Like Tree28Likes
Old 09-25-2014, 09:25 AM   #4861
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
yeah, people are drilling their own holes
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-25-2014, 09:38 AM   #4862
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Wildcat1971 View Post
So I rewired my car with deans ultra wire..... IMO it is too stiff. I normally use the TQ13awg in my 2wd cars. Unsure if I want to try it in the d413. My 12awg wires already get warm from racing. Who makes the best and most flexible 12awg? Wet Noodle? Reedy 12awg?
I use the wet noodle and have not a problem with heat on any kits. It's the most flexible wire I've personally seen
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 09-25-2014, 09:45 AM   #4863
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by braderb View Post
the incubus
What about an alternative to hobby shop "BLACK GREASE"
That one I do not know. A few people on RCTech indeed know precisely what it is and where to get it at a fair price instead of the grotesquely inflated In-Hobby prices for just a god damned smidgen.
If I had to guess and experiment, I'd try Dow33 as it is a specifically engineered bearing grease with carbon molecules mixed into it, but I do not know how it would hold up and if it would work well. As it dissipates it leaves just a residue carbon molecules which is black.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 09-25-2014, 09:46 AM   #4864
spu83's Avatar
I think you can use smaller wires if they are short enough.
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 09-25-2014, 09:57 AM   #4865
I have a bunch of different "brand" wire and it's all very similar. I have some shiny coated and some flat finished wire in 12, 13 and 14 AWG and they are all comparable to one another in each respective gauge.
Wet noodle isn't made to any special set of specifications from Deans. They simply call up a wire manufacturer who makes it in bulk and they pay a cent or two extra to have their "branding" stamped on it. Several "manufactures" in RC provide the exact same stuff from the very same spools. It is flexible, more so than some, but there are others just like it. Flexibility all depends on the strand count for the gauge and the silicone formula used for the insulation.
The number one culprit that results in loss of flexibility is over tinning. You ALWAYS want to tin using the minimal amount of solder to coat the leads completely. A touch of flux will allow you to accomplish tinning much more efficiently than without.
ROB RIVERA
Old 09-25-2014, 11:16 AM   #4866
So far ... shocking build. The screws to put the diffs together ... why did they not use screws that had a 1.5mm hex. Destroyed 1 diff already :|
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 09-25-2014, 11:52 AM   #4867
that is one grip I have with this kits. The number of hex drivers required. I would prefer that the kit be all 1.5 and 2mm.
Old 09-25-2014, 12:46 PM   #4868
kdeleon's Avatar
Should that really be a gripe with this kit. Or should it be more about the industry. The D413 requires 4 hex sizes. The TLR 22 requires the exact same sizes. And my older B44 also required 4 sizes. Those are the kits I had so it seems fine to me.
kdeleon is offline   Reply With Quote
Old 09-25-2014, 12:50 PM   #4869
Trader Rating: 130 (100%+)
Hey guys. I am having a hard time getting the D413 to run on a indoor tight clay track. Can you guys share some of your setups?
skyline1015 is offline   Reply With Quote
Old 09-25-2014, 01:24 PM   #4870
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Which set up are you using right now?
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 09-25-2014, 01:50 PM   #4871
https://drive.google.com/file/d/0B6C...it?usp=sharing
Old 09-25-2014, 02:31 PM   #4872
the tlr22 uses a 2mm on 98% of the car. In fact, I cant think of any 1.5 aside from maybe the hexes.
Old 09-25-2014, 02:32 PM   #4873
your pistons look a little on the crazy side. what do you want it to do or not do?
Old 09-25-2014, 02:47 PM   #4874
Team Tekin
yzracer758's Avatar
I would start by less front kickup, move battery forward, and go down to 10 or 15k on front diff oil
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is online now   Reply With Quote
Old 09-25-2014, 03:53 PM   #4875
JKoiva's Avatar
Finally got my car built, first run will be tomorrow night. I'm running medium bite small indoor clay topsoil mix tracks up here in New England this winter. The Kit was packaged well, made it very easy to build, I'm still not used to all the slop in a new kit, but I'm eager to see how it handles and understand the philosophy. I liked my d812 which had the same slop just always seemed like it was on edge compared to my mp9 for my driving style. Anyways, figured just start with stock setup, stock shocks, diffs for day 1... But then after reading Torrance from page 1, I went with 15-100-3, and I used Kyosho x rings in the shocks ... Looking at other setups posted here but I'm thinking that my tracks in New England don't have the same groove/traction, and temperature like the west coast tracks and setups you guys are running though? . We will see after Friday I guess, on which direction to go with setup.
Tki3 , O.S.
D413
B5M
Futaba
JKoiva is offline   Reply With Quote
