Like Tree42Likes
Old 09-26-2014, 09:12 AM   #4891
trick25's Avatar
Trader Rating: 27 (100%+)
too heavy in rear. with 15 up front go 5 or 7 prob 5
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 09-26-2014, 09:54 AM   #4892
snwchris's Avatar
On Petitrc, the 3 set-ups I've seen and using for reference for Med-High bite clay show people using 15-100-3. For my track I'm starting out with 10-100-3 and will go from there.
I'm planning on picking up a 2nd Front Diff to have on hand for easier diff changes.
snwchris is offline   Reply With Quote
Old 09-26-2014, 10:20 AM   #4893
Suspended
Trader Rating: 1 (67%+)
Stock setup works great at SRS Regardless of wildcat says. Box stock setup with pretty new electrons
Hot Bodies Racing, Proline Racing, Byron Fuels, and Radio Post
-Hot Bodies D8 Hara Edition, and D8 Truggy
-B5 and b4.2
rcgarrettp9 is offline   Reply With Quote
Old 09-26-2014, 10:29 AM   #4894
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
huh? what did I say, lol. I am mostly box stock. In fact I am like 99% box stock still.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-26-2014, 10:42 AM   #4895
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Which "Box stock" set up are you guys running? Per set up sheet (page 36) or per instructions? They are not the same.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 09-26-2014, 11:36 AM   #4896
my car is mostly built per the instructions. My sway bars are silver front and rear and maybe a couple other small things. My shorty is in the middle position. but camber links and shock positions are kit. I also run no limiters and have the eyelets to the bottom line
Old 09-26-2014, 08:44 PM   #4897
Trader Rating: 29 (100%+)
Is the looser diff in the rear to help the car rotate? With front diff tighter more on power steering? I can tune ball diffs with the best of them but pretty new to gear diffs so just curious if the same principals apply?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 09-26-2014, 10:21 PM   #4898
How have you guys been setting camber and toe in the front?? this thing wobbles so much you dont get the same measurement twice??
Old 09-27-2014, 01:18 AM   #4899
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by WagwanBumba View Post
Found some M2x10mm screws with 1.5mm hexes on them in my LHS ... Why .050 HPI!?!?
Which shop in HK?
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 09-27-2014, 02:50 AM   #4900
Originally Posted by veecee View Post
Which shop in HK?
I bought mine from Harmony Models on Pitt St. But there are other very good shops for screws. Most of my screws/hardware I get from Jet Hobbies on Victory Avenue and also RC Hobby on first floor, Hung Cheung building near KWS.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 09-27-2014, 09:25 PM   #4901
Djchow85's Avatar
I've seen a few people mount the fans either behind the motor or on an angle without a bracket you'd normally get to attach on the can. Are people just using double sided tape to hold down fans for the motor?
Djchow85 is offline   Reply With Quote
Old 09-27-2014, 09:54 PM   #4902
yeah, you can use tape. I also tried shoe goo, but that failed quickly. Now I am looking to get an onroad mount.
http://www.ebay.com/itm/Samix-Alumin...item1e90fa7723
or
http://www.tqrcracing.com/shop/produ....asp?p_id=4932
I am doing the shorty config, so I plan to reuse those screw holes
Old 09-27-2014, 11:19 PM   #4903
trick25's Avatar
first raceday with d413. i was put with 1/10 2wd(sc,st). only 4wd but i didnt care i wanted to run it. out qualed most 4wd sc guys though.
Car drives good. i have notice the weight difference between the durango and 413 makes the 413 a little more tricky to drive. But i do not have nearly enough time on buggy yet for it to be setup for me.
went on to get 2nd with my durango ST despite not driving it before the main.
But biggest thing....i raced the day and didnt break anything not even small. I think I can get used to this.
Old 09-28-2014, 01:08 AM   #4904
veecee's Avatar
Thanks mate! Can I ask what brand? Starting my build soon. Would be great to use these screws to start with!
Old 09-28-2014, 01:14 AM   #4905
This wheeler just does not suit my driving style. Great car, just not for me
