Like Tree31Likes
Old 05-05-2014, 02:14 PM   #2311
Originally Posted by GermanOffroader View Post
The Yokomo wheels has a perfekt fit! Front and rear!
Here a pic with the YOK wheels!
Hot Bodies D413 1/10 4WD Buggy-image.jpg
HB#hpiracing
LRP electronic
JConcepts
Sanwa
TQGrafix
GermanOffroader is offline   Reply With Quote
Old 05-05-2014, 02:15 PM   #2312
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I had no idea the AE wheels and other fronts are different offset
I agree if its 12mm should work
Im sure Ty runs Proline wheels he ran AE wheels at the worlds
T. Deguzman said something about the wheels for b44.2 are different offset?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 05-05-2014, 02:17 PM   #2313
boudin4evr's Avatar
that's exactly what mine will look like! All yellow!
Marc Richard
Old 05-05-2014, 02:20 PM   #2314
That's the Body for Training!
The other one is at the Airbrusher at the Moment!
I will Post some pics, when it is ready!
HB#hpiracing
LRP electronic
JConcepts
Sanwa
TQGrafix
Old 05-05-2014, 02:25 PM   #2315
@ Tekin--- Thanks for cookin' my new speed passions 8.5t. HAHAHAHAHAHA
Motor Temp 179
Battery temp 86
ESC ("auto fan") 97
No hot solder tabs... or wires anyplace~
(I don't think the motor is "Shot".... but it sure stinks~)
I got 5 packs in~ some tough tumbles, some good laps.
Only broke 1 thing. My motor!
72t spur, 28t pinion 8.5t SP v3 motor.
after pack 4 yesterday I hadn't made any changes to my initial build. (99% stock)
The only changes from box-stock were:
Middle line for droop both Fr/Rr.
I used 35wt Losi oil with Bladders.
20k/100k/7k for the diffs (Fr/C/Rr.)
After the first 5 minutes I checked the temps of EVERYTHING. each solder joint, my bullets, the motor end bells etc...
erevo1*16 is offline   Reply With Quote
Old 05-05-2014, 03:22 PM   #2316
mnracer's Avatar
Trader Rating: 25 (100%+)
I see my d413 still shows early May at Tower, the parts all changed to mid May today.
Billy D
mnracer is offline   Reply With Quote
Old 05-05-2014, 03:29 PM   #2317
Jpm1's Avatar
Mine to
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 05-05-2014, 04:36 PM   #2318
Here's mine. I did dremel the steering bushings probably half a millimeter. Other than that the build was very smooth. Just need to do a quickie paint job and i'm ready to go.
pullinteef is offline   Reply With Quote
Old 05-05-2014, 04:49 PM   #2319
boudin4evr's Avatar
somebody please show the pics of bushing and dremel work
Marc Richard
Old 05-05-2014, 04:51 PM   #2320
boudin4evr's Avatar
guys your cars look great! post some videos!
Marc Richard
Old 05-05-2014, 05:00 PM   #2321
Thumbs up
I have nothing to add to this thread... other than enthusiasm! My first 4wd buggy, reporting from Toronto!
I was going to build for saddles (since I have 2 sets) but shorty seems so popular I picked up a cheap pack at the LHS when I got the car. I'm also going to recycle the rims from my old 22 as it sounds like they'll fit?
PetRock is offline   Reply With Quote
Old 05-05-2014, 05:04 PM   #2322
Trader Rating: 22 (100%+)
car should be here within the hour and my proline type R should be here 2marrow
noproblems209 is offline   Reply With Quote
Old 05-05-2014, 05:28 PM   #2323
Rybeau40's Avatar
What tuning setup on the sway bars are people finding work best indoors?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 05-05-2014, 05:29 PM   #2324
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Someone please post vids of this thing running on the track with someone other than Ty behind the wheel I really want one of these
HB D815v2 (Nova Mito4) / HB D8TTE (Nova Mito7)
HB E817 (Hobbywing XR8 and 1900kv motor)
Associated B6D (Orion and Schuur Speed)
SEF is offline   Reply With Quote
Old 05-05-2014, 05:31 PM   #2325
Ran mine today after waiting for shorty packs to arrive.
After initial run I added the silver front sway bar to calm down the steering a bit. Have to change the rear diff fluid to 2000wt. Initially running 10000 front/ 30000 center/ 5000 rear.
I basically used the same set up as Ty medium traction setup and went from there.
Amazing car. I am used to 1/8 buggies and this feels very similar.
Only problem I had was motor temp. Running a 6 turn reedy with 20 tooth pinion.
I am hoping soon that there will be larger spur gears available so I can fine tune to keep motor temp down. I can fit a 19 tooth pinion on the buggy, but that is it. 18 tooth is close but the gear mesh is too loose.
So if anyone knows if and when a larger spur gear is coming, let me know.
GGREAVES is offline   Reply With Quote
