Like Tree28Likes
Old 09-24-2014, 05:11 AM   #4846
snwchris's Avatar
On Petitrc there's a couple setups running the 2x1.6 Pistons.
That's how I currently have mine setup with, so when I hit the track in next couple weeks, since Indoor season will be starting up should know how it is.
snwchris is offline   Reply With Quote
Old 09-24-2014, 06:29 AM   #4847
big greg's Avatar
Trader Rating: 119 (99%+)
heres my rig I just finished, dont really like the battery leads, lol
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 09-24-2014, 09:15 AM   #4848
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
So I rewired my car with deans ultra wire..... IMO it is too stiff. I normally use the TQ13awg in my 2wd cars. Unsure if I want to try it in the d413. My 12awg wires already get warm from racing. Who makes the best and most flexible 12awg? Wet Noodle? Reedy 12awg?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-24-2014, 09:17 AM   #4849
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Wildcat1971 View Post
actually.... I used the traxxas blue xrings. Same thing I use in my B5. It is like $5 to do all 4 shocks. And I always use green slime
A quick tip for you guys, The best lube to use on your Friction O-rings is DOW55. It is specifically engineered for the application and has a component that swells O-rings a touch to create a better, more uniform seal. O-rings are rarely perfectly round and as such, you are supposed to lube their groves before installing them, and then you wipe the excess lube over the O-ring to provide a thin film. Additionally you can let your O-rings sit in the Dow55 for a day or two before installing them and then follow the procedure.
I take my lube a step further due to my experience with O-rings thanks to 20+ years in Paintball and make my own concoction I call Formula-44D. It contains the same swelling properties of Dow55 whilst being slicker and smoother and never sticks. I may have to make a batch and peddle it in the RC market. It is that good. LOL
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 09-24-2014, 09:21 AM   #4850
this stuff?
http://www.amazon.com/CORNING-MOLYKO.../dp/B00B2OHYMU
Old 09-24-2014, 09:22 AM   #4851
Post or PM a pic of the current setup.
Wet Noodle and all the name brand wire is nothing more than rebranded Chinese stuff these days and its stiffness depends on the silicone insulation and the strand count. Wet noodle should not be stiff and nether should any of the well known RC Brands.
You also want to strip just a hair more than 1/16' off the end of your wires and then tin just that tiny amount of wire. From there tin the contact points just before you are ready to solder the leads onto them. Of course, ALWAYS use a tiny bit of flux on the wire (I use my X-acto knife to place a small dab of it on my leads) and make sure you iron's tip is pristine before pressing down on the tinned lead and the result is a perfect solder joint.
ROB RIVERA
Old 09-24-2014, 09:23 AM   #4852
Yes sir, but that's a whole lot of Dow55. That tube will last you YEARS!!! LOL
ROB RIVERA
Old 09-24-2014, 09:30 AM   #4853
The orion stuff feels more flexible than the Deans ultra wire. But orion wants an unborn child for that stuff. I think it is because the insulation is thinner. Like the TQ13. I think the Reedy wire has a thinner insulation also.
Old 09-24-2014, 09:53 AM   #4854
And Orion stopped ordering the damn Purple stuff too!!! :P
ROB RIVERA
Old 09-24-2014, 05:02 PM   #4855
anyone tried the 1.2x4 pistons? The only drill bit I have is a #55. I am debating making my blanks into 1.3x3. meh, maybe I will just go up in oils
Old 09-24-2014, 05:08 PM   #4856
trick25's Avatar
Trader Rating: 25 (100%+)
if you want to try 3x1.3. i would close up one of the holes before i used my blanks.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is online now   Reply With Quote
Old 09-24-2014, 07:02 PM   #4857
the incubus
What about an alternative to hobby shop "BLACK GREASE"
braderb is offline   Reply With Quote
Old 09-24-2014, 07:50 PM   #4858
kdeleon's Avatar
For the 3 x 1.3, I just plugged up one of the holes. I had already used up my blanks for 2 x 1.6 and 1.7 pistons. Since I had the 4 x 1.3, I thought I could try those instead. Torrance even suggested the same thing. I blocked mine with tooth picks and glued them in place. I recently changed out my oils and they were still in place. So it can work and no worries about incorrectly drilling new holes.
kdeleon is offline   Reply With Quote
Old 09-25-2014, 08:29 AM   #4859
Hey guys ... for the 2X1.6 and 1.7 pistons, are people just drilling their own ones? I've only just started building my D413.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 09-25-2014, 09:25 AM   #4860
trick25's Avatar
yes they are drilling the blanks.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
