enough to fit a #50 bit (.070"/1.78mm)
I'd recommend using this method
#55 or #56 pilot hole
Front: Drill with #53, check hole with 1/16" drill. If it doesn't fit drill with 1/16" bit
Rear: Drill with #52, check hole with #51 drill. If it doesn't fit drill with #51 bit.
Take your time the holes should fit snug against the drill bit when the size is correct.
Just a FYI: I've checked my drills with a .0001" micrometer 1/16" measured .0623"/1.582mm, #51 measured .0667"/1.694mm
Originally Posted by Wildcat1971 View Post
I am not so sure about your shock package. I talked to a couple local sponsored HB drivers and they say Ty's shock package is way too soft. they are running the 2 hole with like 47/42 oils.
After resolving my drill bit issue, I started off with 40/35w x 2 holes. The car was really stable until landing big jumps or flat landing it had a nasty uncontrollable bounce. I thought it didn't have enough pack so I went up oils until reaching 50/40w, by then the car drove the worst ever due to the shocks hydrolocking/over packing which was causing the bounce. So I went to 30/25w it was "springy", but 100x better. With my drill pistons 32.5-35wfront and 27.5-30w rear seems to be the sweet spot.
Here's a crappy webcam video with 35/27.5wt. When dropped from 10-12" the buggy uses about 70-80% of travel, full compression is slightly below ride height then rebounds to ride height, the car never bottoms out.
http://www.youtube.com/watch?v=vn_vpSCGGmI
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 10-14-2014, 06:45 AM   #5141
snwchris's Avatar
@Wildcat, its pretty much a Clay/Dirt mixture and using M4 Ions for tires and gets watered each round. On new track builds it's really high bite, were you could almost use slicks.
Old 10-14-2014, 06:54 AM   #5142
cool. We run clay slicks, so probably a bit more traction. I didnt like Ty's reedy setup at all, the rear of the was all over the place off power. if you drive strapped it might be fine I guess.
Old 10-14-2014, 07:57 AM   #5143
MasiisaM's Avatar
What weight is in the rear diff?
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 10-14-2014, 08:46 AM   #5144
7k
Old 10-14-2014, 08:58 AM   #5145
MasiisaM's Avatar
7k
Well damn...it's not that..sounded like you were at 2K..
Thanks to:
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
