Like Tree29Likes
Old 09-25-2014, 07:14 PM   #4876
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Here's my set up after 4 days of testing.
Hot Bodies D413 1/10 4WD Buggy-nv529.jpg
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 09-25-2014, 07:40 PM   #4877
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
you sure about the AE caps on the rear? I Put them on this week. My camber link hits the mount before the arm is all the way up.I almost want to put the original caps back up and see the difference.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-25-2014, 07:43 PM   #4878
Originally Posted by Wildcat1971 View Post
actually.... I used the traxxas blue xrings. Same thing I use in my B5. It is like $5 to do all 4 shocks. And I always use green slime
do you have the part number?
Nick Vasquez
Old 09-25-2014, 07:47 PM   #4879
MasiisaM's Avatar
Looks like some notes at the bottom might address that? Or is that a separate issue?
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 09-25-2014, 07:48 PM   #4880
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ17
Old 09-25-2014, 07:49 PM   #4881
Originally Posted by MasiisaM View Post
Looks like some notes at the bottom might address that? Or is that separate issue?
my shocks cant bottom out, the link hit about 5mm before full compression.
Old 09-25-2014, 07:50 PM   #4882
Originally Posted by kdeleon View Post
Should that really be a gripe with this kit. Or should it be more about the industry. The D413 requires 4 hex sizes. The TLR 22 requires the exact same sizes. And my older B44 also required 4 sizes. Those are the kits I had so it seems fine to me.
Having built my 2WD VBC Wildfire, Kyosho ZX6 and Xray XB4 very recently, bitterly disappointed with the diffs. They're not smooth and those .050 screws ... shoot me now! I have to go out and buy a hex driver just for this ... my allen key that worked with my B44.1 (because the screws were short) just isn't up to the job. No excuse to have countersunk the screws and used metric hardware with 1.5mm hex on top. Really wanted to like this kit (my first nitro was an HPI and I loved it!) but to get disappointed at step B.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 09-25-2014, 07:57 PM   #4883
I definitely dont love the build of the kit. But is does drive well. so I am trying to tolerate it.
Old 09-25-2014, 08:11 PM   #4884
wel, since i just rebuilt mu shocks, I tossed a couple orings on each shaft to serve as external limiters. I kinda want to keep the AE caps on because my rear shocks popped off a few times in practice
Old 09-25-2014, 08:12 PM   #4885
kdeleon's Avatar
Since you quoted me, I personally had no issues building my diffs but I can understand what you are saying. When I worked on my B44, I realized allen keys just didn't work, so I quickly upgraded. Surprised how much of a difference a quality hex wrench makes.
Anyway, my comment was around the number of types of hex wrenches needed. This kit is inline with other kits. For me, even if there is just one screw, then I need to have a wrench. So 1 screw or 100, I will need to carry that wrench.
kdeleon is offline   Reply With Quote
Old 09-25-2014, 08:18 PM   #4886
I'm positive, check out the witness marks in the photos (bumpstops removed to show bind in photos). The AE cap are about 1.5mm shorter to centerline of standoff hole this will allow additional up travel which is causing the bind. This is a non-issue with the stock caps.
Hot Bodies D413 1/10 4WD Buggy-img_20140925_231018_600.jpg   Hot Bodies D413 1/10 4WD Buggy-img_20140925_230204_455.jpg   Hot Bodies D413 1/10 4WD Buggy-img_20140925_224907_957.jpg   Hot Bodies D413 1/10 4WD Buggy-img_20140925_224648_631.jpg
Nick Vasquez
Old 09-25-2014, 08:31 PM   #4887
I have all of those witness marks with the stock caps also.
Old 09-26-2014, 01:48 AM   #4888
Found some M2x10mm screws with 1.5mm hexes on them in my LHS ... Why .050 HPI!?!?
ST - Losi 22T 2.0
Old 09-26-2014, 05:51 AM   #4889
trick25's Avatar
Trader Rating: 25 (100%+)
thanks. i will address this shock issue tonite before we race tommorrow.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 09-26-2014, 07:45 AM   #4890
Trader Rating: 29 (100%+)
For a medium to high bite clay track is 15k 100k 10k front to rear good for diff oils?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
