Like Tree29Likes
Old 10-09-2014, 06:04 AM   #5071
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Originally Posted by WagwanBumba View Post
Have you tried running it having taken the slop out?
I have, the car drives the same.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 10-09-2014, 06:18 AM   #5072
snwchris's Avatar
My car has the slop and I've also tried small washer to help eliminate some of the slop and can't notice when racing on track. I ran last week as my baseline test for track times and laps and this past Tuesday at practice, tried the washers and didn't notice a difference.
snwchris is offline   Reply With Quote
Old 10-09-2014, 07:09 AM   #5073
I guess because the cars going forward (most of the time), the steering hubs will be pushed back against the all the links. If anything, the affect of slop would be most apparent in braking
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 10-09-2014, 10:39 AM   #5074
mes
These kits have been around now for a while. Would you guys recommend it to someone who is used to Kyosho/Yokomo/VBC Racing quality and intends to run it on loose dirt? I am looking for a wheeler as a stand in until the VBC 4WD will be released. As I don't want the B44.3 due to its SAE hardware and Kyosho seems not to be a viable option in Germany at this time, it is probably either the D413 or the lightweight B-Max4III.
mes is offline   Reply With Quote
Old 10-09-2014, 11:35 AM   #5075
JDJamminX1's Avatar
Default Front axle crush washer fix
After running the car for some time now. I decided it was time to do a rebuild/ cleaning up of the D413. One thing that stood out more then anything was the front axle having a bind to it. At first I thought the hex on the rim vs. the front hex was off in tolerance. I would grind down the hex on the rim and still had the same problem.
I decided to change out the bearings in the front to see if that helped. After opening up my front axle I noticed that the plastic spacer between the 2 bearing had gotten smashed a little. I decided that this needed to be replaced with a alum version.
After looking all over the hobby shop board for a replacement, I came across a kyosho spacer. This fixed the problem with amazing results. No bind what so ever.
See picture attached for part and product header card. Comes with 4 spacers 2 that are smaller then the other. Use the smaller ones.
Hot Bodies D413 1/10 4WD Buggy-img_3306.jpg
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 10-09-2014, 01:12 PM   #5076
cokemaster's Avatar
Trader Rating: 18 (100%+)
I had the same problem as you. Another option is to use the rear hexes in front. http://www.amain.com/Hot-Bodies-12mm...-Hub-2/p298396
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 10-09-2014, 01:26 PM   #5077
trick25's Avatar
Trader Rating: 25 (100%+)
you also may want to look at the pr racing SB401
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 10-09-2014, 01:54 PM   #5078
mes
Thank you for your suggestion, but the two above cars are the only ones that I'd consider giving a try. Of course, the Yoke would be the logical choice due to their great customer service and parts support in this part of the world, but I'd like to try a center diff for a change. Before somebody suggests Xray or TeamC, I don't consider these to be an option neither.
Old 10-09-2014, 01:58 PM   #5079
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The fit and finish of the d413 is as high as kyosho or some others. It makes the b4 slop look minor. I got over it because it is a tank and drives very good
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-09-2014, 02:30 PM   #5080
trick25's Avatar
cool. wasnt sure if you know about the pr racing. Then out of the 2 i would go for d413 on loose dirt. i really like mine. and i race on dirt, but i have not had it long.
Old 10-09-2014, 04:41 PM   #5081
rider313's Avatar
Trader Rating: 94 (100%+)
Guys looking for a chassis protector the JC B44.2 one fits pretty dang close. Just a bit of trimming in the rear and around hinge pins.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 10-09-2014, 04:51 PM   #5082
Graham11's Avatar
Trader Rating: 21 (100%+)
Ordering a d413, what parts should I order off with the kit as back up and necessary upgrades?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 10-09-2014, 04:58 PM   #5083
trick25's Avatar
order some luck. cause your gonna need one to find a kit. lol
Just kiding. get the b5 composite shock caps and stand off and some 3x12 socket cap head screws for the two motor clamp screws and the 4 on the top brace. it actually uses 3x10 on the two clamp screws but i use 3x12 and use washers.
and order a spare spur
Old 10-09-2014, 05:16 PM   #5084
Graham11's Avatar
Already found one, online bnib and cheap too, called the store to verify and everything. After currency conversion I made out big!
Cool thanks for the suggestions. Are the wheels a HB specific offset or what wheels can I use? And no need for extra arms and stuff?
Old 10-09-2014, 05:25 PM   #5085
This is codswallop! I have and built a Kyosho ZX6 and Xray XB4 and the D413 is BY FAR the most sloppy and flexible and least well parts fitting kit.
@Mes - after building the VBC Firebolt and Wildfire, I think you'd be disappointed with the way the D413 goes together. If you're looking to find enjoyment in your build in comparison to the VBCs, the D413 is not the one to get ... but this is purely from a build perspective.
As per performance, I've not had a chance to run my D413 yet but Ty's Nats win speaks for itself
ST - Losi 22T 2.0
