Like Tree28Likes
Old 07-05-2014, 11:29 PM   #3511
What are people's thoughts on this car on a low grip smooth clay track? With the shorty layout.
Regards,
RB6 - Nosram - Muchmore - SMC
HB D413 - Nosram - Muchmore - SMC
T4 2013 - Nosram - Muchmore - SMC
Tekno SCT410 - Tekin - SMC
K.O. Propo EX-1 - Proline - HEI - king RC - Coast2Coast rc
JacobsLosi is offline   Reply With Quote
Old 07-06-2014, 11:53 AM   #3512
Rybeau40's Avatar
Hot bodies RC nation Facebook group
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-06-2014, 12:00 PM   #3513
Red78's Avatar
I didn't see one..I was thinking of making one..unless someone else was
Red78 is offline   Reply With Quote
Old 07-06-2014, 12:03 PM   #3514
Rasheed's Avatar
Default 5 race update
I've run my D413 for 5 race days now, on a smooth low grip dirt track with big jumps. I started with the tessman OCRC setup.
I went down on my front diff fluid, now I am at 7K/60K/2K and am pretty happy with it. I felt like when I was at 10 or 15 in the front it was sluggish in the low speed steering areas. Im thinking about trying 5K in the front next to see how it feels, though it is getting to the point where it has as much steering as I need.
For shock oil I am running 35/30 with the 3x1.3 piston (used the kit piston and glued a hole shut). I tried using the gold rear spring instead of yellow (1 step stiffer) but the rear was just a little too loose at times. It was better on 180 degree turns, though.
Only have broken 1 rear ballcup. I bent a front dogbone, but it still works fine. I have never popped off a shock cap and never had a spur gear problem.
What hingepin holders did the kit come with? Did it come with 2 pairs of 1 dot, 2 pairs of 2 dot, and 2 pairs of 3 dot? I seem to only have 1 pair of 3 dot...
Derek "The Speed" Rasheed - Sponsored by Kaiser Permanente. Thrive!
davesrctracks.net - a great offroad 1/10th scale track.
Rasheed is offline   Reply With Quote
Old 07-06-2014, 12:06 PM   #3515
murky123's Avatar
what radio's do you guys use with this buggy.
I have some range issues with my sanwa mt-4 that I didnt had before. Was thinking of the carbon could be one of the sources for this issue
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 07-06-2014, 02:08 PM   #3516
Rybeau40's Avatar
I made one. It's Hot Bodies RC Nation on facebook.
Futaba 4PLS
Support your LHS.
Old 07-06-2014, 02:16 PM   #3517
Red78's Avatar
Didn't show up
Old 07-06-2014, 03:46 PM   #3518
Rybeau40's Avatar
https://www.facebook.com/groups/hotbodiesrcnation/
Any HB product join up.
Futaba 4PLS
Support your LHS.
Old 07-06-2014, 08:07 PM   #3519
5uperdave's Avatar
Hi everyone,
First time posting though i have followed this thread since the beginning.
PLEASE READ!
My LHS had a d413 kit in stock for about 3 weeks around the time nobody could find a kit to buy, and i finally gathered the cash to buy the car i'd been drooling over since its first pics were released, and my first 4wd buggy.
I have raced it 3 times so far, all 3 were trophy races, and all at 3 different tracks.
The first race, completely box stock, 2nd place A finish. The second and third races I finished 6th and 5th in the A-mains, and I will say there was more competition then the first race. With minimal changes to the kit setup I like how the car handles.
As much as this is a great car, ive had a couple issues with it.
1) The sway bar ball cup links- This issue was stated earlier. At least 3 times I have had the sway bar ball cup pop off the arm mounted ball stud. When this happens it alters the cars performance drastically. This issue led to my second issue.
2) Front driveshaft- On my third race day during qualifying i had the sway bar cup pop off and made the car handle awful, leading to a series of large wipeouts for the remainder of the heat. In this time, I bent the front driveshaft, which later snapped, and man was I mad considering parts support, and I will say this breakage is in part driver error.
This is where it gets good! A fellow racer that runs Team C had a spare centre 75mm driveshaft from his 4wd buggy (the shafts with the Team C buggy slipper setup, not the new centre diff set up) and it fit perfectly in the axle housing and the diff output!! One of the attached pictures shows the new driveshaft in the buggy. It is the thicker one on the left, and appears to be stronger than the HB stock one I have asked him to order me some spares.
After hearing of all the spur gear issues, I check my mesh every run, with no sign of wear after 15+ packs. My mesh is quite tight to try to preserve the spur gear, and my motor temps are around 135 on a 6.5t.
I have only been racing for two years, and getting better every weekend, and this buggy is fantastic!! Very durable for what ive put it through lol.
Thats it..
Hot Bodies D413 1/10 4WD Buggy-image-7-.jpg   Hot Bodies D413 1/10 4WD Buggy-image-6-.jpg   Hot Bodies D413 1/10 4WD Buggy-image-5-.jpg
5uperdave is offline   Reply With Quote
Old 07-07-2014, 04:03 AM   #3520
slakr's Avatar
Trader Rating: 28 (100%+)
Can you post up the part # for the TeamC driveshaft? Could be useful for others that get into a similar situation and needing a spare part to get them through the race day. Thanks.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-07-2014, 08:54 AM   #3521
another spur cut....just in case the original fails
Cygnus X is offline   Reply With Quote
Old 07-07-2014, 09:02 AM   #3522
the incubus's Avatar
Trader Rating: 17 (100%+)
Forget getting them through the day… If it fits perfectly, might as well replace it and keep the stock ones as spares.
As for the mesh being relatively tight, I say loosen it a hair to decrease motor temp juuuuust a tad. Another thing a tighter mesh does is build excessive heat which will soften up the molecules and softens up the plastic which can contribute to a failed spur.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 07-07-2014, 09:05 AM   #3523
Red78's Avatar
If you are making them...I'd buy one
Old 07-07-2014, 09:12 AM   #3524
Trader Rating: 129 (100%+)
^ I agree with this guy
skyline1015 is offline   Reply With Quote
Old 07-07-2014, 09:26 AM   #3525
5uperdave's Avatar
The guy that gave me the driveshaft is trying to find the part number for it. As soon as he finds it I will post it.
As for the spur gear mesh, i found the spur gear to be slightly out of round, not sure if anyone else noticed this with theirs. The way I have mine set is to be proper at the loosest side, and slightly tight on the tight side of the spur. The gear looks brand new after 3 race days and some practicing and temps are reasonable in comparison to fellow drivers 4 wheelers.
Hot Bodies D413
Hot Bodies D812
Team Associated B5M
Team Losi Ten-T
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jprevolution
