Like Tree31Likes
Old 06-24-2014, 01:10 PM   #3316
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Great Planes just told me July 3rd
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 06-24-2014, 01:40 PM   #3317
Trader Rating: 131 (100%+)
lets hope next week. i really dont want to see people selling their kits because of parts. This buggy is awesome and has so much potential
skyline1015 is online now   Reply With Quote
Old 06-24-2014, 02:05 PM   #3318
Trader Rating: 23 (100%+)
Default spur alternative
I just ran a few packs through the buggy with my ae spur conversion that cygnus came up with. Worked perfect. Ran a brand new 21t pinion just in case. Temps were fine and mesh looks good after 2 packs.
scteonoffroad is offline   Reply With Quote
Old 06-24-2014, 02:15 PM   #3319
STLNLST's Avatar
Trader Rating: 21 (100%+)
I wonder how many people's real cars have recalls on them even though they themselves never experienced that particular issue? People crack me up.....lol
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-24-2014, 02:46 PM   #3320
boudin4evr's Avatar
I'm hoping Tower has enough this time to fill my backorder from 4/16
If not, I'll just sale my electrics and tires(RSX and gen 2 6.5)(dirtwebs with new foams)
Marc Richard
Old 06-24-2014, 02:47 PM   #3321
Red78's Avatar
Finished up the wiring..I may re do it, but good enough to brk in the diffs
Hot Bodies D413 1/10 4WD Buggy-1403646559133.jpg
Red78 is offline   Reply With Quote
Old 06-24-2014, 05:01 PM   #3322
Originally Posted by yzracer758 View Post
Its just a picture they pulled off somewhere of Tessmann's buggy. Proline caps will never be in the hands of anyone other then Tessmann.
actually aluminum traditional style caps are coming!
No idea when.....but they are coming.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 06-24-2014, 05:02 PM   #3323
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Originally Posted by the incubus View Post
While this is true, there are too many people having the spur let go on them to say it's user error. And not everyone is running the same aluminum pinion and not everyone's mesh is just right to cause this. It's too much of a coincidence I think.
What's the actual count on people with spur gear issues? If I recall correctly, there were no more than 5 or 6 who posted in this thread.
The spur gear is the weakest link in the drivetrain. I fully expect it to fail. The when depends on who set the mesh, how you drive and the traction available. I think this "situation" is being blown WAY out of proportion. T.Deguzman is likely refraining from jumping in on this for fear of the shitstorm that would cause. Chill out, parts are coming, and I'm sure they'll get the "defect," or whatever you'd like to call it rectified. It's summertime any way. Just make sure kits and parts are available come early September.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 06-24-2014, 05:05 PM   #3324
JDJamminX1's Avatar
Well im happy to report that after a little over 2 months of running. I have had only 2 issues with the car, and one of them was not a spur gear....
I bent a front CVD hitting a SC full punched on the straight.
And have popped off the ball cup shock caps several times.
Bent back CVD with no issues.
Replaced ball cup caps with B5M shock caps and they are holding up fine.
I know people are having issues out there and I might know the cause. But Im no expert in the molding of parts process and the effects of them.
What I have seen from mine is that when setting the mesh. I set the mesh then rotate the spur all the way around checking the mesh each time I rotate the spur. There are times when I would have a tight mesh in one section vs. the other. This might be caused by the process of how the mold is being injected and could come up with a not so true spur.
I have seen this many times with many cars and many different manufactures. It is very hard to make sure that this process is 110% accurate every single time.
This is why I always check the mesh so that at least 70% of the mesh is as good as it gets, and the last 30% might be tight. After a few runs. I check it again. Most of the time the pinion will cut the 30% so that it is not so tight. Yes the spur gear will make more noise in the beginning. But after several packs this will be less of a problem.
If you set your mesh on a spot that will be tight, then the mesh will be 30% meshed based off that check, and 70% even looser which could cause the gear to skip. Especially under braking.
Again this is only what I have seen, and what I have seen with many cars from any number of manufactures. And that is why on all my cars I check the mesh on the whole spur gear and not just one section.
Yes, HB could work to try to fix this and they might. But this is a common problem with any car. Maybe not all of them, but most.
I hope this helps the guys that are having issues.
Again this is a great car. And I know as I was one of the few that was able to test it when it still was in prototype stages. When I tested it, it was pretty much the exact same as you guys see it today.
I still believe in this product even if I don't work for HPI/HB anymore. And that has to tell you guys something. I even went out of my way to get back on the team from a company that let me go, that tells you more.
Just my 2 cents.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 06-24-2014, 05:14 PM   #3325
t0p_sh0tta's Avatar
Are you guys torquing the diff screws in a star (cross) pattern?
Old 06-24-2014, 05:19 PM   #3326
Matt :-)'s Avatar
Preach it brother !
Matt :-) is offline   Reply With Quote
Old 06-24-2014, 06:54 PM   #3327
Tech Legend
Wild Cherry's Avatar
Believe the Ae cap & seal fit perfect ..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-24-2014, 07:53 PM   #3328
yes
Cygnus X is offline   Reply With Quote
Old 06-24-2014, 09:29 PM   #3329
Rybeau40's Avatar
You have an HB D413 you've tried it on?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-24-2014, 10:30 PM   #3330
the incubus's Avatar
Trader Rating: 17 (100%+)
I think they fit well but not perfect. The thread pitch was said to be slight bit different by a couple people in here so it cross threads slightly. Just keep an eye on them to ensure a gap doesn't build and they should be ok.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
