Like Tree28Likes
Old 06-08-2014, 05:02 PM   #2956
has anyone found a solution for the shock caps? the plastic ones do tend to pop out None of the caps i tried fit (xb4, 22).
nicmo is offline   Reply With Quote
Old 06-08-2014, 06:58 PM   #2957
Trader Rating: 23 (100%+)
No options that I am aware of. Mine are fine. I will just have a spare on hand in case they get to beat up and start popping off. The new associated buggy is all plastic as well so it really should not be an issue.
scteonoffroad is offline   Reply With Quote
Old 06-08-2014, 07:21 PM   #2958
Genebaby's Avatar
Hi guys, it looks like 1/10th is gaining interest at my local track so I'm interested in the D413. I turned my Vorza into a D8E with the Tekno kit and really like it and it seems that HB has got it going with this little buggy.
I can see it's on back order at most places, and Amain don't seem to stock a lot of spares, though Tower have heaps.
What are the best parts to get as spares for the track and are there any notable hop-ups/changes to stock that are a good idea?
Do these cars use regular size servos? I usually run the Radiopost Red model:
Torque:
@ 6.0V: 333 oz in
@ 7.4V: 419 oz in
Speed:
@ 6.0V: 0.10sec/60
@ 7.4V: 0.09sec/60
Is that overkill/bad for a 1/10 buggy or will it be fine?
Are the shock caps a problem? I don't like the idea of plastic myself.
I don't have any 1/10 wheels yet so is it easy enough to get some that fit this car stock? I'm not sure about the whole difference in the hubs compared to other 1/10, in 1/8 it's all the same.
Vic
Tekno EB48 / Viper VTX8 / Tekin 1900
HB Tekno D8E / HW SCT Pro / Leopard 2150
Genebaby is offline   Reply With Quote
Old 06-08-2014, 07:29 PM   #2959
Originally Posted by jmoneym View Post
Using Orion Race Esc blinky / Orion 7.5t with 21 pinion, temps was not an issue after 7 min. I moved to a 5.5t same pinion I thermal at 3-4min. Switched to a 19 pinion did the trick. Coming off at 135 every time.
glad you posted this as I have the r10.1 pro and vst2 5.5T and just put on a 19t pinion to try out tomorrow at Dirt burners here in Michigan. I was just wondering how that setup was on a 19t pinion. did you have the top speed/punch you needed and how big is the track you run on. just trying to get an idea before I even get to the track tomorrow. thanks
randy0025 is offline   Reply With Quote
Old 06-08-2014, 07:34 PM   #2960
Rybeau40's Avatar
5.5t is too much for Dirt Burners imo. I use a 6.5 at Clubhouse and it has loads of power on a bigger track then Burners. Of course, you can always turn the 5.5 down as needed. I run a 22t pinion on my 6.5 no fans and motor temp hits about 160 at 10 mins right now.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-09-2014, 03:40 AM   #2961
Trader Rating: 309 (100%+)
My opinion with the center diff you need a 5.5 or at least a 6.5t. With other wheelers you can get away with 7.5t motors.
With the 5.5t I have top and bottom.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 06-09-2014, 05:09 AM   #2962
Matt :-)'s Avatar
Torque:
@ 6.0V: 333 oz in
@ 7.4V: 419 oz in
Speed:
@ 6.0V: 0.10sec/60
@ 7.4V: 0.09sec/60
Vic
This car was just released a month ago. There are a lot of people who have pre ordered everything. Including myself. Getting the kit, and extra parts will be a little slow for a few months.
The only aftermarket part available right now that I'm aware of is a ProLine body.
Normal size servos are perfect. A 1/10 4wd buggy only requires .130oz of torque. If you use a really strong servo, make sure you set your end points.
I've only seen a couple people on this thread have issues with the shock caps. Most people have no trouble with them. Just read the build tips on post #1. It shows you how to take care of them properly.
According to what I've read on this thread, TLR 22-4 wheels fit perfectly on the D413.
Matt :-) is offline   Reply With Quote
Old 06-09-2014, 05:31 AM   #2963
Only parts I want are spur gear and shock caps, I don't see myself breaking anything else.
Jermaine Mitchell
Mercenary Racer
Old 06-09-2014, 05:45 AM   #2964
carbons2k's Avatar
Trader Rating: 21 (92%+)
This car has some real potential. I drove mine the other day and only had 2 gripes with it... Its VERY VERY twitchy! Both steering and throttle. Im running box setup... does anyone know how to make the car less twitchy with steering? Also bc of the center diff... The car seems to have a lot of power right from the get go. Any ideas how to numb out the throttle a little? Could I go to a lighter diff oil? 50k? So far so good! Burnt up a spur gear but luckily a friend had a spare so I was saved.... I better stock up... if they ever come in stock!
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 06-09-2014, 06:12 AM   #2965
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Lighter oil will let the front do more of the work coming out of a corner. If you go too light, you'll be tearing through front tires. What oil are you running now?
Regarding the power, you can lower EPA, use your exponential, or just learn how to drive!
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 06-09-2014, 06:30 AM   #2966
carbons2k's Avatar
Smart ass
Im running this setup
http://www.petitrc.com/setup/hotbodi...1116/setup.pdf
Tom Licata
Old 06-09-2014, 07:18 AM   #2967
symmetricon's Avatar
Trader Rating: 27 (100%+)
I'm wondering if any of you guys have lightened up the c diff and went with a harder compound in the front to make it less twitchy and to compensate for the front end diff-ing out?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-09-2014, 07:44 AM   #2968
i just finished a big race at norcal hobbies running josh close's setup, the car took hell of a beating, with nothing broken ! it was EASY to drive not twitchy, and not once did it fishtail under power
some people drop in a super fast servo with 0.08 and lower times, this can easily make the car twitchy
i went up from 10K in the front diff to 15K (mugen) which calmed it down and made it easier to drive, without loosing steering or anything...if you feel like you want more steering remove front sway bar
i know Josh, when he set up his cars, he strives to make a car easy and fast.
we both run team powers radon pro 140A and 6.5T team powers motors, i opted for a fan on my motor....my esc fan did fail and esc came off at a whopping 150F auch !!!!
Norcal hobbies track had a brand new layout, and the buggy took quite a few nasty hits, something that for sure would have killed a b44 (mostly snapped a-arms) a couple of time i had to land on full power to correct for a mistake...no problem, one of the spectaters saw this, and said that would have stripped his 44 ring and pinion
this buggy is loud, and yes it is the center diff, well not the diff part but rather the spur...my buggy screams, the 2 other HB in this race where doing the same...so its normal.
im actually quite proud to be in the a-amain with the pro drivers (think there was 4 of them) i got screwed over a couple of times by some of the pro drivers who didnt have time for people to move over and decided to drive through them....(i thought they would have a more sportsman like behavior, especially when they are mixed with local club racers)
sworkz black thick wing, works great on this buggy, it will be the last wing you buy
i had a ton of fun, and want to thank norcal hobbies for a great race, thanks josh, vasutin, kathy, and HB for this awesome car....all the fast guys want's one now :-) which is great as we will get better parts support at the store.
Cygnus X is offline   Reply With Quote
Old 06-09-2014, 08:09 AM   #2969
Trader Rating: 17 (100%+)
It was an awesome weekend of racing. 3 D413s in the main and 1 in the B with all the local fast and Pro guys. Way to build a killer car HB!
AlderBoy is offline   Reply With Quote
Old 06-09-2014, 08:44 AM   #2970
+1
and dang it josh you beat me by a point :-D guess i forgive as you figured out a killer setup...and for that i thank you
HB...AWESOME CAR !!!! cant say that enough ...but please we need parts...one of the d413 driver had to switch to his backup(b44) as he stripped the spur....a spur should not be the end of a race
