Like Tree35Likes
Old 10-04-2014, 07:40 PM   #5011
Trader Rating: 17 (100%+)
Originally Posted by lovell View Post
I have serpent caps on my d413.
Here are the part numbers needed
500146-14.50
500137-4.69
500199-11.49
2-500176-23.99
500179-2.50
Do they thread on properly? Any pictures you can share?
AlderBoy is offline   Reply With Quote
Old 10-04-2014, 07:50 PM   #5012
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by HulkNT1 View Post
Should I change it or leave it like that until it gets really bad?
Originally Posted by AlderBoy View Post
Change the pinion to a new one as it will chew up the spur if you leave the old one in there.
And pull the pebble out of the spur...
jhautz is offline   Reply With Quote
Old 10-04-2014, 08:27 PM   #5013
The rears screwed right on. The fronts needed the threads cleaned to get the caps to screw on easily. Must of had excessive coating build up in the threads. I will try and get some pics tomorrow. You will need 4 cap head screws also. Not sure on the length because I just cut the excess off at the nut.
lovell is offline   Reply With Quote
Old 10-04-2014, 09:34 PM   #5014
Awesome, thank you!
Old 10-05-2014, 12:03 PM   #5015
trick25's Avatar
Trader Rating: 26 (100%+)
first full raceday with d413. between a fast paced raceday, racing multiple classes and talking i did not get the change to make any setup changes. took 2nd out of 4. 1st ran away though and lapped me.
i will be making changes to front springs and a little change in weight balance and try again next week. sure is nice to be thinking about setup changes instead of fixing the car a couple times a day like i did the durango.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 10-05-2014, 03:33 PM   #5016
trick25's Avatar
i couple small notes. i did have some oil seapage at the top of one shock with the b5 caps. so i put the durango shock O-rings in hopes that it provides a better seal.
On the front page it says you can use yokomo wheels. i tried them on front. they work...but you have to either dremel the wheels a bit so the hex is not so deep or shim the wheel a bit. or the wheel will bind on the carrier. i would just not use them if i had to do it again.
Old 10-05-2014, 04:18 PM   #5017
500146-14.50
500137-4.69
500199-11.49
2-500176-23.99
500179-2.50
hummm too expensive :P
nicmo is offline   Reply With Quote
Old 10-05-2014, 07:26 PM   #5018
scottydog471's Avatar
Default Interchangeable wheels for d413
What car brand makes a replacement wheel that will fit this buggy.
Is it only hot bodies?
Pegasus Raceway Rules!!!! So does the Beard, LQV2 and Snow Flake
scottydog471 is offline   Reply With Quote
Old 10-05-2014, 07:36 PM   #5019
Trader Rating: 132 (100%+)
22-4 front and rears are a direct fit and same track width
skyline1015 is offline   Reply With Quote
Old 10-05-2014, 07:37 PM   #5020
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
I'm using TLR 22-4 wheels
nv529 is offline   Reply With Quote
Old 10-05-2014, 08:53 PM   #5021
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
DE racing 22-4 wheels fit nice, are of good quality and are cheap. win, win, win.
RC*PHREAK is offline   Reply With Quote
Old 10-05-2014, 11:52 PM   #5022
Does anyone make a replacement spure for this thing. Striped mine during the first run.
Allen Drebi is offline   Reply With Quote
Old 10-06-2014, 03:27 AM   #5023
http://www.amain.com/Hot-Bodies-Spur-Gear-72T/p298473
I've found Losi steel pinion gears to mesh the best with stock spur.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
Old 10-06-2014, 05:33 AM   #5024
snwchris's Avatar
Well finally got to race my 413 this past weekend for our Indoor season opener. WOW, this buggy is fun to drive. This is my first venture into anything 1/10 buggy related and was pleased with how easily the car felt to drive and each qual I tried pushing a little harder and was able to knock off 3-4secs each round.
We had 8 buggys with some great competition for the opener, I ended up sitting 5th on the Amain grid. I was able to move up to 2nd a few laps in, but made a bobble, dropped down to 6th, but climbed back up to finish 4th. I'll take that for first day out with it.
I had a couple of the fast guys drive it after racing and they liked it and just recommended I change out the Front diff oil, currently running 10-100-3, so most of them recommended going to 7-100-3 and see how that goes.
During practice session in the morning I only had one break and was rear outer ball cup, I landed sideways and a Corr truck landed on me at same time.
snwchris is offline   Reply With Quote
Old 10-06-2014, 05:36 AM   #5025
trick25's Avatar
when you replace the spur. replace the two button head screws that clamp the motor mount in place with socket(cap) head screws and use tread lock. this will allow you to put a lot more torque on them giving you security.
Also make sure you thread lock the little counter sunk screws that hold the mount to the end of the motor. If these vibrate loose the motor will vibrate loose and strip the spur.
