Like Tree28Likes
Old 05-03-2014, 04:09 PM   #2236
Mopar's Avatar
I started with Ty's OCRC med bite set up. Except for diffs are 10k front, 30k center and 3k rear. 1mm front inside camber, heavy front sway bar no rear. AKA Typo clay front super soft rear, WD40 for sauce. 2 x 1.6 37.5wt with bladder front, 2 x 1.7 32.5wt with bladder rear. Bladders tuned for minimum rebound.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-03-2014, 04:19 PM   #2237
Trader Rating: 48 (100%+)
Originally Posted by boudin4evr View Post
what size Lunsford turnbuckles? stock are steel?
3x48
3x38
3x34
2 of each
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-03-2014, 05:10 PM   #2238
Originally Posted by RC*PHREAK View Post
Thanks for getting back to me. One more question. Will this shipment contain significantly more kits than the first? The number that I heard for the first shipment was shockingly small.
the first batch was 300 kits. the 2nd is 400. we have a small factory. they're maxxed out.
Originally Posted by Mopar View Post
Or use a drop of thread lock. Praise to Torrance! ! ! This is the best 4wd buggy I've reed had. For my third run I change from 1.5mm to 1mm on inside front camber link. The car was absolutely hooked up, and was so easy to drive fast. The crash I had on the second run that bent the shock shaft would have broken at least one front arm if not both had I still been running my 410v3. Torrance, man you designed one awesome ride. You deserve a raise!
glad to hear the D413 is working well for you! a word of caution about using thread lock on the pins though - use very very little of it and only on the outer ends. if you use too much and it seeps in towards the axle they'll be a bitch to get out. i know because i've made this mistake
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 05-03-2014, 05:20 PM   #2239
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Ok thanks. I heard the first batch was much smaller than that. Hopefully I'll be lucky enough to get one from next batch.
RC*PHREAK is offline   Reply With Quote
Old 05-03-2014, 05:29 PM   #2240
What about spares? Do u know if they are coming with this shipment?
My Credit Card
Old 05-03-2014, 05:31 PM   #2241
fredmotokx's Avatar
What about parts? They are coming with the second batch? The only reason I have no kit on preorder yet is because their no parts available.
TLR SCTE 2.0
Team associated B5
fredmotokx is offline   Reply With Quote
Old 05-03-2014, 05:44 PM   #2242
Im confused. How is another 4-5 weeks "early may"??
Zenbot is offline   Reply With Quote
Old 05-03-2014, 05:47 PM   #2243
I don't know why this issue with spares always pop up. Back when I worked at AE it's the same story. Spares ship out with the kits. This is how we always do it. Most companies also ship spares out with kits. I don't know what happens to them after they leave our factory. Ask the distributors what they do with the spares. I saw an earlier post where somebody successfully ordered and received D413 spares.
Torrance Deguzman
powered by LRP
Old 05-03-2014, 06:16 PM   #2244
murky123's Avatar
no problem with spares here in europe
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 05-03-2014, 06:18 PM   #2245
RC*PHREAK's Avatar
great planes FTL...
Old 05-03-2014, 09:25 PM   #2246
mes
Originally Posted by carbons2k View Post
Just finished the build. 1 question... The hex pins keep falling out and I didn't even put the wheels on yet! Anyone know how I can keep them in place better?
ShoeGoo, the solution to almost every RC problem!
mes is offline   Reply With Quote
Old 05-03-2014, 11:06 PM   #2247
Mopar's Avatar
Back from a day at the track. I signed up for 2wd 13.5 class as usual. We end up with a mixed bag of 3 x 13.5 and 2 x mod 2wd. So for the second round I ran the D413 and ran a lap faster than my 2wd 13.5 and ran it in the main as well for another lap over the second round. My problem is I have to push myself to drive in 4wd mode. Now I'm only running a 9.5 while the 2wd mod's were running 7.5 motors. The car was fast, responsive, nimble and easy to drive, all while not feeling on "the edge". After the mains were over I let 3 friends drive the car and all 3 will be ordering cars this week. The funny thing was that all three said the car had too much steering for their preference. All the changes through out the day was to take steering out of the car and I felt the car was fairly neutral, but I have a few ideas for improvements. First off will be a harder front sway bar, around 20 - 25%, and tune from there. Only thing I need to order for spares are front shock shafts. I could have sold a half dozen kits if I'd had them.
Old 05-03-2014, 11:53 PM   #2248
gticlay's Avatar
This was at our track today
Hot Bodies D413 1/10 4WD Buggy-d413.jpg
gticlay is offline   Reply With Quote
Old 05-04-2014, 12:01 AM   #2249
Trader Rating: 17 (100%+)
Electronics added. Slowly but surely on this build.
AlderBoy is offline   Reply With Quote
Old 05-04-2014, 05:25 AM   #2250
Matt :-)'s Avatar
Hey guys, There are 7 different tracks in my area that I attend (Tennessee & Kentucky). I've never owned a 10th scale 4x4 buggy, but intend on the D413 being my 1st one. 3 of the tracks are indoor, the other 4 are outdoor. The track sizes range from 2,000 to 12,000 square feet of actual track space. Most of the guys I see at the tracks are running 6.5T motors, in their 10th scale 4x4 buggies, so I figured I'd run a 6.5T motor also.
My question is, what range of pinion gears should I keep on hand for the size & variety of tracks as described above if I were to run a 6.5T motor in the D413.
I've also wondered if I should just get 2 different motors, something like a 7.5T for the smaller tracks, and 5.5T for the larger tracks.
Maybe these are good questions for Tye, or Torrence ?
Thanks in advance for any advice.
Matt :-) is offline   Reply With Quote
