Like Tree28Likes
Old 05-04-2014, 09:17 PM   #2281
Made my own chassis protector from generic jconcepts film. A little patience, t-square and a razor blade.
Sct410, rc10b5, d413, Scx10 Honcho, Dex410v3, TRCE Slash, Hpi Blitz
Bluect9a is offline   Reply With Quote
Old 05-04-2014, 09:21 PM   #2282
RiseRC's Avatar
Thumbs up Best 4wd Buggy Ever!!
Thanks Torrenance and Ty for creating the d413. Drove it today for the first time and its awesome. Smoothest 4wd Buggy I have ever had the pleasure of driving. Cant wait to get it back to the track
Mike H.
RiseRC is offline   Reply With Quote
Old 05-04-2014, 09:29 PM   #2283
Originally Posted by GGREAVES View Post
are the upside down wing mounts intentional?
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 05-04-2014, 09:36 PM   #2284
mydudrevo's Avatar
Yes that's a tuning option. Pretty cool actually
Proudly sponsored by Tekno R/C
Tekno ET48 CC2200kv/HW150a
mydudrevo is offline   Reply With Quote
Old 05-04-2014, 09:39 PM   #2285
Trader Rating: 17 (100%+)
Originally Posted by T. Deguzman View Post
LRP power: No fan, No problem!!!
Velcro mounts were made from left over trimmings from the wing (build tip#8).
Nice!
Didn't realize the build tips had been updated. Did you use servo tape to hold them down? Just wondering if they are more to keep the body from folding in or if you use them to keep the body on without clips?
AlderBoy is offline   Reply With Quote
Old 05-04-2014, 10:13 PM   #2286
Originally Posted by murky123 View Post
I dont understand the complaints about the slop in the steering assembly / ackerman bar? does the car not steer? what problems does it bring?
I have noticed the slop also. but it is not a problem nor an issue at all. well at least I find it not to be a problem.
20+ pack ran with my d413 and it is still fine. no issue
Torrance, is this slop normal and deliberate?
Old 05-04-2014, 10:52 PM   #2287
Speaking from experience a car with no slop tends to be darty! "I'm not sure that darty is a real word...but thats how the car acts with no slop"
Jason Snyder
Old 05-05-2014, 12:20 AM   #2288
mtbkym01's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jakesterama View Post
Code:
			D413	ZX5 	D413	ZX5
			Front	Front	Rear	Rear
Width			26.3	27.8	38.5	37.8
Backspacing		23.5	24.5	26.7	26.0
Hex Face to Outside Face2.8	3.3	11.8	11.8
Hex Face to Mid Tire	-10.4	-10.6	-7.5	-7.1
Hex Depth		2.9	2.9	3.8	3.4
Nut Pocket Depth	0.4	1.1	3.9	7.5
Outer Bead		5.7	5.7	5.7	4.7
Inner Bead		5.7	6.1	5.8	5.2
Since I am coming from a ZX5 and have quite a bit of mounted tires left, I measured a set of rims and compared them to the included rims with the kit. I found that using ZX5 fronts will increase absolute width (outside rim face to outside rim face) 1mm and will decrease mid tire to mid tire width by .6mm. This is because even though the backspacing is deeper, the width of the rim is also more.
The rear ZX5 rims are interestingly 0.7mm narrower, but the backspacing is also 0.7mm less, so the absolute width is unchanged and the mid tire to mid tire width is increased 0.6mm.
I had to take a body reamer to the rear tire's axle holes and remove a little bit of material to fit the larger axle of the D413. I will use my ZX5 rims without a second thought!
Brilliant Info, all mine will definitely be utilised as well, cheers
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
Old 05-05-2014, 05:13 AM   #2289
Trader Rating: 48 (100%+)
Originally Posted by Speedychris22 View Post
I lost one of those little orange things that keep the sway bar from moving around. Where can I find a quick replacement
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 05-05-2014, 05:28 AM   #2290
Torrance designed the d812 to have "slop" in it when new so I assume the "slop" some of you are referring to is normal on this car. It helps keep the feel of the car more consistent as it begins to wear in. Haven't driven mine yet but I feel nothing feels too loose or "sloppy".
klithgow416 is offline   Reply With Quote
Old 05-05-2014, 06:10 AM   #2291
Matt :-)'s Avatar
Default Pinion selection
T. Deguzman or Tye,
Can you guys give a suggestion of what range of pinion tooth sizes might be good for me to keep in stock for the D413 ? I'll be running a 6.5 turn motor.
I race at 7 different tracks that have anywhere from 2,000 to 12,000 square feet of racing surface.
The smallest track's (2,000 square feet) longest straight is about 30 feet long.
The larger tracks have straights around 130 feet long.
Thanks for the help
Matt :-) is offline   Reply With Quote
Old 05-05-2014, 07:03 AM   #2292
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Originally Posted by Matt :-) View Post
T. Deguzman or Tye,
Thanks for the help
I am neither Ty or Torrance, but I am planning on running a 6.5 and 21-24T pinion. This is based on setups and recommendations for other 4wd vehicles. The best investment you can make is an IR temp gun. I use a cheap eBay one that isn't super accurate, but readings are repeatable. "Run for a little bit and check your temp" is really the only right answer. Sounds like you have a lot of different kinds of tracks to run on, and if I was you, I would have 20-25T on hand depending on temps and speed/acceleration needs at each track. Swapping pinions is really easy on the D413.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 05-05-2014, 07:12 AM   #2293
Matt :-)'s Avatar
Jakesterama, Thanks man !
At least that gives me a range of pinions to include on my initial purchase.
I noticed you mentioned "This is based on setups and recommendations for other 4wd vehicles."
Does the D413 have the same tooth count on the internal diff gears as other 4wd 10th scale buggies ?
Old 05-05-2014, 07:18 AM   #2294
FastPete's Avatar
Trader Rating: 44 (100%+)
Looks good, like the HW sticker.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-05-2014, 07:19 AM   #2295
Yeah, a little bit of slop is needed so everything moves properly and doesn't change over time as things wear in. I think what we are saying is that it just feels like there is slighly more slop in the Ackermann bar than with the rest of the car. I am sure it is fine, but you know how we RC nerds can be when we sit around at the bench playing with our new cars before we get a chance to throw down on the track
practice_lap++;
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
vicdamone11
