Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 05-18-2014, 06:24 PM
  #2686
Tony Rivas's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Stevomatik
Tony Rivas?... Are you married to Asa akira?
Wow no lol
Tony Rivas is offline
Old 05-18-2014, 06:30 PM
  #2687
Tony Rivas's Avatar
Originally Posted by evolution03
That may work but where am I going to get one to fit it ?
You can make one with a folders or thick paper I've done be for for 1/8 buggy
Old 05-18-2014, 06:43 PM
  #2688
I took the diff part today and i had to install all the 1.3 screws with a L wrench when i was building the kit. I ordered a 1.3 driver and used it today when i was rebuilding diff. Im hoping that the screws weren't tight enough and thats what caused leak. I couldn't get a good feel with the L hex wrench because plastic was new. hopefully the hex driver fixed it
evolution03 is offline
Old 05-18-2014, 07:23 PM
  #2689
Trader Rating: 22 (100%+)
Originally Posted by the incubus
ProLine made Ty's shock caps and I imagine they will be producing them soon. I'd call them up tomorrow morning and ask for a timeline.
proline made the caps because hot bodies could'nt have them done in them... ill be installing alum caps on mine when they come out but everything has to have a breaking point i've got 3 days of racing on my car with a 5.5 and i've had a few bad wrecks with no damage besides popping a cap off and snapping it right back on...
noproblems209 is offline
Old 05-18-2014, 07:57 PM
  #2690
RiseRC's Avatar
Default Durability
The durability has been awesome for me. I run a 6.5 in mine and have had some tumbles I thought would for sure would have broke something and it didnt. I broke one rear outer ball cup after full speed end of the straight away traction roll into a wall That was all me there. I have had some high speed direct pipe hits and all that happens is the shock caps and sway bar mounts pop off.
RiseRC is offline
Old 05-18-2014, 09:49 PM
  #2691
STLNLST's Avatar
Trader Rating: 32 (100%+)
Is there any overseas places that carries parts for this car? Tower's site is basically a coming soon advertisement. Car looks killer but VERY hesitant to get this now as parts is always an issue it seems.
STLNLST is offline
Old 05-18-2014, 09:57 PM
  #2692
Trader Rating: 17 (100%+)
I am more worried about shops not carrying parts because nothing breaks.
AlderBoy is offline
Old 05-18-2014, 10:12 PM
  #2693
STLNLST's Avatar
You still need some parts to run Ty's setup's from what I read.
STLNLST is offline
Old 05-18-2014, 10:20 PM
  #2694
True, option parts.
AlderBoy is offline
Old 05-18-2014, 10:32 PM
  #2695
STLNLST's Avatar
You running the Jconcepts race?
STLNLST is offline
Old 05-18-2014, 10:35 PM
  #2696
Yeah, I am on the wait list.
AlderBoy is offline
Old 05-18-2014, 10:49 PM
  #2697
the incubus's Avatar
This car JUST came out, it's so new the kits themselves are difficult to get a hold of. Unless you're pro, you won't benefit much from Ty's collection of parts and setup. You can just buy the car and a few arms and corresponding parts and learn the car as is and upgrade according to what suits your needs/preferences.
All this running out to buy a gazillion upgrades before ever driving a car always baffles me. Unless it's something that's factually week like the 410's servo saver that snaps as soon as it's placed under nominal loads, or the 22's putrid sliderack, try the car as is until you find something that's lacking.
the incubus is offline
Old 05-18-2014, 10:50 PM
  #2698
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
WWW.wheelspinmodels.co.uk
yzracer758 is offline
Old 05-18-2014, 11:01 PM
  #2699
If we start seeing Ty use the exact same setup for many different types of tracks or even between two tracks with the same type of grip I would say run out and buy everything he has. That hasn't happened yet nor do I see that happening. Each track will have a slightly different setup and every driver will like/benefit from a slightly different setup.
I think for me the only "option" parts I see getting are the carbon arm inserts, some extra spacers of various sizes, aluminum shock caps, HB spring set and some pre-cut shock bladders (if they ever come out).
AlderBoy is offline
Old 05-19-2014, 04:37 AM
  #2700
STLNLST's Avatar
The normal spares needed for any car aren't readily available though.
STLNLST is offline
