Like Tree31Likes
Old 08-04-2014, 07:21 AM   #4021
i used kit ones, and plugged one hole to make a 4 hole into a 3 hole
tower has them in stock http://www3.towerhobbies.com/cgi-bin...?&I=LXEGFF&P=7
Cygnus X is offline   Reply With Quote
Old 08-04-2014, 08:35 AM   #4022
Stevomatik's Avatar
Originally Posted by AlderBoy View Post
Why are folks trying other pistons, not enough HB ones available or folks don't want to drill HB blanks?
I tried losi pistons because I had them on hand and didn't have a drill kit at the time... Got a drill kit now and ended up drilling my own... Big difference between 4 hole and 2 hole pistons
Check out the bodies I've painted
Instagram.com/CBS_RC
Stevomatik is offline   Reply With Quote
Old 08-04-2014, 08:58 AM   #4023
DWheels's Avatar
Race day always feels like forever away!
Tekin, Inc. - Team Yokomo - Protek RC - Factory-RC Products - Pro-Line Racing - Vision Racing Products - Avid RC - Max.FX - SOR Graphics
DWheels is offline   Reply With Quote
Old 08-04-2014, 09:02 AM   #4024
Maxxican's Avatar
Trader Rating: 65 (100%+)
I had first run with this buggy,. its a blast to drive took a few huge tumbles and only broke a ball end all weekend. made the main but this being my first 4wd i need more stick time on it to keep up with the fast guys...
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 08-04-2014, 09:31 AM   #4025
ali_g's Avatar
anyone tried removing the front centre shaft and use it as a 2wd?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 08-04-2014, 09:37 AM   #4026
lbenton's Avatar
Trader Rating: 48 (100%+)
That would not work unless you addressed the center diff and locked it someway.
lbenton is offline   Reply With Quote
Old 08-04-2014, 10:09 AM   #4027
ali_g's Avatar
perhaps putting 1 million into the centre diff? has
☆ JU.C RACING ☆
Old 08-04-2014, 10:30 AM   #4028
to make 2wd the right way you would have to remove front diff, take front axles apart, remove center axle, so there is no drag on the front tires
center diff you would need way thicker oil/grease, it might be beneficial to have the diff working a bit as there is no slipper....so maybe 500k to 1m ?
Old 08-04-2014, 11:34 AM   #4029
Matt :-)'s Avatar
Just for the sake of joining the current topic.
I just had a similar conversation with a friend of mine.
He brought up 2 good points.
1 - Why would some one want to buy a $430.00 4x4 kit, just to convert it to 2wd ?
2 - If it was capable of being competitive, Tye Tessman would have already done it.
I admit, I was curious myself, until he challenged me with those 2 questions.
Matt :-) is offline   Reply With Quote
Old 08-04-2014, 12:24 PM   #4030
What's the advantaged of 2 holes compared to 4 holes?
Tigergutt is offline   Reply With Quote
Old 08-04-2014, 12:27 PM   #4031
Trader Rating: 17 (100%+)
Other companies like Xray and Schumacher that have done this haven't had good luck with their cars. They pretty much only work well on carpet/astro. I would just get a proper 2wd car for now and/or wait for one from HB.
AlderBoy is offline   Reply With Quote
Old 08-04-2014, 12:40 PM   #4032
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by yzracer758 View Post
Marc, let me know where you want me to send a new hinge pin to?
THIS is going "Above and Beyond!" Thanks, I'll be able to get it dirty
this weekend!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-04-2014, 12:48 PM   #4033
kdeleon's Avatar
Default Other Brand Shock Pistons
Since no one is answering the questions on how to use other brand shock pistons with this car, let me take a crack at it and have other correct.
The car has washers that go above and below the piston. So even if you use a TLR piston, for example, the larger hole will probably still not be larger than the washer.
So one would mount up the piston but not tighten down the screw completely. Then start building the shock. Once the piston is build, the you could tighten up the screw and the piston would be centered and thus work properly.
P.S. Ok, maybe I understand why no one replied. I really had to word that carefully without it making the whole explanation go in a different direction. Not perfect, but close.
kdeleon is offline   Reply With Quote
Old 08-04-2014, 12:52 PM   #4034
Matt :-)'s Avatar
this weekend!
Above and beyond is the only way the folks at Tekin roll. THE BEST customer service in the biz. PIRIOD
Old 08-04-2014, 02:10 PM   #4035
Trader Rating: 137 (100%+)
Finally got my diff
Parts 2 days late thank you USPS. Need gearing for an 8.5. Not entirely sure I have confidence In. This car yet so I'm gong
To take it easy at first. Sloppy city this is, but
It's apparently normal. Must have bulletproof bearings in the front hubs. Even with the crush tubes that front end is a mess.
jpcopeland1 is offline   Reply With Quote
