Like Tree28Likes
Old 05-07-2014, 05:59 PM   #2416
Originally Posted by Jakesterama View Post
You guys drilling a hole in the battery bar for your balance bullet or just taking it out of the car to charge?
Originally Posted by murky123 View Post
always remove the lipo from the car.
I have seen complete cars go up in flames while they where charging the lipo in the car
Always charge out of the car!
Originally Posted by Jpm1 View Post
Has anyone found the proline available anywhere?
prolineracing.com
Originally Posted by GGREAVES View Post
I get why there is an issue with an optional larger spur gear. It would not fit. With the 72 tooth spur gear there is minimal clearance between the spur and chassis. Any substantial spur gear increase would not fit with the diameter increase.
Exactly... larger spur will not fit
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 05-07-2014, 06:17 PM   #2417
stinky cheese's Avatar
Trader Rating: 21 (100%+)
Torrance.
In Australia we run 17.5 blinky stock and its a sanctioned class. Its has strong numbers and run across the country with typical gearing around 5.5/6.5 to 1. Some justification for a smaller spur and hopefully increased sales.
Thanks.
Leigh Cheeseman.
My racing is supported by the following companies
AKA Tires. http://www.ryperhobbies.com.au/
TKO Competition Development. http://premiermodelsupplies.com/
Tornado RC Chargers
Schelle Racing Innovations.
stinky cheese is offline   Reply With Quote
Old 05-07-2014, 06:55 PM   #2418
Rasheed's Avatar
Working on my build now. So far everything is going fairly smoothly.
I am trying to do the tessman OCRC setup. What shock piston included in the kit or which losi piston would be most similar to 2 x 1.6 and 2 x 1.7?
When I was putting the screws in the center diff I wasn't paying close enough attention and the screw starting digging into the spur gear. It didn't even feel like I was turning that hard...
Derek "The Speed" Rasheed - Sponsored by Kaiser Permanente. Thrive!
davesrctracks.net - a great offroad 1/10th scale track.
Rasheed is offline   Reply With Quote
Old 05-07-2014, 07:15 PM   #2419
mnracer's Avatar
Trader Rating: 25 (100%+)
Proline body shows in stock..limited quantity at tower
80% of my parts at tower now show invoiced.. Processing in warehouse.
Car kit still shows early May....
Billy D
mnracer is offline   Reply With Quote
Old 05-07-2014, 07:23 PM   #2420
kdeleon's Avatar
Default Spur preorder from Tower
For those that preordered a spur gear from Tower may want to check your order. Mine is being processed but instead of being the spur gear, the item is now pointing to the gear shims. I called Tower and they said that I had to email them my receipt that showed that the original description was really for the spur gear.
So just a heads up for those that are ordering another spur gear. Or maybe I could be the only one.
kdeleon is offline   Reply With Quote
Old 05-07-2014, 07:28 PM   #2421
mnracer's Avatar
Ouch!!!! My order had 2 spur gears... Now it shows shims..
Billy D
Old 05-07-2014, 08:06 PM   #2422
Errokk's Avatar
One could shim between the center diff and chassis to make room for a larger spur if one was available... A manufacturer could come up with a larger spur and shim kit...
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 05-07-2014, 09:06 PM   #2423
Trader Rating: 48 (100%+)
What parts did u order? I only see a couple of items in stock.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-07-2014, 09:12 PM   #2424
This is true as the center drive shafts are already not perfectly level, so shimming would not make too much difference on dogbone and out drive wear.
We shall see if they make larger spur gear kits.
GGREAVES is offline   Reply With Quote
Old 05-07-2014, 09:37 PM   #2425
I take back what I posted before. You can't shim the center motor mounts because of the top decks! They have to be level. You would have to shim all the top decks and the center bulk head and the motor mount. This would also weaken the structural integrity of the top decks and may put unwanted flex into the chassis. It opens up a whole can of worms.
Old 05-07-2014, 10:53 PM   #2426
Stevomatik's Avatar
Good video of d413 running on an indoor track
https://www.youtube.com/watch?v=NtjZJXs_a4k
Check out the bodies I've painted
Instagram.com/CBS_RC
Stevomatik is offline   Reply With Quote
Old 05-07-2014, 11:35 PM   #2427
Originally Posted by justpoet View Post
it'll just break faster. Lol
Lol.
Well, if nobody posts up before I get mine back apart, I'll gladly measure mine for ya'.
erevo1*16 is offline   Reply With Quote
Old 05-07-2014, 11:49 PM   #2428
Default Aka wheels?
So I bot a bunch of aka hex lite wheels for the front and rear, just wondering if they will work. Or if I need to send them back tower hobbies , still waiting for my kit lol, early may -k'mon baby !-
jdmjimmy is offline   Reply With Quote
Old 05-07-2014, 11:54 PM   #2429
Default Rsx
Originally Posted by erevo1*16 View Post
Lol.
Hey e-Revo - how are you liking the tekin rsx, I am going to be installing that esc with a tekin 6.5 and a 23 pinion, would I need to add boost and timming or would it be fine just like that with no boost or timming . Asking because of all the heat issues peeps are having .
Old 05-07-2014, 11:55 PM   #2430
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Which fronts did you get? Rears should be fine.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
