Like Tree35Likes
Old 09-08-2014, 07:28 PM   #4531
JasonR/C's Avatar
With a 6.5 I have tried a 22-23 pin and had higher temps. Went to a 25pin and the temps dropped and man was my car fast. Outdoor medium traction. With a 6.5 I do thinks the 22 range is alittle under geared
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 09-08-2014, 09:26 PM   #4532
Trader Rating: 17 (100%+)
Hmm that is interesting. What were the temp differences and what diff setup!
AlderBoy is offline   Reply With Quote
Old 09-09-2014, 04:00 AM   #4533
Hello. Tell me please, differential gears in this model sintered or machined?
foobar is offline   Reply With Quote
Old 09-09-2014, 05:39 AM   #4534
Trader Rating: 21 (100%+)
True story...i was sitting across for him. Took his advice and had the same result.
AE B6
AE B64
kerby is offline   Reply With Quote
Old 09-09-2014, 05:57 AM   #4535
Machined I believe.
Old 09-09-2014, 05:58 AM   #4536
I believe it, just curious as to the specifics.
Old 09-09-2014, 06:02 AM   #4537
Trader Rating: 132 (100%+)
Default Center Diff Help
Hey guys, I have been running the buggy on an outdoor track since I got it in may. 20/100/5. No issues with handling.
I am getting the buggy ready for an Indoor clay track. A few trips to the track and I noticed that on Hard Braking, the front just locks up and the buggy slides. Will dropping the center diff to 60k help with the braking?
skyline1015 is offline   Reply With Quote
Old 09-09-2014, 06:06 AM   #4538
JasonR/C's Avatar
Outdoor diffs are the same as my indoor clay setup
7/100/3.
22 pin was over 170
25 pin was 160 at most after 6 minutes.
Old 09-09-2014, 06:33 AM   #4539
7/100/3.
22 pin was over 170
Interesting, this goes against the recommended gearing. If it works who can argue though.
Torrance or Ty, any thoughts on this?
Old 09-09-2014, 08:10 AM   #4540
JasonR/C's Avatar
I keep my break epa at max. Adjust to 75% in your esc and then adjust with ATL only after that. No need to go down in diff fluid.
Old 09-09-2014, 08:15 AM   #4541
gearing is a mystery. too far off in either direction can cause a motor to run hot.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 09-09-2014, 08:28 AM   #4542
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Sounds similar to 8th scale.
A gun in the hand is better than a cop on the phone.
A 9mm might expand but a .45 will never shrink.
The gene pool needs a little chlorine.
DRTMI is offline   Reply With Quote
Old 09-09-2014, 08:32 AM   #4543
snwchris's Avatar
The recommended gearing on the first page shows a (23.8) pinion for 6.5, so one would assume to carry a 24T & 25T pinion.
Motor: 6.5 FDR: 10 Pinion: 23.8
I plan on running a 8.5 motor since my first trip in 4w buggy and will probably 24T-26T pinion
snwchris is offline   Reply With Quote
Old 09-09-2014, 09:03 AM   #4544
That it is. I run a 20/21 with a 5.5 and 21/22 with a 6.5. No heat or speed issues. Maybe I should go up a couple teeth and see what happens.
Old 09-09-2014, 10:55 AM   #4545
I run 21t on an Orion 5.5 and it seems to run out of steam on straights. I bought a 22t today to try and suspect I may go as high as 23t. Pleased it's not just me. Car is brilliant by the way.
sime46 is offline   Reply With Quote
