Like Tree42Likes
Old 06-19-2014, 10:12 AM   #3196
kdeleon's Avatar
Carbon, if you really want to make a drastic change. You should try Ty's "low" bite setup. It is also from OCRC where the Reedy setup was based. I tried it but changed the diff fluids to 15K/100K/3K (f/m/r) and 1 and 2 dot for the front kickup. That setup had way too much steering as I was driving on med to med-high bite tracks. So right now I'm more towards the Reedy setup. But you may want to try the other setup as I felt it had much more steering, too much for me.
http://www.petitrc.com/setup/hotbodi...nn_OCRC201312/
kdeleon is offline   Reply With Quote
Old 06-19-2014, 12:31 PM   #3197
JDJamminX1's Avatar
Default AE Shock caps, Aleternative
Here is a picture of the AE Caps installed. I ran them through practice on Tuesday at OCRC. Install of caps was a breeze. They look factory. What I used was the original plastic caps from the AE B5/B5M buggy. Fitment was pretty good. There was someone on here that said that they felt like the threads were stripping, but just a little. When I installed these they fit pretty good. Tight, but didn't feel like that were cross threading or anything. I used the bladders from the D413, cut to emulsion. They fit in there perfect, like they were meant to be. There is 0.50-1mm gap from the cap to the lip on the shock body. This might get dirt in there, but you could use a oring to combat that.
They held up through about 4-6 packs of long practice, with SC's gunning for me in every corner.
A good alternative, at least till the alum caps are released.
The only thing to look out for is fitment on the front. They felt a little bound up initially. If this is the case with yours, just add a .50mm shim to the back of the standoff you use and it should be perfect. Rear had no issue and completely free.
Hot Bodies D413 1/10 4WD Buggy-photo.jpg
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 06-19-2014, 01:02 PM   #3198
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
assuming those are AE standoff? also did you measure shock length/droop with stocker as well as the AE's? those caps look tall and may add some length.
RC*PHREAK is offline   Reply With Quote
Old 06-19-2014, 01:26 PM   #3199
JDJamminX1's Avatar
RC*PHREAK, That is a good point. I did do a visual check and they look to be pretty close. I think with how much material that the AE shocks have on the eyelet of the cap they may look tall. Sorry didnt get a exact number.
When running on the track I didnt feel much of a difference in the driveability of the car. But I will keep an eye out for this and report.
And yes they are the AE stock B5M standoffs. I used a thin lock nut on the inside of the standoff to get that 0.50mm extra length i needed for the front to not bind.
Old 06-19-2014, 02:30 PM   #3200
Trader Rating: 23 (100%+)
Originally Posted by Cygnus X View Post
here's my run from last night (dark orange/black) TQ...best 5 laps sub 18's yay have been working hard on that ;-) still have to shave off 2 secs to get 18 laps
+ YouTube Video
@Norcal D413 racers i can fix stripped spur if needed
Nice driving skills on that video. I sent you a pm to see about repairing a stripped spur.
scteonoffroad is offline   Reply With Quote
Old 06-19-2014, 03:21 PM   #3201
Trader Rating: 55 (100%+)
Anyone got an extra shock cap? I'm willing to pay for price of 2 but need 1.
Speedychris22 is offline   Reply With Quote
Old 06-19-2014, 03:25 PM   #3202
Trader Rating: 17 (100%+)
Get a set of the B5/B5M ones and try it like the guy a few posts ago.
AlderBoy is offline   Reply With Quote
Old 06-19-2014, 03:45 PM   #3203
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
I can send you one.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics |
Jeremy Potter
yzracer758 is offline   Reply With Quote
Old 06-19-2014, 03:56 PM   #3204
Red78's Avatar
Just got done with the build..
Hot Bodies D413 1/10 4WD Buggy-20140619_143325.jpg
Red78 is offline   Reply With Quote
Old 06-19-2014, 05:56 PM   #3205
Rybeau40's Avatar
Need suggestions for taking away a bit of steering. Added A few shims to the camber link, which helped. I was using a sway bar in the front as well, but didn't seem to take the twitch out.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-19-2014, 06:13 PM   #3206
Matt :-)'s Avatar
Would your radio simply allow you to turn down the steering gain, or fps ?
Matt :-) is offline   Reply With Quote
Old 06-19-2014, 07:02 PM   #3207
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by yzracer758 View Post
I can send you one.
Stepping up... I like that, did the same thing a few months ago, worth the dollar postage to help a bro out.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-19-2014, 08:30 PM   #3208
is tower suddenly giving me free car for waiting so long?
nicholasxuu is offline   Reply With Quote
Old 06-19-2014, 10:12 PM   #3209
the incubus's Avatar
From what I understand, it's just showing what you've placed an order for but it shows nothing in the shipped column and shows 0 stock so you have not been charged as of yet. Once it's in stock you will receive an update and the charge will appear and be processed.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 06-19-2014, 10:49 PM   #3210
Genebaby's Avatar
Yes, back ordered items are not charged until they are in stock.
Genebaby is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
YoG
