Like Tree29Likes
Old 05-26-2014, 02:43 PM   #2791
pli
Originally Posted by boudin4evr View Post
Hopefully they do the aluminum rear mount like Ty uses on his car...
Are you're referring to the plate where you mount the rear turnbuckles? That already comes in aluminium out of the box.
pli is offline   Reply With Quote
Old 05-26-2014, 04:58 PM   #2792
kdeleon's Avatar
Just anodized black while Ty's are "naked".
kdeleon is offline   Reply With Quote
Old 05-26-2014, 05:05 PM   #2793
Rybeau40's Avatar
Car is working great. Hit my best lap time on the current layout yesterday. Need to work on lap consistency now. Anyone have any tips for taming the steering down some. I do like my steering a bit edgy, but right now it's a bit much still.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 05-26-2014, 06:09 PM   #2794
boudin4evr's Avatar
Trader Rating: 18 (100%+)
that is good to hear! I figured it was plastic! My car is not here YET!!!!
longest back order ever! thanks
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 05-26-2014, 07:03 PM   #2795
Mopar's Avatar
Use a heavier front sway bar.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-26-2014, 07:34 PM   #2796
Rybeau40's Avatar
Used the black one from kit. Need to get a bit less steering still.
Futaba 4PLS
Support your LHS.
Old 05-26-2014, 07:41 PM   #2797
Trader Rating: 17 (100%+)
You could also add .5-1mm spacer to the inside front camber link. Not sure what setup you are working off of, but that will make the steering smoother, less twitchy and overall tamer.
AlderBoy is offline   Reply With Quote
Old 05-26-2014, 08:32 PM   #2798
rcgod's Avatar
Trader Rating: 27 (100%+)
Is there a fix for the shock mounts yet? Saw the first one on our track this weekend and the top of the shock was popping off on fairly small crashes.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-26-2014, 09:01 PM   #2799
Haven't had a single issue with mine and have had many very hard crashes. Has that person been popping the shocks off the ballstuds either for shock changes or any other reason? Because the more you do that the less holding capability they have. It is best to take the nut off the opposite site of the shock tower and leave the shocks on the ballstud.
Old 05-26-2014, 09:30 PM   #2800
kdeleon's Avatar
I also have yet to have a shock pop off.
Old 05-26-2014, 09:34 PM   #2801
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
I've put 7-8 packs through mine and no pop-offs.
RC*PHREAK is offline   Reply With Quote
Old 05-26-2014, 10:20 PM   #2802
Trader Rating: 22 (100%+)
I've had 2 or 3 pop off's, but they we're pretty good hits...
noproblems209 is offline   Reply With Quote
Old 05-26-2014, 10:29 PM   #2803
rcgod's Avatar
I have no idea how many times he's taken the shock off. Is the plan to wait until the shock cap wears and starts popping off and then replace the shock caps? Definitely sounds like a good place for the aftermarket to jump in.
Dialed RC Hobbies
Old 05-27-2014, 12:16 AM   #2804
I believe that would be a good time to replace the shock caps, yes. The shocks caps were designed in this unique way to avoid binding and provide freenes in the suspension. It works very well in that regard. And in hard hits they pop off instead of things breaking.
If they are popping off very easily then something is wrong. Most likely excessive ware in the ballcup or perhaps QC issue in the caps that came in that particular kit.
As far as upgraded aluminum caps go, I know some will be coming out just not sure when. My stock kit ones have taken so many hits from SCs they are starting to get pretty marred up. Not sure if aluminum ones would fair any better, but I will try them when they come out.
Old 05-27-2014, 06:44 AM   #2805
Matt :-)'s Avatar
Increasing the negative camber on the front is a very quick and easy way to calm the steering down.
Example,
0 degree camber = very responsive steering.
-3 degrees camber = less responsive steering.
Matt :-) is offline   Reply With Quote
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
