Like Tree31Likes
Old 06-07-2014, 04:12 PM   #2926
Trader Rating: 49 (100%+)
Originally Posted by Beaker151 View Post
Contact Marcus at www.rcshox.com he either has or will very have his two stage pistons for the d413 shocks. Down here in Houston are tracks are outdoors, dusty and rough; his pistons work like a champ.
Thanks for the suggestion. Before I go that route I really want to make the pistons included in the kit work. I'm new to 4wd so just trying to understand what would work. I'm also trying to understand why some setups don't use a front sway bar and others don't use a rear. What the reason behind this.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 06-08-2014, 01:32 AM   #2927
murky123's Avatar
I drive on bumpy low grip out door.
I have 4x1.2 with 30wt in the back with the stock springs and I drilled the blanks as 2x1.4 with 35wt for the front with a slight stiffer spring then the one that came with the kit.
setup is evolving but I like it.
I use the thickest front swaybar and no rear swaybar
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 06-08-2014, 09:19 AM   #2928
Default Something better is around the corner!
What a blessing in disguise! I've had the HB D413 backordered for 2 months now and was getting frustrated to see the dates getting pushed back further each month. It all worked out because I found out that something better will be coming out soon. I cancelled my HB D413 backorder today with Tower. The D413 is a formidable machine but I don't like the way they jerked around potential customers. Also, the buggy that will be out shortly has had the chance to compile data on the D413 and is more flexible to varying track conditions.
logiqal is offline   Reply With Quote
Old 06-08-2014, 09:27 AM   #2929
Trader Rating: 310 (100%+)
Stop crying
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 06-08-2014, 10:40 AM   #2930
Thanks Murky, I was looking at ur setup, I see ur running 4mm under rear bulkhead, doesn't that give a high roll center?
My Credit Card
Old 06-08-2014, 11:06 AM   #2931
what buggy are you talking about?
ebay007 is offline   Reply With Quote
Old 06-08-2014, 11:40 AM   #2932
Why not send him a private message so we can stay on topic on this car
My Credit Card
Old 06-08-2014, 11:56 AM   #2933
Matt :-)'s Avatar
AWESOME !!! That puts me one more car closer to my pre order I just submitted 2 days ago !!! YOU ROCK !!!
Matt :-) is offline   Reply With Quote
Old 06-08-2014, 11:56 AM   #2934
murky123's Avatar
indeed. I wanted a higher real rollcenter.
Old 06-08-2014, 11:57 AM   #2935
Rybeau40's Avatar
lol...meanwhile I'm having the most fun with this buggy than I can remember with any wheeler in 25 years of rc. Durable doesn't even come close to describing it. The car you're hyping will also have it's availability issues for the first few months too, btw.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-08-2014, 01:28 PM   #2936
Trader Rating: 23 (100%+)
Default extra pieces in kit???
Guys. Do you guys happen to know what these are for. They have numbers on them. Hope I did not miss something in the build. Thanks.
scteonoffroad is offline   Reply With Quote
Old 06-08-2014, 01:30 PM   #2937
I dont remember those on my build
Zenbot is offline   Reply With Quote
Old 06-08-2014, 01:31 PM   #2938
murky123's Avatar
nope, never seen those
Old 06-08-2014, 01:34 PM   #2939
Matt :-)'s Avatar
Originally Posted by Matt :-) View Post
I don't have my car yet. Could anyone measure the front and rear 12mm wheel hex pins with a set of metric calipers (a.k.a. micrometer) and let me know what the thickness is of the retainer pins are ?
Thanks in advance.]
Old 06-08-2014, 01:38 PM   #2940
Default rear hinge pin and antisquat installation
I found a image from snyder on the front but did not see the rear image. Does this look like the correct way to install the hinge pin holders on the rf and rr? Thanks
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
