Like Tree31Likes
Old 09-12-2014, 11:41 AM   #4576
Default Gearing for a 13.5 motor
I have the 72 pinion spur gear. I'm running a 13.5 motor. How many tooth pinion do I need for the motor?
sdsurfer is offline   Reply With Quote
Old 09-12-2014, 01:42 PM   #4577
Tobiasmart's Avatar
On the first page there is a chart. For 13.5 it says 34 tooth.
Tobiasmart is offline   Reply With Quote
Old 09-12-2014, 03:03 PM   #4578
Ok so my LHS has one of these little puppies in stock in stock and thinking I might go grab it today. Only driven 8th scale and 2wd St and wondering if this setup sounds about right. Savox 1258tg retention pro 1.1 with 5.5r hooked up to my 4pls running the smc shorty?? Am I heading down the right path with setup to try my hand at 10th mod??
Tekno ET48, Tekin RX8/T8 2000, Hitec 7955
Tekno EB48.2, Tekin RX8/T8 2050 2050. Hitec 7955
Mugen MBX7eco, Tekin RX8/T8 2050, Hitec 7955
AE RC8.2e Tekno V4, Tekin 1900, Savox 1256TG
Futaba 4PL
Vegetable is offline   Reply With Quote
Old 09-12-2014, 03:29 PM   #4579
trick25's Avatar
Trader Rating: 25 (100%+)
sounds like a good setup. depending on size of track.
4wd bug-D413, Blinky bug-XB2 17 CE 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 09-12-2014, 03:33 PM   #4580
Decent sized well kept outdoor with a triple. Pretty good grip
Futaba 4PL
Old 09-12-2014, 04:04 PM   #4581
trick25's Avatar
i would say 6.5. but a 5.5 would be fine too.
Old 09-12-2014, 05:18 PM   #4582
Have already run on a small indoor track with an SMC 5.5 motor. You'll be fine. A 5.5 motor will be smoother than a 6.5. Seems like the even number wind motors, ie 6.5, 8.5, have more torque and will be punchier, than odd number wind motors like 5.5, 7.5. I'd rather have smooth over punchy, easier to drive harder.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 09-12-2014, 05:51 PM   #4583
Originally Posted by Tobiasmart View Post
I like those orange wheels. How does the offset compare to that of the stock wheels?
skeeler is offline   Reply With Quote
Old 09-12-2014, 05:53 PM   #4584
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Got my used d413. It haf a blown spur. I replaced that. Also replaces the screws that go into alum. The kit screws feel kinda cheap. Replacing the spur sucked. Had to dusassemble half the car lol. I ran 2 pacjs with a 6.5 in yhe shorty config. The csr felt planted and very stable. [email protected] out a little easy. The previous owber said it is the tessman setup. I am running indoors on medium bite. The plastics feel cheap and the mix of 2mm hex and 2.5mm hex is annoying. The rack us sloppy. Was expecting higher quality.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-12-2014, 05:54 PM   #4585
Gah. Phone typing fail
Old 09-12-2014, 06:08 PM   #4586
trick25's Avatar
lots of different tessman setups. and you will of course adjust for your driving style. if it steps out easy i would play with rear roll center first.
did you change the button screws on the motor mounts to cap head screws? i personally think that would help you be able to tighten down the motor better. and help save the spur. i will find out when i build the kit when i get it in soon.
Old 09-12-2014, 07:33 PM   #4587
Matt :-)'s Avatar
Some one say socket head screws ?
Matt :-) is offline   Reply With Quote
Old 09-12-2014, 07:53 PM   #4588
trick25's Avatar
thats what is going on mine. figured it could not hurt.
what gearing your running with the 7.5?
Old 09-12-2014, 08:49 PM   #4589
I just bought one off a shelf at my LHS!! Can't wait to build it
Futaba 4PL
Old 09-13-2014, 02:32 AM   #4590
Matt :-)'s Avatar
22t Robinson Racing Absolute steel pinion.
I'm only running this car on a few indoor tracks right now though. They range from 2500 to 5000 square feet in size. The outdoor tracks in my area range from 7500 to 12000 square feet. I'd probably use a 6.5t motor & 23t pinion for those tracks.
