Like Tree28Likes
Old 06-11-2014, 03:00 AM   #3031
Originally Posted by Genebaby View Post
I'm going to get this car from Tower, so far I've also got in my cart:
*Hot Bodies Front Shock Tower Mount D413
*Hot Bodies Rear Shock Tower Mount D413
*Hot Bodies Front Suspension Arm Set D413
*Hot Bodies Rear Suspension Arm Set D413
*Hot Bodies Spur Gear 72T D413
Anything else I should look at maybe? Hinge pins? Shock shafts?
Maybe add a set of shock caps, they are in a set with damper plastics or something, then you probably have parts forever, thing is a tank
fjelltorsk is offline   Reply With Quote
Old 06-11-2014, 03:38 AM   #3032
Matt :-)'s Avatar
Originally Posted by masin14 View Post
There on ebay.
Can you post a link ?
Thanks,
Matt :-) is offline   Reply With Quote
Old 06-11-2014, 04:56 AM   #3033
Trader Rating: 23 (100%+)
Yes. Hinge pings and shock shafts. Also a set of the ball cups ends for the front and rear camber links. These take a lot of stress because everything else is so strong. I would skip the rear arms and double up on extra spur gears, diff gaskets, front spindles, and rear hubs. The hubs mainly because most of use the inside hole closest to the edge and it could break while the camber link ball cup cracks in half under extremely hard crash against a wall. This car is extremely tough so I don't think you will need these but without having a LHS supply I would stock up just in case.
scteonoffroad is offline   Reply With Quote
Old 06-11-2014, 05:51 AM   #3034
Genebaby's Avatar
Thanks, found them!
Tekno EB48 / Viper VTX8 / Tekin 1900
HB Tekno D8E / HW SCT Pro / Leopard 2150
Genebaby is offline   Reply With Quote
Old 06-11-2014, 05:57 AM   #3035
Genebaby's Avatar
Ok, rear arms are gone and I've found the rear hubs. More spur gears are in.
Are these the front spindles you're talking about?
http://www3.towerhobbies.com/cgi-bin...?&I=LXEGEG&P=7
Do you have part numbers for the ball cup ends, front and rear camber links?
I have front shock shafts only, it seems the front mainly break, or are rears a good idea too?
Old 06-11-2014, 07:25 AM   #3036
Front shafts only. I would skip the rear shafts. Here are the part numbers:
1. ball cup set 112724
2. sway bar cups 1127275
3. rear hub 112770
Old 06-11-2014, 07:35 AM   #3037
boudin4evr's Avatar
Trader Rating: 18 (100%+)
what are the stock springs F&R ?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 06-11-2014, 07:39 AM   #3038
Thanks,
Sorry looks like they sold.
masin14 is offline   Reply With Quote
Old 06-11-2014, 07:49 AM   #3039
Front Springs- 113063 61.8mm Gold
Rear Springs- 113068 36.4mm Yellow
Old 06-11-2014, 07:50 AM   #3040
[QUOTE=Genebaby;13328018]Ok, rear arms are gone and I've found the rear hubs. More spur gears are in.
You may also want to order the steering bellcrank in case you don't run a servo saver.
Hot Bodies Steering Crank Set D413 112764 part number
Old 06-11-2014, 07:53 AM   #3041
This is not the right part I was thinking. I would use this one because it has the carbon fiber L bracket that could break.
112769 Plastic front spindle
112768 Carbon fiber steering arm
Old 06-11-2014, 08:02 AM   #3042
boudin4evr's Avatar
thanks
Marc Richard
Old 06-11-2014, 08:32 AM   #3043
Trader Rating: 48 (100%+)
Does anyone know where I can get those orange sway bar holders by themselves? I stripped one so I need one
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 06-11-2014, 09:01 AM   #3044
I think you have to buy the whole sway bar kit to get those. I wonder if you can use the HPI kit below and just shave off the ball end with a dremel. Much cheaper option that is in stock.
HPI Sway Bar Holder Set
[HPI107883]
http://www3.towerhobbies.com/cgi-bin...?&I=LXEGFR&P=7
Old 06-11-2014, 12:22 PM   #3045
A fellow racer who got the d413 when I got mine has now broken 2 sets of shock ends. Anyone else having any issues? The bottom is just blowing out of the end on a medium sized jump. Nothing I would consider big or hard landing. I guess maybe hitting something on previous laps may be weakening them then they are letting go. Just a heads up. Keep an eye on yours.
Sct410, rc10b5, d413, Scx10 Honcho, Dex410v3, TRCE Slash, Hpi Blitz
Bluect9a is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
