Like Tree28Likes
Old 05-02-2014, 11:24 PM   #2206
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 05-03-2014, 02:30 AM   #2207
Originally Posted by Zenbot View Post
When did you order yours?
March 27
Cygnus X is offline   Reply With Quote
Old 05-03-2014, 04:46 AM   #2208
Default pinion?
Sorry guys i need help, don't know what pinion gear or type to get, this is going to be my setup:
Tekin Rsx 6.5 combo
radiopost blue servo
shorty packs
tires: hole shots & blockades M4 compound with aka foams
Running at small track outdoor with light watering before qualifiers & main for night club racing.
Any help would be much appreciated, also if any of you can tell me a generic
point of how much boost and timing to get started, as i am not familiar with
electric buggy's since i run nitro primarily.Thank you guys- got all electronics just waiting on kit for my build process to start
jdmjimmy is offline   Reply With Quote
Old 05-03-2014, 05:41 AM   #2209
murky123's Avatar
I run 23/24 pinion with 6.5T HW3.1 buggy/sct mode all settings unchanged. 4200mah shorty.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 05-03-2014, 06:17 AM   #2210
carbons2k's Avatar
Trader Rating: 21 (92%+)
Thank you jason! Does it matter if they're the other way or this way?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 05-03-2014, 06:43 AM   #2211
The Hinge pin holders are one of the (many) nifty ideas I've seen used on this kit.
(I'm not sure if I've seen this style before or not, but I like it!)
In front the angle of the kick-up will be affected by adjusting the blocks.
In the rear it's called Anti-squat...
Check out your owners manual, on page 36 to see which blocks to use to get what of kick-up, or anti-squat you want~
http://www.hpiracing.com/en/kit/112723
erevo1*16 is offline   Reply With Quote
Old 05-03-2014, 06:58 AM   #2212
So, just because I have always geared for temps, and I've never bought a NEW kit before (meaning they've always been on the market before I bought.)....
I don't know what to start my gearing at. (I've always had a good starting point before this kit~
I'm running a Speed Passion 8.5t (about 4000kV.) with a Tekin RSX.
I was looking into the "top speed" calculator... I Plugged in the diff for the RC8b (3.31 ratio.) and plugged it all in for a 28t pinion, can came out with 42mph... Which is faster than I'm thinking that I'd need to go on my 1/10 local track...
I see guys talking about 41t pinions, and I wonder if I've got mine geared way too low....
Any help would be good~ Looking to get this truck on the dirt for the first time tomorrow.
Old 05-03-2014, 10:23 AM   #2213
Rybeau40's Avatar
Ordered from Absolutehobbyz Thursday and delivered today. Time to get building!
Attachment 1193005
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 05-03-2014, 11:02 AM   #2214
Attachment 1193005
I knew i should have ordered one from there, it just sounded too good to be true lol.
Zenbot is offline   Reply With Quote
Old 05-03-2014, 11:03 AM   #2215
Mopar's Avatar
First run on car was decent. Just a little loose in back. Am disconnecting rear sway bar and going up 1 tooth on pinion gear. Started w/ stiffest front bar and softest rear bar. With they made a harder front. Might have to make my own.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-03-2014, 12:18 PM   #2216
Rybeau40's Avatar
Any idea what grease Ty is using in his diff build video?
Futaba 4PLS
Support your LHS.
Old 05-03-2014, 12:27 PM   #2217
Trader Rating: 48 (100%+)
Want to share a couple of pics of the car!
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-03-2014, 12:56 PM   #2218
Matt :-)'s Avatar
Speedychris22, you car looks GREAT !
Matt :-) is offline   Reply With Quote
Old 05-03-2014, 12:57 PM   #2219
Mopar's Avatar
Second run better, definitely need stiffer front bar to be able use the light rear at all. Going to lower front inner camber link.
Old 05-03-2014, 01:06 PM   #2220
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
or maybe the carbon fiber arm inserts up front. i'd like to have those as a tuning option, but i think the last time i looked you could only buy the front with the rears and the price was really steep. hopefully someone like SnR makes just the fronts if HB isn't going to sell them separately.
RC*PHREAK is offline   Reply With Quote
