Like Tree42Likes
Old 09-05-2014, 03:25 PM   #4501
Trader Rating: 15 (100%+)
This buggy comes with a set of wheels, correct?
Tommygun1 is offline   Reply With Quote
Old 09-05-2014, 03:28 PM   #4502
trick25's Avatar
Trader Rating: 27 (100%+)
yes
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 09-05-2014, 03:28 PM   #4503
Trader Rating: 133 (100%+)
Complete set of white
skyline1015 is offline   Reply With Quote
Old 09-05-2014, 04:44 PM   #4504
Matt :-)'s Avatar
Originally Posted by LT FAB View Post
Pull that servo saver off and save yourself a lot of headache.
I've performed zero modifications to the bell crank/steering rack.
Also running the stock servo saver, and I've finished within the top 3 positions in every race so far. Just sayin.
Matt :-) is offline   Reply With Quote
Old 09-05-2014, 05:08 PM   #4505
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by the incubus View Post
In the future you might want to study the wire and see how twisting it one way or the other causes it to sit. Get that right and you won't ever have to "train" your wire again. I measure my wire and then tin both ends in order to see how they fall naturally so I can know how I need to solder both ends for the desired effect.
seriously, where did you get that purple wire
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-05-2014, 06:32 PM   #4506
Trader Rating: 139 (100%+)
Originally Posted by JoeC View Post
I am assuming the answer is yes but I am about ready to build my new kit and was going to use the recommended associated standoffs and composite shock caps. My question is can I use the associated b5 aluminum caps instead of the composite?
Tried it, nope.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-06-2014, 12:12 AM   #4507
bedwell1's Avatar
I know this is an odd question but does anybody else's car sound differently than most other cars. I'm not sure if its the cars drive train, motor or mesh but mine just sounds different.
bedwell1 is offline   Reply With Quote
Old 09-06-2014, 05:26 AM   #4508
Matt :-)'s Avatar
The D413 is probably the loudest 10th scale 4wd buggy at the moment.
Most R/C's with a center diff tend to make more noise in comparison to a 4wd with a center slipper, or at least it seems that way to me.
The center diff bulk head may also be transferring sound to the carbon fiber chassis, and in turn, the chassis resonating that sound. Kind of like one of those big oriental gongs.
There's my theory for the day. Now I'm off to drink coffee, and play with toy cars
Old 09-06-2014, 10:18 AM   #4509
Ok someone tell me where the secret stash is so I can pick one of these up.
Old 09-06-2014, 10:23 AM   #4510
Jaz240's Avatar
Trader Rating: 52 (100%+)
Seems like they ship them 2 at a time from Istanbul via carrier pigeon.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-06-2014, 12:46 PM   #4511
bedwell1's Avatar
I know its been mentioned but what shock piston work I've still got my blank ones but want to try others if available. Sorry don't want to look through 300 pages to find my answer
Old 09-06-2014, 11:13 PM   #4512
How much drag is their in your drivetrain? Once I lift off the buggy seems to slow down quite quickly.
moch8 is offline   Reply With Quote
Old 09-07-2014, 04:50 AM   #4513
cokemaster's Avatar
Trader Rating: 18 (100%+)
The most common for the blanks is to drilled them 3 x 1.3mm. You can use this setup both front and rear.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 09-07-2014, 10:20 AM   #4514
Does anybody know if the there is some other manufactor of the little black plastic piece that's under the clip that holds the wing that fits?
I've lost three of those and it's quite annoying to order a complete wing mount set, when you just need that piece. Otherwise I haven't broke a thing on this machine yet.
p_west is offline   Reply With Quote
Old 09-07-2014, 02:14 PM   #4515
murky123's Avatar
you can use these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJH49, just cut them with a lexan scissors to the right size
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
