Like Tree29Likes
Old 05-05-2014, 05:45 PM   #2326
Ok I have gotten confused on gearing and motor temps.
I was running a 20 tooth with 6 turn motor and motor temp cut off kicked in on my ESC. However the ESC was cold, ambient temp. Shorty pack 4200mah 65c, toro 120a ESC and reedy sonic 6 turn motor, stock spur gear.
Should I be going bigger in pinion or lower??????
GGREAVES is offline   Reply With Quote
Old 05-05-2014, 05:56 PM   #2327
Mopar's Avatar
Originally Posted by boudin4evr View Post
somebody please show the pics of bushing and dremel work
Grind the top off of #112781 or find shim that will fit over the bushing as Torrance suggested. I just didn't have any shims. Your looking for around .5mm either way.
Hot Bodies D413 1/10 4WD Buggy-dsc00012.jpg
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-05-2014, 06:07 PM   #2328
Mopar's Avatar
Originally Posted by Rybeau40 View Post
What tuning setup on the sway bars are people finding work best indoors?
I made a 1.6mm and a 1.9mm bar. With the black front (1.4mm) and copper rear (1.2mm) my car was loose in sweepers. When I removed the rear bar the car was fairly neutral but could be traction rolled in some situations. Using a stiffer front bar will allow me to use the rear bar and eliminate the traction roll except for overly extreme situations. If you intend to make your own bar and want to use the collars you must put them on before you make your bends.
Old 05-05-2014, 06:36 PM   #2329
Errokk's Avatar
Smaller pinion will reduce your motor temps. You have any timing advance in the esc or motor? If so, this will cause higher motor temps.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 05-05-2014, 07:03 PM   #2330
hairless_ape's Avatar
What brand motor are you running GGREAVES? Every brand has different recommended FDR, it's not one size fits all. For example, Speed Passion motors have comparatively low physical timing, which means they require larger pinions than say a Reedy Sonic with the same number of turns. The motor should have come with a sheet of paper with he recommended FDR.
Also check your motor mount for slop (to the chassis and motor), any amount of wobble could cause excessive heat. And of course double check your gear mesh isn't too tight while your at it.
hairless_ape is offline   Reply With Quote
Old 05-05-2014, 07:22 PM   #2331
Originally Posted by gticlay View Post
This was at our track today
Hey, that looks familiar....
Here it is all done
Hot Bodies D413 1/10 4WD Buggy-2.jpg   Hot Bodies D413 1/10 4WD Buggy-1.jpg
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 05-05-2014, 07:39 PM   #2332
I am running reedy sonic Mach 2, looked and could not find FDR for the motor.
No slop in motor mount and gear mesh is good. I did have boost and turbo timing on 10 degree timing.
I have already changed ESC setting to eliminate timing advances and tomorrow will get a 19 tooth pinion, that's the smallest I can fit with the motor mount.
Guess I will try that, if that don't work then I am guessing I will have to go down in turns.
Old 05-05-2014, 08:37 PM   #2333
Rybeau40's Avatar
Originally Posted by Speedychris22 View Post
3x48
3x38
3x34
2 of each
What sets did you buy? I was trying to find some online, but none were fitting those dimensions. Have a link to them by chance? Thanks!
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 05-05-2014, 09:08 PM   #2334
kdeleon's Avatar
I don't think Lunsford does make those exact sizes. When I got mine, I converted the instruction sizes into imperial. Here is what Ty is using. Most are slightly shorter than the manual but I understand why he uses them after I built my car. We use up all the threading especially after copying Ty's setup. But here is what I got (which work fine) and they match out of box:
All are 3 mm and then 1 3/8" (steering), 1 1/2" (rear), and 1 7/8" (front).
Originally Posted by TYTESSMANN View Post
The sizes of the turnbuckles I use on the D413 are below
Front Camber Link 3 x 1 7/8
Rear Camber Link 3 x 1 3/8
Steering Link 3 x 1 1/4
I get my titanium turnbuckles from www.lunsfordracing.com they have great products.
kdeleon is offline   Reply With Quote
Old 05-05-2014, 09:48 PM   #2335
Default D413 review
+ YouTube Video
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 05-05-2014, 09:48 PM   #2336
Errokk's Avatar
Currently I'm running the xb4 2013 v2 with the same motor and a mmp esc with a 19t pinion with 10 degrees timing. The motor comes off a 10 minute main at about 165 and the esc has an air conditioner on it so it's good. I give it no slack whatsoever, and it keeps taking it and wanting more so I keep dishing out. Maybe a 19t pinion will fix you up. Good luck!
Wonder how this Wheeler compares?
Garage:
Old 05-05-2014, 11:14 PM   #2337
gticlay's Avatar
Here it is all done
Maybe because it looks sofa king good? Can't wait to see how it drives (hint hint!) I guess you can go for that big quad without worries. Need a faster motor?
gticlay is offline   Reply With Quote
Old 05-05-2014, 11:20 PM   #2338
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by Jason Snyder View Post
+ YouTube Video
nice vid jason. i can't help but hate all of you unprepared people with no electronics that got chosen to received a buggy from the first batch. i've had everything ready to go for this buggy (esc, motor, batteries, servo, servo horn, tires) for weeks and yet.....no buggy. no, actually i'll expand on that. i hate EVERYONE that has a buggy!!!!!!!
/end of jealous rant
RC*PHREAK is offline   Reply With Quote
Old 05-05-2014, 11:21 PM   #2339
dont hate the player hate the game.....
I have electronics....but have some different stuff coming for a review.....!
On a side note.....this car was sitting on the counter in a hobby shop in Illinois.....was not mail ordered!
Jason Snyder
Old 05-05-2014, 11:42 PM   #2340
gticlay's Avatar
+ YouTube Video
Nice review Jason. We need one on-track. Send it up here and I'll take it through a tough test.
