Like Tree31Likes
Old 05-04-2014, 06:40 AM   #2251
chinamonkey7's Avatar
Here is My D413.
chinamonkey7 is offline   Reply With Quote
Old 05-04-2014, 06:55 AM   #2252
Trader Rating: 48 (100%+)
I have to say working on this car is great!! I'm used to kyosho stuff and to change rear toe anti squat is beyond stupid. With this car it's done in no time. Well done Torrance. The only question I have is my car seems to have some play between the steering assembly. I followed the instructions. Did I do something wrong?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-04-2014, 08:52 AM   #2253
T-1hour!!! So geeked right now.
erevo1*16 is offline   Reply With Quote
Old 05-04-2014, 10:34 AM   #2254
Mopar's Avatar
I found that a lot of the play came from the bushing being .5mm taller than the rack. When you tighten the screws it leaves play. I dremeled the height down to minimum clearance. Now I tighten the screws down then back off just till there's no binding. I also notice play in all the ball cups, and before I drove the car it had me a little concerned. After driving I have no worries. Some cars like a little (for lack of a better word) slop, while others don't.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-04-2014, 10:51 AM   #2255
Great info, time to dremel!
My Credit Card
Old 05-04-2014, 11:52 AM   #2256
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Code:
			D413	ZX5 	D413	ZX5
			Front	Front	Rear	Rear
Width			26.3	27.8	38.5	37.8
Backspacing		23.5	24.5	26.7	26.0
Hex Face to Outside Face2.8	3.3	11.8	11.8
Hex Face to Mid Tire	-10.4	-10.6	-7.5	-7.1
Hex Depth		2.9	2.9	3.8	3.4
Nut Pocket Depth	0.4	1.1	3.9	7.5
Outer Bead		5.7	5.7	5.7	4.7
Inner Bead		5.7	6.1	5.8	5.2
Since I am coming from a ZX5 and have quite a bit of mounted tires left, I measured a set of rims and compared them to the included rims with the kit. I found that using ZX5 fronts will increase absolute width (outside rim face to outside rim face) 1mm and will decrease mid tire to mid tire width by .6mm. This is because even though the backspacing is deeper, the width of the rim is also more.
The rear ZX5 rims are interestingly 0.7mm narrower, but the backspacing is also 0.7mm less, so the absolute width is unchanged and the mid tire to mid tire width is increased 0.6mm.
I had to take a body reamer to the rear tire's axle holes and remove a little bit of material to fit the larger axle of the D413. I will use my ZX5 rims without a second thought!
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 05-04-2014, 12:14 PM   #2257
Rybeau40's Avatar
Build went well. Ended up missing bag Q, which are the wheel nuts. Also, having some steering slop issues with the ackerman bar.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 05-04-2014, 12:25 PM   #2258
Mopar's Avatar
Repeat: I found that a lot of the play came from the bushing being .5mm taller than the rack. When you tighten the screws it leaves play. I dremeled the height down to minimum clearance. Now I tighten the screws down then back off just till there's no binding. I also notice play in all the ball cups, and before I drove the car it had me a little concerned. After driving I have no worries. Some cars like a little (for lack of a better word) slop, while others don't.
Old 05-04-2014, 12:33 PM   #2259
I was going to race today, but I stayed up too late last night getting my 22T setup. Going to hit up the track tomorrow for open practice though!
Thanks for the idea on the bushing Mopar, mine is also pretty loose.
erevo1*16 - I did the same thing to get to the pinion set screw, good idea!
practice_lap++;
Old 05-04-2014, 12:48 PM   #2260
lbenton's Avatar
I think we have all the same issues.
I went through my trash bin and found the missing bag Q with the wheel nuts.
I noticed the slop in the bar as well as anybody that has looked at my car, not sure what to do for a fix, but a ball bearing style system instead of those grommets would do it, not sure if there is room in there though for that kind of hardware in the aftermarket upgrade world.
Originally Posted by carbons2k View Post
Just finished the build. 1 question... The hex pins keep falling out and I didn't even put the wheels on yet! Anyone know how I can keep them in place better?
And this issue about the pins... I may have a solution for this.
I put a small bend in the pins used for the rear wheels.. it is just enough to bind them in place without the wheel on. But not enough to make it hard to push them out with a small hex tool.
As for the fronts. I am have not tried it yet, but think I will try to fashion a small disk of duct tape to put on there since a simple bend to the pin will not solve the issue up front and the pin is in a trench on the outer side of the hex. Maybe it will hold it there enough that you can work on the car with the wheels off and not worry about the pins running away.
Already lost one of the 12mm pins on mine and had to cut out a piano wire solution to get me back on the road again.
So to all this, if there is a revision in order I would ask for two things that are my only gripe to be addressed.
1 - tighten up the ackerman bar
2 - a way to capture those floating pins in the wheel hexes.
Edit - Did a quickie fix on the front, I think it will hold well enough without holding too well like an adhesive might.
I will have to try that, the slop there in the bar just bugs me.. But it will not be today.
lbenton is offline   Reply With Quote
Old 05-04-2014, 01:29 PM   #2261
Rybeau40's Avatar
Did the dremel fix. Wheel nuts were in the garbage...lol. Also, I used some of my tlr black grease on the pins and it worked great. Just put some in the slots/holes.
Overall, I wish more companies would package their kits as compactly and nicely as this one. Real nice job on the bag layouts/labeling. Pretty sure a 12 year old could tackle this build. Now time to wait for some electronics this week.
Futaba 4PLS
Support your LHS.
Old 05-04-2014, 01:58 PM   #2262
lbenton's Avatar
It was shoebox sized, But I will add that my Durango DEX408T (1:8 truggy) came in an alarmingly small box as well.
Maybe this is a trend? It would cut down on the shipping expense I guess.
Old 05-04-2014, 01:58 PM   #2263
Mopar's Avatar
Next thing will be to fab a new front bar. I am making an .062in or 1.58mm bar, this should allow me to use the existing rear bars. I forgot to include interior pics earlier.
Hot Bodies D413 1/10 4WD Buggy-dsc00009.jpg   Hot Bodies D413 1/10 4WD Buggy-dsc00010.jpg   Hot Bodies D413 1/10 4WD Buggy-dsc00011.jpg
Old 05-04-2014, 02:17 PM   #2264
murky123's Avatar
I dont understand the complaints about the slop in the steering assembly / ackerman bar? does the car not steer? what problems does it bring?
I have noticed the slop also. but it is not a problem nor an issue at all. well at least I find it not to be a problem.
20+ pack ran with my d413 and it is still fine. no issue
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 05-04-2014, 02:21 PM   #2265
Trader Rating: 17 (100%+)
I see folks are mixing and matching Ty's setups with little bits of their own ideas and have varying degrees of success. I recommend you try a full setup from Ty with no mix and match. He puts a lot of time into each setup with every little detail working together with others. You may just find that his medium grip setup actually works well for medium grip.
AlderBoy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
jprevolution
