Like Tree35Likes
Old 05-03-2014, 01:41 PM   #2221
Mopar's Avatar
Forgot to mention that on the second run I nailed an 10th scale e-truggy full speed on the straight, only bent right front shock shaft. Took 30min to straighten out. I don't see the need at our track for the carbon inserts. But I will be making at least one harder front bar if not a couple.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-03-2014, 01:45 PM   #2222
Trader Rating: 50 (100%+)
Originally Posted by Matt :-) View Post
Speedychris22, you car looks GREAT !
Thanks Matt, also purchased the proline body but that's getting painted by a professional. The car came together great
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-03-2014, 01:53 PM   #2223
carbons2k's Avatar
Trader Rating: 21 (92%+)
Just finished the build. 1 question... The hex pins keep falling out and I didn't even put the wheels on yet! Anyone know how I can keep them in place better?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 05-03-2014, 02:02 PM   #2224
put a thin coat of black grease on the pins. that'll give it enough sticktion to keep from falling out.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 05-03-2014, 02:07 PM   #2225
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
Originally Posted by RC*PHREAK View Post
no sense in sitting around and watching a-main's date fluctuate from day to day when we have the man right here...
torrence, what is the status of the next order of buggies?
Hey Torrence ^^^^^^
RC*PHREAK is offline   Reply With Quote
Old 05-03-2014, 02:17 PM   #2226
Hey Torrence ^^^^^^
2nd batch is about 4-5 weeks after the 1st. that's when it ships from our factory. additional time added from processing by the distributors and dealers I don't know. 2nd batch should be somewhere over the Pacific now.
Torrance Deguzman
powered by LRP
Old 05-03-2014, 02:42 PM   #2227
Originally Posted by murky123 View Post
I run 23/24 pinion with 6.5T HW3.1 buggy/sct mode all settings unchanged. 4200mah shorty.
thank you murky for your response
jdmjimmy is offline   Reply With Quote
Old 05-03-2014, 02:44 PM   #2228
Speedychriss, i saw your car and it looks bad ass. Where did you get your titanium turnbuckles?
Old 05-03-2014, 03:12 PM   #2229
RC*PHREAK's Avatar
Thanks for getting back to me. One more question. Will this shipment contain significantly more kits than the first? The number that I heard for the first shipment was shockingly small.
Old 05-03-2014, 03:23 PM   #2230
Mopar's Avatar
Or use a drop of thread lock. Praise to Torrance! ! ! This is the best 4wd buggy I've reed had. For my third run I change from 1.5mm to 1mm on inside front camber link. The car was absolutely hooked up, and was so easy to drive fast. The crash I had on the second run that bent the shock shaft would have broken at least one front arm if not both had I still been running my 410v3. Torrance, man you designed one awesome ride. You deserve a raise!
Old 05-03-2014, 03:36 PM   #2231
Thanks bro, I got the turnbuckles from Lunsford.
My Credit Card
Old 05-03-2014, 03:42 PM   #2232
Mopar's Avatar
I did Lundsford too, only I anodized them green to go with my colors.
Old 05-03-2014, 03:55 PM   #2233
boudin4evr's Avatar
Trader Rating: 18 (100%+)
mopar, will you post your setup when dialed?
what surface are you running on? tires?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 05-03-2014, 03:56 PM   #2234
boudin4evr's Avatar
Originally Posted by yzracer758 View Post
Waiting for me at home in the box. At E-Nats in Texas right now. Will get you pics once some various parts are back from anodizer.
Ive been watching liverc
Marc Richard
Old 05-03-2014, 03:56 PM   #2235
boudin4evr's Avatar
what size Lunsford turnbuckles? stock are steel?
Marc Richard
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
