Like Tree42Likes
Old 09-04-2014, 10:52 AM   #4471
kdeleon's Avatar
Originally Posted by Wildcat1971 View Post
ok, this car is now around 6 months old. How is it holding up aside from the spur gear? Outdrives and diff wear? What parts break the most? What are the critical upgrades? Anyone running this car with a 10.5? I never really like super fast motors. And a 10.5 is probably fine for the indoor racing I do. I just dont have it over heating if the car tends to run motors a little hot.
Top issues that I have seen (in no particular order):
1. Spur gear stripping.
2. Shock caps (not sure if people are breaking or just popping off).
3. Rear outer ball stud as mentioned just again recently.
For me, I have only experienced the shock cap popping off. It really doesn't bother me. I just pop it back on. I prefer that fix than having the plastic break or the shock tower. I even had one come off during a race after a crash. The marshal popped it back on. I may have lost a few more seconds but I finished the race. I have always had it come off after an accident.
And that leads to the most common upgrade, use AE shock caps until HB delivers their version.
I wouldn't call this an upgrade, but another common change is adding shims or filing down the steering rack to remove some slop. I added some AE shims. But it was more for looks than change in steering. It was just weird seeing the wheels moving so much on the track, I was always worried something was going to fall off.
kdeleon is offline   Reply With Quote
Old 09-04-2014, 01:12 PM   #4472
murky123's Avatar
its holding up great. outdrives and diffs wear is good. I run this car from last april. and my season ends in a month. but im gonna use the outdrives and dogbones also in the next season.
to bad you live across the ocean otherwise I could hand you my buggy to show it to you
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-04-2014, 01:15 PM   #4473
snwchris's Avatar
Is this the Ball Cup your talking about??
Hot Bodies D413 1/10 4WD Buggy-rear-ball-cup.jpg
snwchris is offline   Reply With Quote
Old 09-04-2014, 05:30 PM   #4474
tazfam2's Avatar
Trader Rating: 40 (100%+)
Yes 3 cars at our track all have broken that part more than once
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
Old 09-04-2014, 06:41 PM   #4475
trick25's Avatar
Trader Rating: 27 (100%+)
thanks for the heads up. if i get this kit ill put durango ones in that spot.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is online now   Reply With Quote
Old 09-04-2014, 06:48 PM   #4476
Matt :-)'s Avatar
Matt :-) is offline   Reply With Quote
Old 09-04-2014, 06:49 PM   #4477
Trader Rating: 120 (100%+)
I am assuming the answer is yes but I am about ready to build my new kit and was going to use the recommended associated standoffs and composite shock caps. My question is can I use the associated b5 aluminum caps instead of the composite?
B6D
B64D
Tekno EB410
JoeC is offline   Reply With Quote
Old 09-04-2014, 07:03 PM   #4478
trick25's Avatar
i dont know for sure but it is said that the aluminum dont thread all the way on correctly and to use the composite.
Old 09-04-2014, 07:11 PM   #4479
Thanks for the reply.
B6D
B64D
Tekno EB410
Old 09-04-2014, 07:42 PM   #4480
trick25's Avatar
Originally Posted by Matt :-) View Post
i actually have very few HD durango pop off. but i also dont pop them off to work on it. i have had better luck with durango than most other brands.
Old 09-04-2014, 07:46 PM   #4481
kdeleon's Avatar
Does durango have a match for the rear outer cup? If so can you post a part number. The one used here seems pretty specific to the car. But if you are talking about the "standard" ball cups, I don't think many are having a problem with those.
Old 09-04-2014, 08:28 PM   #4482
Pete Martinez's Avatar
Question for anyone. The front and rear bones seem to be off on my car front being to short and the rear being to long anyone else having this issue. And yes there on the car correctly plus it's hard to make that mistake with the bags being set up for you bag by bag front and rear apart. The front bone is 75mm and the rear is 73mm thanks.
MUGENRACING.COM/MBX7/
/B64/B6/RIP LIR/PHAT SCHEEMZ PAINT/WWW.RCNYC.NET/
BARNSTOMERSRC/REDLINE HOBBIES/WOLCOTT HOBBY & RACEWAY/
/FORT KNOX RC NYC/IRH RACEWAY/TEAM TIGHT TO THE PIPE RACING/
/TEAM RAMOS/
Pete Martinez is offline   Reply With Quote
Old 09-04-2014, 09:15 PM   #4483
jhautz's Avatar
Trader Rating: 85 (100%+)
The front outdrives are longer than the rear. You have the front and rear diff swapped. I did the same thing. Took me a little while to figure it out.
jhautz is offline   Reply With Quote
Old 09-04-2014, 09:22 PM   #4484
Default My ride
Just waiting on body paint
Allen Drebi is offline   Reply With Quote
Old 09-05-2014, 05:16 AM   #4485
Matt :-)'s Avatar
Allen Drebi,
I like how you used a piece of lexan to mount the fan.
I'm not running any fans on my D413. Temps have been great.
This may not be an issue since you mounted the fan, but IF you do experience higher motor temps, you might end up needing to get all that extra wire off of your motor can. This would be especially helpful if your fan played out in the middle of a race. I had wires packed right against a motor like that before on an 8th scale buggy. Kept battling with high temps. When I re-routed my wires off the motor can, it allowed more air flow around the motor. Dropped temps about 18 degrees. Just food for thought.
Your build looks great
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Sofa King
