Like Tree31Likes
Old 08-04-2014, 02:13 PM   #4036
chadg's Avatar
Trader Rating: 16 (100%+)
Originally Posted by kdeleon View Post
Since no one is answering the questions on how to use other brand shock pistons with this car, let me take a crack at it and have other correct.
The car has washers that go above and below the piston. So even if you use a TLR piston, for example, the larger hole will probably still not be larger than the washer.
So one would mount up the piston but not tighten down the screw completely. Then start building the shock. Once the piston is build, the you could tighten up the screw and the piston would be centered and thus work properly.
P.S. Ok, maybe I understand why no one replied. I really had to word that carefully without it making the whole explanation go in a different direction. Not perfect, but close.
You hit the nail on the head, that's how I built mine up with TLR pistons.
I placed the nut on loosely, ran the shaft up and down to center the piston then tightened down the nut a bit. Rinse and repeat until I had clean movement up and down all around shaft rotation. It hasn't moved yet, but I'm keeping an eye on it.
chadg is offline   Reply With Quote
Old 08-04-2014, 03:50 PM   #4037
Matt :-)'s Avatar
Originally Posted by jpcopeland1 View Post
Finally got my diff
Parts 2 days late thank you USPS. Need gearing for an 8.5.
I'm running a 22t on a Speed Passion 7.5 zero timing all the way around. Feels pretty good so far. 155 degrees on 12 to 15 minute runs.
Matt :-) is offline   Reply With Quote
Old 08-04-2014, 03:50 PM   #4038
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Matt :-) View Post
Above and beyond is the only way the folks at Tekin roll. THE BEST customer service in the biz. PIRIOD
+1 million AND it's a HB part! NOT a TEKIN part!!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-04-2014, 05:19 PM   #4039
Trader Rating: 137 (100%+)
Thanks Matt.
jpcopeland1 is offline   Reply With Quote
Old 08-04-2014, 07:42 PM   #4040
Matt :-)'s Avatar
I know ! Dude must be hookin you up with some personal stash.
Don't get me wrong. The Speed Passion in my car is performing well. If I wasn't tight on cash when I did this build, I would have had Tekin all the way. Just couldn't scrape enough together. Running Tekin in both my 8th scales and love um !
When I bought my 1st tekin set up for my 8IGHT-E 2.0, I really needed some help with understanding how to properly set it up. Jeremy (an AWESOME tech at Tekin) took a good 45 minutes with me on the phone and tutored me step by step through the entire esc linked with Hot Wire. What a huge help !!! His assistance went much farther than that because there's no telling how many fellow racers iv'e been able to pass the knowledge onto. I just can't speak well enough about what a great asset Tekin is to the R/C industry. And what a great program they have for our Military ! If I keep this up, I may be tempted to apply with them as a sales rep
Old 08-04-2014, 10:36 PM   #4041
ScottyP's Avatar
That makes sense. Thx!
ScottyP is offline   Reply With Quote
Old 08-04-2014, 11:06 PM   #4042
First club race on new tires. Got third against some insanely fast locals. Not having a slipper will take some getting used to. How do I adjust the diffs so it does not feel like the front is carrying most of the load of getting the car to move forward. Running tessmans setup from Reedy Race. Poor guy with a 22-4 broke it in two out of the three heats we had.... (Church giggles)
Old 08-04-2014, 11:08 PM   #4043
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
if you feel like too much power is going to the front, you would go thicker in the center diff.
RC*PHREAK is offline   Reply With Quote
Old 08-04-2014, 11:22 PM   #4044
racer x 1's Avatar
Trader Rating: 27 (100%+)
for those that ran surf city classic dont forget to post your set ups . I know when I talked to JD Mora a few weeks back when he was practicing for it he ran a set up mirroring Tessmans Reedy set up. Curious to see if any others can share.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 08-04-2014, 11:29 PM   #4045
Would thickening up the rear help out?
Old 08-04-2014, 11:30 PM   #4046
Was supposed to run it, but a problem center diff and a usps screw up kept me from running there.
Old 08-05-2014, 05:00 AM   #4047
Matt :-)'s Avatar
Think of it like this.
Heavier center diff oil would be similar to tightening a slipper clutch. Putting more equal power front and rear.
Thinner center diff oil would be similar to loosening a slipper clutch. Putting more power to the front while on throttle.
The following does hold basic fact / truth, but ultimately comes down to the condition of the track surface and personal driving style.
Heavier rear diff oil may help give you more straight forward bite (as long as the center diff is supplying enough drive to the rear) , but the rear might want to lose traction while on throttle through a turn.
Lighter rear diff oil will provide better on throttle control in turns, and personally I've never really been in a situation where it hurt my speed on the straights.
Hope this is helpful.
Old 08-05-2014, 05:53 AM   #4048
Red78's Avatar
I've played with a few different combos on a dirt track outside..med to les then med bite.. 10/50/10 seems to work real well.. I also tried that on carpet and I liked it. Jumped nice and and panty of brk control
Red78 is offline   Reply With Quote
Old 08-05-2014, 07:39 AM   #4049
Makes sense to me. Always wondered why we ran 10K up front and 3K rear with the slipper relatively tight, but not too tight as to strip the diff gears in an XB4. I'm almost positive now that I have slept on it that having new tires is always going to be a hindrance at first. It only was doing it in one section of the track which stays wet pretty much all day long while other parts dry up a little bit and have better grip.
Old 08-05-2014, 09:53 AM   #4050
RockStew's Avatar
Oh man dude you just stoked the crap out of me with this info I am getting the picture!!!!! one piece left what happens in the front by increasing, decreasing the weight oil?
B5M,TEKNO SCT 410,T5M,HB D413,TEKIN,DE WHEELS,TRINITY,PROLINE,JCONCEPTS,SDRC,IERC, EclipseRC.com, AIRTRONICS,
RockStew is offline   Reply With Quote
