Like Tree31Likes
Old 09-29-2014, 07:41 PM   #4951
trick25's Avatar
Trader Rating: 25 (100%+)
yeah if its smooth reds would be ok for you. i think yellow is the stiffest i can get away with cause its rarely ever smooth. lol
4wd bug-D413, Blinky bug-XB2 17 CE 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 09-29-2014, 07:43 PM   #4952
Originally Posted by Wildcat1971 View Post
no, I mean it was rubbing the inside of my shock body and would not even go up all of the way with the shock cap off.
Wow really that sucks. You should have contacted him he would have sent you a new pair free of charge. He has a very good warranty policy and is easy to reach either from his thread here on rctech or his website.
But bottom line that really does suck that you had that issue.
Beaker151 is offline   Reply With Quote
Old 09-29-2014, 07:43 PM   #4953
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
it is pretty bumpy here, but the bite is pretty high. honestly, I just need 1 step higher than the HB Gold. I just need to support the front more going into high speed 180s with breaking.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-29-2014, 07:44 PM   #4954
It was only in 2 of them, but I didnt want to run 1/2 2 stage.
Old 09-29-2014, 07:47 PM   #4955
trick25's Avatar
one step higher would be blue if i remember right.
Old 09-29-2014, 07:49 PM   #4956
I use blue in my B5m sometimes. Might be to soft for a 4wd. I will probably pickup yellow and red and try both. AE springs are cheap
Old 09-29-2014, 07:52 PM   #4957
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
The only area my car is lacking pack is on big flat landings everywhere else the car feels good.
Has anyone gone back to running bladders? Maybe reducing the amount of air in the shocks will increase pack.
nv529 is offline   Reply With Quote
Old 09-29-2014, 07:54 PM   #4958
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by WagwanBumba View Post
They were 3Racing ones ... are you based in HK?
Also they're not the only ones using a .050 hex. I bought a .050 hex anyways ...
Thanks! Yes I'm based on HK. Sounds like a .050 hex wrench is the way to go then...
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 09-29-2014, 08:03 PM   #4959
we have a few smallish jumps with flat landings. so the car slaps unless I stay on the power as I land. I was running bladders, but I cant bleed those for crap. so I went with cut bladders
Old 09-29-2014, 08:08 PM   #4960
Where is your dot setting on the bellcrank? No matter what I change on the set up my car drove like crap with the dot facing forward per manual.
Old 09-29-2014, 08:25 PM   #4961
please clarify? dot setting on the cranks?
Old 09-29-2014, 08:28 PM   #4962
Trader Rating: 29 (100%+)
Originally Posted by TricycleRider View Post
Hey guys, I am running the usual 2x1.6 and 2x1.7 pistons and I'm having issues with this car still being really soft and lacking pack. I even ventured up to 45 and 40 wt shock oil just to try to stiffen this thing up a little bit. Is anyone else having these issues? I dont want to purchase the 20 dollar a set Kyosho springs that Ty uses if that wont solve my problem... Thanks for the help.
I had the same problem, just about every wheeler runs the 2x1.6 front and 2x1.7 rear piston setup with a large amount of success. This wheeler sucked ass with that setup and I went as high as 47.5 front and 42.5 rear and it was still way bouncy. So, I went the other way and tried 35 front and 30 rear and it was even WORSE. The only conclusion I can come to is that TY is running a special Pro-Line piston, or the Xgear and Kyosho springs are just that much better. Cause I also tried TLR and AE springs to no avail. Long story short after a full day of testing, I settled on 4x1.3 pistons on all 4 and 40wt. on all 4. with the stock springs. The car felt pretty good but was still a little on the soft side.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 09-29-2014, 08:33 PM   #4963
yeah, I have the 1.3x4 and I agree. It is a little bit soft. I think 1-2 spring rates up and it should be good. The problem is....Different sping's rates are not easy to compare. Why? well I talked to some people that have a high dollar spring tester. And I was told many of the springs out there are not really what they say...but if you go stiffer with a particular brand, you get a stiffer spring, but to directly compare to AE would not work without driving the springs. that is why I want to try yellow and red AE front. I think one of them will be good. I want to try ae white and grey rears also. I thin k those springs will get me where i want
Old 09-29-2014, 08:34 PM   #4964
And another thing is, I cannot find out whether tessman and fischer run emulsion or bladder style, cause it would make a significant difference. But I dont know of any pro level drivers that run bladders so i would think their setups are emulsion?
Old 09-29-2014, 08:37 PM   #4965
kdeleon's Avatar
I also thought 2 x 1.6 and 2 x 1.7 was too soft. I finally settled on 3 x 1.3 all around with 37.5 in the front and 32.5 in the back. I am happy with the front but the back is still a little soft. Might try 35 or am tempted to go 2 x 1.6 or 2 x 1.5 in the rear.
But so far the 3 holes are good and seem to work well in various conditions, med to med-high traction.
kdeleon is offline   Reply With Quote
