Like Tree29Likes
Old 07-17-2014, 03:13 PM   #3691
Dstreelm's Avatar
Originally Posted by Matt :-) View Post
The R/C fairy left a present for me while I was at work !
Congrats! you have some work to do sir
Dstreelm is offline   Reply With Quote
Old 07-17-2014, 03:28 PM   #3692
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
broke a shock cap last weekend. fortunately i went with the factory team standoffs and caps for my B5M, so I went ahead and put them on all of my shocks. seems to fit ok. i wouldn't trust them without a bladder though.
RC*PHREAK is offline   Reply With Quote
Old 07-17-2014, 06:07 PM   #3693
Originally Posted by My ST-RR EVO View Post
How many MaH are you guys running in your batteries for club racing with a shorty pack? Looking to get 10 min of run time with a 6.5 motor.
Anyone?
Also, 2.4 or 2.2 for tire /rim size? what's preferred?
My ST-RR EVO is offline   Reply With Quote
Old 07-17-2014, 06:16 PM   #3694
Anyone?
4700mah 80c. Never fails me.
Bluect9a is offline   Reply With Quote
Old 07-17-2014, 06:23 PM   #3695
Matt :-)'s Avatar
Anyone?
A lot of people like these. They should run 10 minutes easy.
http://www.smc-racing.net/index.php?...product_id=127
According to Pro-Lines description, the 2.4's are lighter, have increased traction, and provide more control. I've never ran them myself.
http://prolineracing.com/tires/subur...m4-super-soft/
Hope this is helpful.
Matt :-) is offline   Reply With Quote
Old 07-17-2014, 07:31 PM   #3696
boudin4evr's Avatar
Trader Rating: 18 (100%+)
emulsion shock build or full bladder? decisions decisions.. for emulsion I need to drill out vent hole and cut bladder, prob dont have a drill bit that small! is there a huge difference emulsion over bladder?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 07-17-2014, 08:13 PM   #3697
I ran mine this weekend at the jconcepts summer nats in Chico Ca with the factory team standoffs and caps using a standard shock cap o ring shocks performed flawless .
LT FAB is offline   Reply With Quote
Old 07-17-2014, 08:52 PM   #3698
RC*PHREAK's Avatar
i re-read my post and i mis-typed. i bought the factory team standoffs and caps for my B5M and i put the stock plastic B5M standoffs and caps on my D413.
i am curious about your setup. you used aluminum factory team caps on your D413 shocks? what o-ring did you use?
Old 07-18-2014, 06:12 AM   #3699
How long is the servo arm? Are they standard among 1/10? I am thinking of removing the servo saver and just getting an aluminium servo horn when I get my kit.
moch8 is offline   Reply With Quote
Old 07-18-2014, 08:40 AM   #3700
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
I run the B5 composite caps and standoffs with .5mm shim in between tower and standoff with the stock HB bladder cut out for emulsion. No leaks or issues...
The HB Horn and most horns are universal for 1/10 and 1/8 vehicles. I would suggest Ditching the servo saver.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 07-18-2014, 09:54 AM   #3701
DWheels's Avatar
I didn't have a drill bit small enough either so I went with a long pin. Probably a sewning needle or maybe even a thin nail would work. You just have to go through a small amount of plastic to open it up.
Tekin, Inc. - Team Yokomo - Protek RC - Factory-RC Products - Pro-Line Racing - Vision Racing Products - Avid RC - Max.FX - SOR Graphics
DWheels is offline   Reply With Quote
Old 07-18-2014, 10:20 AM   #3702
boudin4evr's Avatar
I surprisingly had a bit that small
I think it was a 1/16 Yes I was surprised how little you have to actually drill out!
that is some tiny screws on that bad boys shock caps and diffs!
my old eyes cant see! i got it done
ill put in electronics sometimes this weekend
thanks
Marc Richard
Old 07-18-2014, 10:48 AM   #3703
RockStew's Avatar
JP would it be possible to see a pic of your RSX? I am doing my wiring right now and am a freak about clean looking and the capacitor is a pain, with my RS gen2 in my B5M I layed it over towards the body but if run the fan on the RSX it must go behind your help is much appreciated!
RockStew is offline   Reply With Quote
Old 07-18-2014, 10:50 AM   #3704
thanks
If you thread the screw all the way in it will make the hole for you too. 1.5mm is the drill bit size I used from my piston drilling kit.
AlderBoy is offline   Reply With Quote
Old 07-18-2014, 11:00 AM   #3705
slakr's Avatar
Trader Rating: 28 (100%+)
Above is what I did. Just be sure to check that the plastic that gets routed out by the screw doesn't remain inside the cap and obstruct the bleed hole. Had this happen on one shock cap... I just had to take my hobby knife blade and clean out the leftover plastic.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
